I have a 37 inch 1080p lg tv which i have just connected to a ht503ph via the hdmi cable. when i am watching the dvd it starts to flicker then the screen goes all white an fuzzy (like the tuning on an old tv). the audio still plays, if you select setup and then press play the dvd plays for a short while but then goes white again
Hi elcrozier.Try changing the resolution from 1080p to 1080i in the system setting on the ht503ph. I had the same problem and that fixed it. good luck
Posted on Jan 05, 2010
Have lg 55ls5700 tv trying to connect samsung hw-f450
I suspect that the TV you have does not support the ARC function that the sound bar has. What you may have to do is use the Optical In from the sound bar to the TV and you should be good to go. You may have to change the TV's settings to use the Optical In though. So you should end up with the BluRay Player connected to the TV via an HDMI cable, the sound bar connected to the TV via the Optical In using a fiber optic cable. Hope this helps.
Mar 19, 2014 | LG 55ls5700 55 Edge Led Smart Tv 120hz...
How can I use my lg lcd tv model m1994a for my ps3 there's no video signal,I try it all inputs to my lcdtv from av cable.component video,and hdmi cable still there's no video signal,but if I'll connect to...
I solve it already my problem by connecting my ps3 to an 32 inches lcdtv and I change the videosetting to my ps3 to default setting because before when I had my sony bravia 32 inches I changed it to 1080p via HDMI cable signal...After I changed to default settings I connected it again to my own LG lcdtv 19 inches but it sadly 1080p is not so very much supported but anyway I can play now ps3 games...
Nov 21, 2009 | LG 42LC2D 42 in. LCD HDTV
Flickering picture when setting resolution to 1080P vs 1080I
This simply means that your TV isn't capable of handling a 1080 progressive input. This is why it is flickering. Change it back to 1080i(interlaced) and the only time you should ever see flicker is in a still menu. But even then it should be barely noticeable.
If your TV does support 1080progressive then you may want to change the scan frequency of the Yamaha receiver. Common ones are 24 frames/sec or 50/60 Hz. The amplifier should have an auto setting which will detect what the TV can display. The nice thing about HDMI is all that information is transmitted through the cable.
A version 2 or highspeed cable won't change the display at all.
Aug 11, 2009 | Samsung BD-P3600 Blu-Ray Player
Insignia 37 inch lcd inputs not working except for hdmi inputs
TV when hooked to Direct TV by HDMI will not work, it must be hooked by RCA cables. I now have 1080i rather than 1080P. The HDMI cable and the direct TV box has been changed. What can the problem be?
Jul 01, 2009 | Televison & Video
LG 42LC2DB LCD TV Flickers when Ps3 is connected via HDMI port
Make sure you have the PS3 set to the correct frequency for the TV. Many cannot accept 1080p / 24fps etc.
Try different settings.
I hope this helps.
Mar 28, 2009 | Televison & Video
LG HT503PH dvd setup
You only connect the hdmi cable to the tv - it takes care of both the video and audio to the set.
Jun 28, 2017 | Televison & Video
Playstation 3 Flickers when set to 1080P
It sucks to see ALLLLLLL these solutions, when I have the solution. Turn off DEEP COLOR in the video settings. It will immediately stop. If it doesn't, then you don't have the typical snow/flickering problem.
Oct 02, 2008 | Sony Playstation 3 (PS3) Console
Lg plasma
there are 2 types of flicker, one is the lamps that drive the display and the second is the sync signal of the video.
I assume the video sync is the flicker you see,
I would try connecting a different way to make sure it is not the tv,
connect using the aux /rca connectors to cable box.
and or connect using the cable direct bypassing the cable box.
I have seen several complaints about the hdmi cable signal being incorrect in some way,
this is the same issue that the svideo connector had in its early adoption signal was too hot or too low.
another thing to watch out for is the low light sensor on the front of tv if it gets an incorrect reading it can flicker the back light though it should be slow in doing so.
some times the flicker you see is not flicker but ac running through the sides of the picture from an ungrounded cable source.
how does it perform if you play a dvd player , with and without the cable box connected.
Apr 29, 2008 | LG 42PX5D 42 in. Plasma HDTV
Panasonic Viera 37 inch Plasma won't read DVD player
does the cd/dvd player have component hookups or are you just using HDMI cable, lots of tv's are having trouble with the HDMI protocol, I only use component cabling, it has HD capability up to 1080i resolution
Mar 16, 2008 | Televison & Video
141 people viewed this question
