Colors split on my ony rear projection tv
When the tv is first turned on the colrs are split then after awhile it will fix itself but it is getting worse every day. any help would be appreciated
  • hunter02 Dec 23, 2008
    thank you not sure what a heat sink is but can solder do i need to worry about risk of being shocked
  • hunter02 Dec 24, 2008
    Thank you I will try this and let you know.
  • 4,234 Answers
If by a color split, it looks like a 3-D picture, the problem is in the convergence circuit. Since it recovers on its own, it suggests to me that there is a poor solder connection at the convergence ICs. If you can solder, this should be a simple repair. Locate the convergence ICs (large black ICs attached to a heat sink that should be marked STKxxx). Resolder the pins on both ICs. If that does not resolve the problem, let me know.
Dan
Posted on Dec 23, 2008
  • ABRsvcs Dec 24, 2008
    You will recognize the heat sink as it is a large silver colored metal piece with a couple of black ICs attached. There are high voltages present even when the set is unplugged, so be careful. You should be fine as long as you are careful not to touch the picture tubes or the red wires going to them
    Dan
I might have issues with my color wheel, Im bnot recieving a picture with full color!
if tv is lcd it has three color filters which can be damaged by heat.If it is dlp then it has a colr wheel which spins.they are located in the light engine.alcd tv has 3 lcd panels a color filter(red green or blue)is mounted behind panel coloring light going through lcd.prisms combine pictures before going through lens. If color burns off of filter then color of picture is affected
Oct 19, 2009 | Panasonic PT-50DL54 50" Rear Projection...
I have a mgnavox hd t.v. and the colors are messed up
Check to see if you are using componet cables which are video cables and make sure your red ble and green are in the proper places on the reciever and the tv.
Oct 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
SCREEM TURN BLUE
The lamps inside of it are weakening, much like a fluorescent light burns out slowly...so get it into a reapir shop OR better yet, Call for an ESTIMATE or replace the whole thing.
May 23, 2009 | Sony KP-51WS500 51" Rear Projection...
Cant get the redd green an blue projectors to line up correctly
you need to have the set reconverged,,,call a repairman to come out and reset the colors
Mar 01, 2009 | RCA HD52W56 52" Rear Projection HDTV
Mitsubishi WS-55411 55 in. Rear Projection Television
2 possibilities. Either your convergence IC's are going bad, or you need to remove the front panel of TV where the speaker grill is and you will find a small box with 6 control knobs on it. Mark each knob so you can set it back to its original position if you forget, the set might turn off if you adjust too high on either color, if so, set knob back in original position and turn tv back on and try again.The if it works reallign your convergence and that should do it.
Jan 28, 2009 | Mitsubishi WS-55411 55" Rear Projection...
WHY DOES MY TV TURN OFF BY ITSELF AND WON'T TURN ON FOR AWHILE?
There is 2 reasons for this poor solder on power AC board and a capacitor going bad. cap when failing will puff up on top.
Nov 29, 2008 | Akai PT4799HD Rear Projection Television
Sony 60 inch KDS 60A2000
sounds like a weak red gun..... fixable sure
The colrs you describe point to the red being the issue
try to run up the red gain to see if that helps
LB
Sep 22, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Colr red keeps coming in and out. had tv for 5 years and hasnt been serviced
If you don't have a degree on tv repair you should not try to fix it yourself, projection tv's are complicated on the way they are build, and when it comes to realigning the projector you are better of leaving it to the experts, dont try to fix it you might make it worst.
Feb 10, 2008 | Televison & Video
Color wheel
as a technician i dont feel the color wheel is a difficult repair. HOWEVER ..color wheel relacement means sometimes depending on model removal of light engine. which means you can get into alignment issues. then once the color wheel is replaced then it too has to be alligned.
Dec 27, 2007 | RCA HD50LPW164 50" Rear Projection HDTV
3 green spots on the top center of my projection hd tv
I had a similar problem and brought it in to a technician for a quote of $860 to fix. The problem - speck of dust on the optics. If it weren't under warranty I would take it apart and blow off the dust myself.
Dec 19, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Televison & Video Logo
285 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
