Question about JVC GR-D270 Mini DV Digital Camcorder
Black lines in play back.
I have used a cleaning cassette but now it will record but when it plays back it has black lines running through it.
  • Michelle Dungan Apr 19, 2007
    Now i have sent the camera back that is 4 months out of warranty and it is currently being mailed back due to JVC wanting $250 to repair the 'drum'. anyone know anywhere that can fix this cheaper.
    President:
  • 4,402 Answers
Need to have it's tape guide realigned.
Posted on Jan 28, 2008
How can I record a music cassette to a music disc on my Magnavox DVD recorder/ VHS --Model # ZV427MG9
You can't burn a CD-A with the ZV427MG9. The unit will not burn to a CD to play in a CD player.
You may be able to record the audio to a DVD with no video source. Connect your cassette player to the Line In audio ports (L/R) at either the back or front of the unit. Depending on your cassette player, you may need a 3.5 mm M to RCA F/F adapter to connect the RCA audio cable to the cassette player's headphone jack. Do not connect a cable to the video input of the composite input unless you have a video on a camera or something to play back. This means that the recorded video may say "No Signal" or will be black or static. (Note: this may not work with this signal issue.)
Set the unit to record to DVD on L1 or L2, as needed, by pressing Source on your remote. Advance the cassette to where you want to record. Press Rec on the DVD unit and then press Play on your cassette player. If you want to identify tracks, Stop the recording and play back and then press Rec and Play again. You are at risk of having issues with the volume during the recording. Clipping of overly-loud sounds and distortion is possible.
When done, finalize the disc, if desired, to play the disc on other DVD players.
If you want to make an audio CD, you would be better off using a computer and connecting the cassette player to the Line In jack of the computer. You do have to make some adjustments to avoid recording the default Microphone input. Use a program like Audacity or any other audio editing program. Record the signal and divide it into tracks, if needed. Now you can filter out any distortion as well. Then save as a WAV file. Use a different program to burn the WAV files to a CD-A. (This must be burned as a mastered disc; my attempts that worked on an older CD player failed if there were gaps between the tracks. Lots of programs will do this; Roxio Creator is one option.)
The manual for the ZV427MG9 is available here: http://download.p4c.philips.com/files/z/zv427mg9_f7/zv427mg9_f7_dfu_aen.pdf .
I hope this helps.
Dec 31, 2012 | Magnavox Televison & Video
Samsung VP D31 stopped recording video - just black screen
my samsung vpd230 has stoped recording, just a black screen,
would you also explain what a ccp is,also the words memory stick keeps keeps appearing.thankyou
Apr 06, 2010 | Samsung VP-D31 Mini DV Digital Camcorder
Video camera appears to record, but nothing plays
Try to run cleaning tape, it may solve your problem.
Nov 21, 2009 | Cameras
Vcr doesn't record sound. Though it plays back
Needs cleaning. You can either use headcleaner cassette ( not always effective ( If you can find the type with micro-filament brushes they're more expensive but far more effective and last forever ) ) ; or alternatively do it manually ( sometimes neccesary ) ; unplug unit, remove the cover and clean all the surfaces that the tape comes into contact with ( using Q-tips and head cleaning fluid ( most effective ( when done thoroughly ( have to keep at it until absolutely no trace of black carbon comes off on Q-tip ) ) ) .
Oct 15, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
Sony 8mm camcorder will record sound but no video
Since it is playing the tape, the play head is ok. Now recording is done by recording heads so you may have a clogged heads or damaged recording heads. Try to clean the heads with head cleaning tape to see if it would help. 1. remove the tape and leave the door open. 2. using a canned air, blow out any dusts in the tape area. 3. run head cleaning tape for about 10 seconds and no more. 4. try the recording.. If this does not resolve, you may have a damaged or heavy clogged video heads. Take it to nearest video technician for a diagnostic. -James
Mar 28, 2009 | Sony Handycam CCD-TR517 Camcorder
Lines on my JVC mini dv recorder
Please use Mini DV Video head cleaning cassette as it seems video head is dirty / clogged in camera.
Oct 24, 2008 | JVC GR-D295U Mini DV Digital Camcorder
Black or blank screen
your older recordings will only play on a pal monitor / tv ; if the camera video is ok now ? your tape heads may be dirty , wearing out - or both ; try a cleaning tape first but - do not rewind cleaning cassettes , or the old grime will be put back on the cleaned heads and guides ;
Jul 23, 2007 | JVC GR-D73A Digital Camcorder (PAL System)
Display shows a set of black bars
This is a common(ish) problem on the JVC models. In most cases running the cleaning cassette will work. If it does not work the first time try it a second time. Make sure you follow the instructions as provided by the manufacturer for the use of your cassette and any cleaning solutions involved. Use them in conjunction with camera's information.
Jul 17, 2007 | JVC GR-D244 DV Digital Camcorder
Play back has black line through it.
Cleaning may still be the problem. Try running the cleaning tape until it automatically stops (about 20 seconds). You may do 3 passes before giving up. If you still have a problem, you are going to need a servicer. Make sure you have a known good tape to test playback as the error is in any recent recording after the problem occured. Same heads for both functions. Good luck, magic seadog
Apr 19, 2007 | JVC GR-D270 Mini DV Digital Camcorder
JVC GR-D270 Mini DV Digital Camcorder Logo
80 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Roger Goldberger
Roger Goldberger
Level 1 Expert
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
