Machine will not read discs, including DVDs,DVD-RWs, and CDs. Have opened machine and cleaned optical lense. Still no joy. Connections to disc drive do not look the same as for a computer one so do not know how to replace it.
SOURCE: lite on lvc 9016g will not prepare dvds or record
I had a problem with a Lite-On that had been working fine then stopped reading any disc--sometimes it would go through the motions of recording if a disc was in and a timed recording was due to start. After recording it would not read the disc. I tried a DVD/CD lens cleaner but it didn't appear to even spin up. A google search led me to find the a dirty laser would cause this. I removed the cover and with a clean lint free cloth I used rubbing alcohol to clean it and it has worked fine since. While I had the cover off I took the unit to my garage and used an air compressor to blow all the dust out of the unit and cleaned the laser again just in case. That was about 6 weeks ago and it works fine. My unit has a cooling fan that I think contributed to the dust problem.
SOURCE: Invalid disc reading
I have successfully made hundreds of play-able DVDs from my home video using this Liteon LVC9016G. Overall I like this machine although it is very quirky.
In my experience the only DVD that can work is SONY DVD+R 120min / 4.7GB. NOTHING ELSE WILL WORK RIGHT. I have used some DVD-R: You can record on it since everything appears to work. The got-ya is you cannot play it at all. I am sick of this because I have re-used some tape but ended up with useless DVDs! Take my word for it, I have tried many media like Maxwell or Verbatin. These "other brands" are fine on the computer but not on this machine. I don't know what this machine can detect and see the differences in the media. Give this media a try.
SOURCE: Liteon DVD recorder LVW-5045 has disc inside and won't open tray
Use your knuckles to knock on top of cabinet just above disc tray door while at the same time pressing open button,99% of the time disc tray will open.The problem you have is caused by a worn out belt drive or the tray is out of alignment.The disc tray belts only cost $2,when tray is open you can see the minature belt that controls door to the right.Use twizzers to remove and replace.Belt size 1.9
