Question about Video Game Consoles & Games
When I switch on my PS3 it says that the hard disk is corrupted and to proceed to press OK. So I pressed OK and it loaded, turned itself off and the system restarted itself. But nothing seems to have happened because everytime the main menu comes up it either doen't load properly and if I click on an icon then the system seems to freeze.
  • 73 Answers
You already have a corrupted hard disk.the best possible solution for that is to replace it with a new hard disk.corrupted hard disk causes the ps3 to freeze bcoz it cannot the load the data that the ps3 needs to boot properly.hope this one solves the problem
Posted on Dec 21, 2008
Could not proceed to boot
To check your hard disk drive if its detected, turn on your computer and press DEL or F2 to enter BIOS setup. Then go to standard cmos setup and there should be the hard drive detected as Primary or Secondary IDE or SATA. If detected and not loading into windows that case your operating system is corrupted. However If your hard drive is not detected on your bios, turn off your computer and unplug and plug your hard disk drive then turn on your computer start pressing again DEL or F2 then check again your hard drive if it is detected.
If your hard disk drive and cd/dvd rom drive are the same cable you can switch the cable to check if the cable of the hard drive are ok. After you have checked and you found out that the two cables are ok that means you will have to format your computer. But you must backup all your data and files before doing so. Formatting your computer will erase or delete the entire space of the partition which you perform formatting.
Here is the video tutorial on how to format your computer using windows xp
Have a nice day.
Apr 05, 2011 | ASUS Computers & Internet
My ps3 is saying the hard disk's file system is corrupted and will be restored......press ok....it loads and then start back to....the hard disk's corrupted......help please?????
mkstreetcrui
If you are getting the corrupted drive message this means that you have corrupted data on your hard drive or there is something wrong with the drive. The link below will help you address the issue and format the drive with your computer if needed.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Dec 17, 2010 | Sony Playstation 3 (PS3) Console
What do i do when it says hard disc system is corrupted on my ps3
Ok try to follow these steps in order to restore your hard disks structure again.
Step 1. Turn the PS3 off into standby mode (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it, then beep again 5 seconds later and then beep once more and turn off. When the console turns off, release the power button.
Step 3. Press and hold the power button again. It will beep when you first press it, then beep 5 seconds later, then there will be 2 quick beeps together. When you hear these 2 quick beeps release the power button.
Step 4. The PS3 will start up asking you to connect a PS3 connector via USB and press the PS button. Do this and then go onto the next step.
Step 5. A menu will then load. Choose option 3 "Restore File System". The PS3 will restart and may report that your hard drive is corrupt, ignore this and click on "OK" to continue. Let the PS3 do its thing and hopefully when it restarts all will be well again.
If this procedure does not work, follow steps 1-4 again but on step 5 choose option 4. If this does not work try again but with option 5.
If none of these procedures work then I am afraid it looks like your hard drive may have become faulty. This will mean you will have to purchase a new one.
I hope this helps and thank you for using FixYa
Aug 20, 2010 | Sony Playstation 3 (PS3) Console
My ps3 has stopped working! It says: "Cannot start. Correct hard disk not found." Please, please, please can you help??? Many thanks, Mark & Michelle
Ouch, Bad news Mark and Michelle. This is a fatal error on the hard drive. Basically, the hard drive needs to be replaced :( Sorry
Aug 12, 2010 | Sony Playstation 3 (PS3) Console
My PS3 says on screen: The hard disks file system is corrupted and will restored. ok Press the PS button to use controller. But when I press x nothing happens
lsn if ur PS3 under warranty then send it to them and they will give u a brand new one, but if not just change the Hard Disk and u can choose any Hard Disk size u want
Jun 02, 2010 | Sony Playstation 3 (PS3) Console
Hard Disk Corrupted
you need to send the ps3 to sony so they can reset the hard drive and format the system
Dec 11, 2009 | Sony Playstation 3 (PS3) Console
Hard disk's file system is corrupted.
Most likely your hard drive is completely corrupted. It could be as simple as a new Hard Drive replacement or as complicated as a motherboard issue.
Check out ccgamingonline.com
They give you free estimates for your broken system.
May 09, 2009 | Sony Playstation 3 (PS3) Console
Hi if you have the ps3 with the model # cechh01 or cechk01 or cechl01 this happen a lot you need to install the new update in a usb memory card and follow the instructions on the ps3 go to sony for instructions on how to download the update in a removable usb if you have the older models you need to format the hard drive or install another one and format the old drive in another ps3 and this can fix your problem
Mar 13, 2009 | Sony Playstation 3 (PS3) Console
Hard disk corrupted
whell hold on to x and d together
Apr 09, 2008 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
89 people viewed this question
Top Video Game Consoles & Games Experts
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
