Question about JVC GR-D270 Mini DV Digital Camcorder
Play back has black line through it.
Have tried cleaning cassette. It records with sound now but with black lines runnning through it.
  • Anonymous Dec 17, 2007
    My camcorder has horizontal black lines on it when I play a tape. What should I do to correct this?
  • 38 Answers
Cleaning may still be the problem. Try running the cleaning tape until it automatically stops (about 20 seconds). You may do 3 passes before giving up. If you still have a problem, you are going to need a servicer. Make sure you have a known good tape to test playback as the error is in any recent recording after the problem occured. Same heads for both functions. Good luck, magic seadog
Posted on Aug 13, 2007
How do you dub cassette to cassette
Hi
If you have a dual cassette deck, then one deck will only play cassettes,whilst the other will have a record facility as well.
Basically you need to place the original cassette in the play only deck and the target cassette in the record/play deck.
Start the playback in the play only deck and immediately press the record and play buttons together on the record deck. Some decks have high speed dubbing but this varies so much that you will need to consult your manual for this.
Cheers
Apr 09, 2015 | Audio Players & Recorders
Why doi have grey lines across my Sharp camcorder VL z7 when It on play back. Theres sound breakage as well. Can someone tell me why?
Do you get the grey line when you play back incamera ?
Have you transferred the file outside the camcorder ?
If you get the grey line in both, invariably the recording head needs cleaning.
Power on the ViewCam.
Eject the tape.
Use a soft lint free cloth and generally clean the head.
The head of the large metallic cylindrical thing placed slightly titled.
It is right at the bottom of the camera beyond those small posts.
If your finger cannot approach, use a swab with mild spirit/alcohol.
Let it dry a minute and then record a fresh material and try.
Please reply if it helped or not.
May 02, 2014 | Sharp Viewcam VL-Z7U Mini DV Digital...
How can I record a music cassette to a music disc on my Magnavox DVD recorder/ VHS --Model # ZV427MG9
You can't burn a CD-A with the ZV427MG9. The unit will not burn to a CD to play in a CD player.
You may be able to record the audio to a DVD with no video source. Connect your cassette player to the Line In audio ports (L/R) at either the back or front of the unit. Depending on your cassette player, you may need a 3.5 mm M to RCA F/F adapter to connect the RCA audio cable to the cassette player's headphone jack. Do not connect a cable to the video input of the composite input unless you have a video on a camera or something to play back. This means that the recorded video may say "No Signal" or will be black or static. (Note: this may not work with this signal issue.)
Set the unit to record to DVD on L1 or L2, as needed, by pressing Source on your remote. Advance the cassette to where you want to record. Press Rec on the DVD unit and then press Play on your cassette player. If you want to identify tracks, Stop the recording and play back and then press Rec and Play again. You are at risk of having issues with the volume during the recording. Clipping of overly-loud sounds and distortion is possible.
When done, finalize the disc, if desired, to play the disc on other DVD players.
If you want to make an audio CD, you would be better off using a computer and connecting the cassette player to the Line In jack of the computer. You do have to make some adjustments to avoid recording the default Microphone input. Use a program like Audacity or any other audio editing program. Record the signal and divide it into tracks, if needed. Now you can filter out any distortion as well. Then save as a WAV file. Use a different program to burn the WAV files to a CD-A. (This must be burned as a mastered disc; my attempts that worked on an older CD player failed if there were gaps between the tracks. Lots of programs will do this; Roxio Creator is one option.)
The manual for the ZV427MG9 is available here: http://download.p4c.philips.com/files/z/zv427mg9_f7/zv427mg9_f7_dfu_aen.pdf .
I hope this helps.
Dec 31, 2012 | Magnavox Televison & Video
I HAVE PROBLEM IN CONNECTING MY LAP TOP COMPUTER WITH AUDIO VIDEO CASSETTE RECORDER BY DYNEX 3.5mm STEREO AUDIO extension cable
Connect the "audio-output" (LEFT/RIGHT) channels from the A/V cassette-recorder to the "line-in" (LEFT/RIGHT) port on your computer.
Click the Windows START button.
Click All Programs.
Click Accessories.
Click Entertainment.
Click Sound Recorder.
Click Record.
On the A/V unit, press Play.
Now, the Sound Recorder should indicate that it is receiving sound.
May 17, 2010 | Computers & Internet
I have a samsung scd103 digital cam and when i record something it looks good on the screen while im recording it but when i play it back there are grey lines and distorted sound
Have you tried cleaning the recording heads? Use a dry type cassette cleaner only. It's just like a vcr head cleaner tape, only in the small mini-dv tape size.
Sep 30, 2009 | Samsung SC-D103 Mini DV Digital Camcorder
Lines on my JVC mini dv recorder
Please use Mini DV Video head cleaning cassette as it seems video head is dirty / clogged in camera.
Oct 24, 2008 | JVC GR-D295U Mini DV Digital Camcorder
Camcorder
Your camcorder has dirty/ clogged video head, please use good quality video head cleaning cassette.
Rank me if it helps.
Jun 01, 2008 | Video Cameras
No sound on tape
hi , many faults for that 1- have you tried to play an old tape with sound to check that the video plays sound ?? if you have the sound of a previous tape then move to 2- from where you are recording if you are recording from tv rf channels then move to 3 or if you are recording from dve chek the audio connection that are coming from dvd to video and change it 3- the remaining last fault is you have a dirty audio head needs cleaning and if you don't know how to do so go to qualified person and if you are familiour with that open case and clean and if no refer to 5 5- the audio head it is a chrome cube with a black two thins lines in the right of the mechanism near the pinch roller rounded thing that draws the tape to move get a clean cloth and spread alchohol on it and rub the rectangle cube audio head up and down ovewr the two thin black things inside it please don't forget to do excelent rate cause i here to help you regards
May 06, 2007 | Aiwa VX-C131 13 in. Combo
Black lines in play back.
need to have it's tape guide realigned.
Apr 05, 2007 | JVC GR-D270 Mini DV Digital Camcorder
Taping over previously recorded tape
I too had same problems its because your tape head is not clean use a head cleaner cassette and play it, your problem will solve
Nov 19, 2006 | Panasonic NV-GS35 Mini DV Digital...
JVC GR-D270 Mini DV Digital Camcorder Logo
80 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
