HOW TO DELETE EISA CONFIGURATION PARTITION CAN U SEND ME THE PROCEDURE PLZZ
  • Anonymous Mar 31, 2009
    My drive is in an external USB drive and this doesn't work
I am having VGN 23G and it came with Vista Home Premium. Right now im using window 7. The os's is working properly. Due to 1GB of RAM using vista is a bit frustrating . All the drivers for VAIO VGN 23G...
All the VAIO Computers will be shipped with the Recovery partition in the Hard Drive. If the Hard Drive is not completely formatted, you can access the Recovery partition by pressing the F10 key for 5 to 10 seconds when the VAIO logo appears.
If you're able to access the Recovery partition, then select Restore C Drive option to restore the Computer back to the factory settings.
Let me inform you how to check the if Recovery partition is available.
Press windows+R key and type diskmgmt.msc and check if you're able to view EISA partition. If EISA partition is there, then the Recovery partition is available and you can access by pressing the F10 key at start-up.
If the EISA partition is not there, then the partition is deleted, then you can purchase the Recovery Discs for your Computer which may cost $15 to $35.
Jun 22, 2010 | Sony VAIO VGN-N110G/W Notebook
I have one partition named Recovery G: ,size=14.7 GB free=7.75GB. when i hide it using diskpart,on Disk managment it show that this partition have no label and letter,that this partition is healty,eisa...
The recovery G: drive on your computer is an OEM partition. You don't have to do anything on it because it is helpfull. The back up for your OS is on that drive and also the OKR files or the recovery files.
If you delete that drive it void the OKR.
Mar 27, 2010 | Lenovo G550 (2958ACU) PC Notebook
Purchased new laptop Sony Viao Model No -VGN-C2 .I have 80 GB HDD.In that i got 8GB EISA Partition .And rest of the Other Partition is only C: Drive.So when i asked my dealer so he replied me that it is a...
Well there is an array of programs out there that can do this for you. I suggest gparted. If you download the gparted iso and burn it to a disk. You can boot from the disk and then you follow the onscreen instructions. You can divide the partitions in any way you see fit. If you have any questions on using the program you can always contact me and I'd be happy to answer
Nov 27, 2009 | Microsoft Windows Vista Ultimate Edition
How to install window XP on CQ40 laptop .
check your boot setting first in the cmos/bios of your laptop, look for the boot order from there choose your cd/dvd rom as your first boot device then the hard drive 2nd, you will need to this because in order for you to install xp, when you are done save the setting that you have made then restart the machine, insert your windows installation disc, it will prompt you to press any key to boot from the cd rom, from it will check you system config, then just follow the instruction given to you by the installation process read it carefully then it will be easy as 123, windows will guide you thru the installation process and will ask you for the lincense key, just make sure that you use a genuine copy of window if not you wont be able to register your o.s and you wont get the updates from windows
Nov 26, 2009 | Compaq Presario Notebook
Say's it needs to initialize and comes up with eisa.
The EISA partition is a partition that a computer manufacturer places on the disc to assist in recovery of that maker's files. It is not necessary to have this partition if you do not intend to perfrom a factory recovery. I will include a guide below to assist you in a deletion of that partition. To initialize a disc, it can be done ways, boot the computer and it will advise you the disc has not been initialized and will initiate a wizard to assist. I attach the hard drive to another computer using an EIDE/SATA to USB adapter, it will be recognized as an external drive but will not give it a drive letter because it is not initialized. You have to go to the control panel > administrator tools > computer management > disc management. Look in the right lower pane and it will show the drive with a grayed out box to the left, it may label the drive as drive 03 or 04 etc. Right click on the drive number and choose initiate. The computer will initiate the drive and give it a letter. It will also ask you if you want to initiate the drive as a bootable drive, choose yes. Below is the guide to delete that EISA partition so you can use the drive in any laptop you see fit.
EISA Partition Delete
1. Open a command prompt as administrator.
2. Run Diskpart application by typing Diskpart in the command prompt.
3. In the “Diskpart” prompt, enter rescan command and press Enter key to re-scan all partitions, volumes and drives available.
4. Then type in list disk and press Enter key to show all hard disk drive available.
5. Select the disk that contains the partition you want to remove. Normally, with just 1 hard disk, it will be disk 0. So the command will be:
select disk 0
Finish by Enter key.
6. Type list partition and press Enter key to show all available and created partition in the disk selected.
7. Select the partition that wanted to be deleted by using the following command, followed by Enter key:
select partition x
where x is the number of the EISA based recovery partition to be removed and unlocked its space. Be careful with the number of this partition, as wrong number may get data wipes off.
8. Finally, type in delete partition override and press Enter key.
Once the partition has been deleted, exit from Diskpart, and now users can use the much familiar and much easier Disk Management tool in Windows (diskmgmt.msc) to manipulate the freed unallocated partition. Users can create a new volume (partition) with this space, or simply merge it to existing partition by extending the size of the existing partition.
Nov 19, 2009 | Toshiba MK8025GAS 80 GB ATA-100 Hard Drive
I want to replace vista with xp, but When I tried to install os it is booting from cd but it is not recognising harddisk
its because of sata hard disk
you have to download sata driver from the website
and copy in to one floppy
connect floppy in to the computer
during boot from the cd
press f6
select which version
follow installation steps
Nov 01, 2009 | Compaq Presario C700T Notebook
I want to downgrade my desktop acer aspire x1800 vista to xp pro everytime i run set-up it always showing me an error could not proceed,.
Most like ly the hard drive has a Vista recovery partition. That partition has got to be deleted. You'll need to open a command prompt and follow the guide very carefully or irreperable damage could occur.
Here’s the trick to delete and remove the EISA recovery or diagnostic partition in Vista. Before proceeding with the deletion action, make sure that at least a set of Recovery Disc Media has been created. Else, you won’t be able to restore your computer to working and factory default condition when any problem on PC requires reinstallation.
select disk 0
  1. Type list partition and press Enter key to show all available and created partition in the disk selected.
  2. Select the partition that wanted to be deleted by using the following command, followed by Enter key:
select partition x
  1. Finally, type in delete partition override and press Enter key.
Oct 08, 2009 | Computers & Internet
Motherboeard wont detect my ide drive
The HP drive has what is called an EISA partition on it, this partition holds HP information incase of a recovery. It has to be deleted in order for you to use this drive on another computer. If you have an EIDE / SATA to usb adapter you can attach this hard drive to another computer to access it. The adapter can be bought ast a computer retailer, ebay etc. for about 20 bucks. When you get the hard drive attached, look in "My Computer" to nake sure it shows up there and write down the drive letter it gave it. Below is the procedure to delete the EISA partition, follow it closely and you'll be fine. Just make sure that when you are in the command prompt, you DO NOT do anything with Drive 0 that is your main drive on the computer and that is not to be messed with.
select disk 0
select partition x
Oct 02, 2009 | Computers & Internet
How to Create EISA Partition...in Vista Or XP......
You can't. The partition was created by SONY to hold recovery files because so many people lose their installation disks. So SONY created the partition, loaded the special software on it and put options in the menu to use it.
Jan 23, 2009 | Microsoft Windows Vista Ultimate Edition
EISA configuration
I believe that he EISA configured partition is where your computer manufacturers 'Restore System' data is kept so that you can't normally access it and mess it up. You seem to have gone to a lot of trouble to do work around that.
I would be interested to know if you can still restore your system now using the data that you transferred to a different partition?
Nov 01, 2007 | Computers & Internet
Computers & Internet Logo
2,644 people viewed this question
David Payne
David Payne
