Question about Nokia N73 Cellular Phone
Low phone memory....cant store anyfing nokia N73
I have tried saving everyfing to mem card.but it doesnt work.tell me kindly anything else which solves this prob permenently.pleaase tell me why this happens?
  • Anonymous Feb 17, 2009
    Please describe the specifics of your problem below. We'll add
    your post as a comment to hasan659's low phone memory....cant store anyfing nokia N73 problem, and notify you when a new solution is offered.
  • 337 Answers
This is normal to all n73, before its too late you must back up all your files: pictures, musics, videos, contacts,etc.
restore it to original setting, or hard format your phone by turning it off and hold press the green or call key, number 3 and asterisk, while holding this turn on your phone,
and also format your memory card on your phone
your phone is good as new again
Posted on Dec 22, 2008
How to remove memory card my n73
The memory card slot for Nokia N73 is located at the bottom of the keypad just above the charger connector.
  1. Before you eject the card, press the power key, and select Remove mem. card. All applications are closed.
  2. When Remove memory card and press 'OK' is displayed, open the door of the memory card slot.
  3. Press the memory card to release it from the slot.
Do not remove the memory card in the middle of an operation when the card is being accessed. Removing the card in the middle of an operation may damage the memory card as well as the device, and data stored on the card may be corrupted.
Jun 29, 2011 | Nokia N73 Cellular Phone
N73 Hangs when Mem card is inserted.
first try to format the memory card through the mobile ...
Sep 22, 2009 | Nokia N73 Cellular Phone
Display of the nokia N73 phone is not work properly when power save screen get up then phone is ok but after restating phone the problem is there
all n73 models have dynamic memory make sure that u r phone memory as well as mem card is above 70% then u r display gets slow&phone too...
Aug 13, 2009 | Nokia N73 Cellular Phone
My nokia n73 shows phone memory is full but nothing is in it
hie dear,
u need to refresh or soft format ur phone memory.
for that pres *#7780# and then the phone code (12345 by default)
it will not harm any of ur messages or the contact saved on ur phone, it will just refresh the memory.
bunty
May 22, 2009 | Nokia N73 Music Edition Smartphone
Memory low
My n73 had all kinds of problems like being really slow or unable to open some programs, screen freezes, and stuff like that. This usually means that the phone memory is full of junk that can't be removed and/or viruses. To completely rid yourself of that problem, try hard formatting the n73.
To format
  1. turn phone off.
  2. hold the following keys WHILE its turning back on: (3 + * + green call key)
  3. do not let go until it asks you about your location
Your phone will gain 44mb back and go back to normal. Phone will respond a lot faster too, as if it were new. Viruses would be deleted as well as other junk stuffed inside.
Important reminder:
If you have anything stored on the phone memory that you woudn't want to delete, such as pictures, videos, or whatever, back it up to your memory card or computer. The format process deletes all stored memory on the phone, but not the memory card.
Aug 19, 2008 | Nokia N73 Cellular Phone
N73 problem
Use only miniSD cards approved by Nokia for use with this device. Nokia utilizes the approved industry standards for memory cards but not all other brands may function correctly or be fully compatible with this device.
Use only compatible miniSD cards with this device. Other memory cards, such as Reduced Size MultiMediaCards, do not fit in the memory card slot and are not compatible with this device. Using an incompatible memory card may damage the memory card as well as the device, and data stored on the incompatible card may be corrupted.
Press menu and select Tools > Memory. You can use a compatible miniSD card as extra storage space and for backing up the information in the device memory.
To back up information from the device memory to a compatible memory card, select Options > Backup phone mem.
To restore information from the compatible memory card to the device memory, select Options > Restore from card.
To eject the memory card, press , and select Remove mem. card.
Important: Do not remove the memory card in the middle of an operation when the card is being accessed.
"I used to be apathetic, but somehow I just lost interest..."
Apr 04, 2008 | Nokia N73 Cellular Phone
Nokia n73
Too many programs, games, themes, music or other odds and ends loaded on the phone. The phone needs a certain amount of internal memory to function.
Solution: delete some of the stuff on your phone.
Dec 30, 2007 | Nokia N73 Cellular Phone
Memory full
Happened to my n73 twice. Format the phone to get rid of junk piled inside the phone memory.
To format:
  1. turn phone off.
Important reminder:
Dec 23, 2007 | Nokia N73 Cellular Phone
N73 HANGING PROBLEM
Try removing your memory card and then using the phone.
If this solves the problem, then might be your phone is unable to deal with the amount of data stored on your memory card.
OR
Remove applications like 'FS caller' and applications that eat resources of your phone.
Dec 01, 2007 | Nokia N73 Cellular Phone
Memory card
Take out the card first from the phone.
Format it using your computer's memory card reader.
Insert it back to the phone.
Go to Menu
Go to Extras
Go to Memory
Go Options
Select Format mem. card.
That should do it. You will be able to use your card again.
Nov 25, 2007 | Nokia 6600
Nokia N73 Cellular Phone Logo
50 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
