Question about Hyundai Computers & Internet
How can i take the bottom stand of my monitor before i mount it t
I want to remove the stand from my moniyor so i can wall mount it
  • 226 Answers
Generally speaking, LCD monitors have a plastic cover that snaps onto the back side which covers the hinge and screws holding the base plate 'post' to the monitor. Remove the cover, and remove the screws. The post that engages the base plate will come off with the hinge intact.
Posted on Dec 21, 2008
Viewsonic monitor manual
Yes. The base stand may be removed. The unit is VESA mount compliant with 4 holes. 100mm x 100mm.
Aug 24, 2014 | ViewSonic VX2025wm 20.1" LCD Monitor
Remove stand from monitor
there will be screws on the back which will allow you to remove the stand, then on the back of the monitor their should be 4 screw holes, use these to attach a a flat plate wall bracket to it.
but if you can't remove the stand, then put a clap speaker bracket on the wall & just clap the base of the monitor, as this type of bracket can be adjusted both in & out & up & down.
Jul 21, 2012 | Acer AL1711 17" LCD Monitor
How do i remove stand from samsung syncmaster 2333 to mount on wall
its a snap-type plug-in stand, just hold the stand firmly and pull the monitor equally upward, then it will snap quickly....... but a proffessional reminder! Before mounting your SyncMaster on a wall, be sure to plug the two (2) stand holes located at the buttom of the monitor. My Samsung SyncMaster 2333HD LCD TV was twice intruded by adult-size lizard, both incident resulted to main power board damaged!!!!
Feb 13, 2011 | Samsung SyncMaster 2333HD 23 in. LCD TV
The stand is secured to the back of the monitor with screws.
Your wall bracket may need modifications if the mounting holes on the monitor.
Dec 04, 2010 | Computers & Internet
Rehow could fix the sreen on wall?
Remove the LCD monitor stand, purchase a wall mounting bracket. There are several types, one is on an articulated arm which allows you to left, right, up and down. Another type mounts flat to the wall with limited up and down adjustment.
You need to check the mounting holes on the wall brackets so it matches the mounting screw holes on the LCD screen.
Nov 26, 2010 | LG 22" FLATRON LCD Monitor
Hi we have samsung lcd 22 inchess.. we need to fix it to wall and there is no backside stand .. how can we get the stand
Most electronic stores sell wall mounting brackets. There are several types. one mounts the LCD screen flat to the wall with a limited range of tilt. Another type mount the LCD screen on an arm that allows tilt and swing movements.
Jul 22, 2010 | Samsung YP-K3 MP3 Player
How do I remove the stand to mount the TV on the
the TV will mount to the wall via the VESA screw mounts on the back of the LCD. If it is a smaller, monitor sized LCD then the screw pattern will be either 75x75mm or 100x100mm. On larger TVs is it usually 100x200mm. Sometimes the base is screwed into this mount and othertimes to the bottom. Simply unscrew it from the screen. Be sure that the wall mounting kit can handle your LCDs VESA screw pattern, screen size and screen weight.
Feb 07, 2010 | Televison & Video
Removing back stand supports
First I am not to sure about the brand you got there, But if it is not wall supportable you do not need to reove anything but by a wall mount that will hold the bottom in place and yes there are wall mounts for this tpye of arrangment see not all flat panels go on walls thus hence you cannot remove the stand easy. Try finding a wall mount the has a L shape to it, it will hold the bottom of the tv and it comes with a little strap to hold it back into securement. Please do not try to remove the stand I would suggest a diffrent wall mount- Rulds2008 TV expert for 20 years
May 14, 2009 | Sampo PME-42S6 42 in. HD-Ready Plasma...
Can not remove the stand to mount it on the wall
If the Aquos 46 is anything like the Aquos 42, the monitor is attached to the base with machine screws (bolts). They are located in the lower back portion of the monitor, probably need an Allen wrench to loosen and remove. Once that is done, the base can be removed from the monitor. Best way is to lay the monitor face down on a tabletop padded with foam, a quilt or blanket, etc to protect the screen as you work. Remove the stand from the monitor, not the monitor from the stand; it is easier and safer that way.
Jan 18, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Tv stand on the wall
It is not made for wall mounting unless it has 4 bolt holes in the back cover. Some wall mounts grip the tv on top and bottom, but they look like hell.
I bought the same Samsung, but took it back.
Dec 28, 2008 | Samsung SyncMaster T200 LCD Monitor
Computers & Internet Logo
544 people viewed this question
Top Hyundai Computers & Internet Experts
 Zackery G
Zackery G
Level 1 Expert
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
