Question about Kenmore 24902 Top Load Washer
How do i get the belt on my 80 series
I have no diagram to put the belt on. the belt is the original and it broke so i am not sure how it was run any buddy give me a hand
  • 640 Answers
If you have a belt driven kenmore,it time to replace it,,they where phased out,,so if you can get the parts i will help..open top with putty knife,,push on the two clips..take tub ring off ..take off agitator,,losen spanner nut,,remove tub ..now you have to turn unit so tha back panel faces you and lean the front agaisnt the wall..remove panel,,now drop the transmission about a fraction of a in,,the transmission bolt to your left looking form back has a spacer remove this bolt and the spacer remember let transmission come down some but dont let it drop..take your belt and put on from that spacer that you removed..if you got this far were almost home wedege the belt over the clutch it will be a thight squeeze..but use a big screw driver or a small pry bar,,remember give yourself as much play in with transmission drop with out taking it out,,just reverse to re assmb,,,,
Posted on Dec 24, 2008
I have a hotpoint model# dlb2880aacad. The belt broke. I bought a replacement part, giving them the model number to ensure the correct belt. It seems too long, but I am not quite sure if i am putting it on...
The belt needs to go over the tension pully too. This will make up for the slack. Check the internet under your model for diagrams. Good luck!
Sep 03, 2011 | Dryers
Can you tell me or send me a diagram how to line up my timeing belt on a Geo Tracker
Unfortunately there is more to it. You have to put the #1 Cylinder to Top Dead Center on the compression stroke. You need to make sure the valves are set so the number one set of valves are on the compression stroke. Then you need to align the timing marks on the timing gears correctly and get the timing belt on. If the original belt broke while the engine was running you want to make sure and get that head checked and verified as good. If any of this does not make sense you need to get the Haynes or Chilton's repair manual on your vehicle so you have step by step instructions for doing these steps.
Jun 25, 2010 | 1995 Geo Tracker
Timing belt broke on hyundai accent how do i replace it and the timing marks
1st you may want make sure that's not an interference engine. if it is then chances are the valves are bend in the head. changing the timing belt probably won't help then. If its not an interference head, then you would need a timing mark diagram which can be found online. be very careful that all marks are aligned. when finshed installing the timing belt, rotate engine by hand twice and re-align marks before putting the rest back together! hyundai should be able to tell u if the engine runs interference or not.
Mar 29, 2010 | Hyundai Motor 1995 Accent
Alt belt broke have new belt need directions to
give these websites a try www.alldatadiy.com and www.autozone.com if all fails stop by your local library and get your hands on a Haynes auto repair manual for your car also give this website a try Drive belt diagram at www.webcrawler.com wish you the best of luck Michigan Man.
Mar 21, 2010 | 1995 Mazda Protege
I have a Kenmore 80 series gas dryer. Dryer heats
The belt around the drum has come off or broke. The front of your dryer will have to come off to inspect
Feb 04, 2010 | Dryers
Hi. Broke the two fan belts on my 80 series landcruiser today and having not replaced them before i dont know the best way to get the new ones on or the exact configuration on the wheels
BELTS MORE THAN LIKLEY HAVE TENSIONERS
WHICH HAVE TO BE BACKED OFF AND RETIGHTENED AFTER BELTS ARE REPLACED.
YOU MUST HAVE TO SECURE A DIAGRAM OF
BELT ROUTING IF THERE ISN'T ONE ON SHROUD.
PARTS STORE MAY BE ABLE TO HELP YOU ON
THIS ISSUE.
Jan 04, 2010 | 1995 Toyota Land Cruiser
Replacing serpentine belt I need a diagram. The belt broke and I'm not sure how to put the new one on.
for the most part there is a diagram under the hood but give this website a try drive belt diagram www.webcrawler.com wish you the best of luck Michigan Man.
Jan 03, 2010 | 1992 Buick Century
Kenmore 24902 Top Load Washer Logo
49 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
