I solved the problem by avoiding this stupid website that only screws you around trying to sell you something and go somewhere else. If your stupid response program would have noticed i asked a question about a different freezer you morons.
Was this helpful?
Yes
No
Popular Solutions for Kenmore 14.8 cu. ft. / 419
Kenmore 14.8 cu. ft. / 419 liter Chest Freezer 13541
I've been using a chest freezer as a frig running it with a Johnson Controls external thermostat....
(More)
I've been using a chest freezer as a frig running it with a Johnson Controls external thermostat. It's been working great staying at a constant 35-40 degrees fahrenheit. The past month it's started to warm up inside. The motor is running, I hear fluid in the walls of the unit. The top section started to get frosty while the rest of the unit would remain fairly warm. This unit has a flash defrost that I initiated. The front internal walls of the unit got very hot while the back was only moderately warm. I unplugged it and let it sit overnight. I plugged it in the morning and let it run all day. The unit was only moderately cool after 10 hours. The thermostat is set on 7 (max). I've adjusted it off and max several times. I hear the unit running the whole time. When I adjust it to 7 after turning it off I hear something else energize for a few seconds and then shut off.
This happened once.
Any assistance with this is greatly appreciated. My kegs are getting warm.
Best regards,
Ross
the power to the house went off. got the generator started to take the load of my house. upon...
(More)
the power to the house went off. got the generator started to take the load of my house. upon outside power comming back on and switching the power. I have noticed the freezer wont work. I made sure it wasnt the outlet and went from there. I dont see the power light on and i dont hear the compressor running? Any ideas would be great. Jon
my freezer just went out light was on in it when i opened the door and all of the contents of the...
(More)
my freezer just went out light was on in it when i opened the door and all of the contents of the freezer was thawed out completly EVERYTHING about $750 worth or more it steaks hamburger sausage chicken hams and turkey's and it was all warm like it had been off for 2 - 2.5 weeks but it was still plugged in and on 7 the smell brought me over to it.so i turned the temp switch to off waited 5 min and turned it on and still no luck compressor never fired or motor for that matter 2 days later went back down to check and everything was working on it light compressor and motor now i dont trust it is there a recall on this model# 253.14922101 heavy duty commercialmanufactured date was 1-06
