Question about GE Profile Harmony DPGT750EC Electric Dryer
Good Morning out there, I have a GE front loaded dryer and the dryer was working fine and now it will not get going, The drum will not turn, I opened the door, pressed the light button, turned on the machine and helped the drum along. Is there something stuck in the drum? or is there anything I can do to fix this. My laundry pile is quite high, is it safe to use the dryer with the assistance method?
You don't say how old the unit is or how heavily loaded it is? Check the belt first. You can't adjust the tension, all you can do is replace it.
Posted on Dec 21, 2008
Why will my dryer not start, but makes a clicking sound?
If the motor runs and the drum doesn't turn the belt may be worn or broken...or you may have a faulty idler
Regards,
Dennis
Aug 15, 2014 | GE Dryers
No high heat in dryer
This type of dryer has 2 rows of elements. If one is out then you will not have high heat.
Basically to get into ge dryers your start by popping the top then removing the front. Then the drum comes out.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 05, 2012 | GE Dryers
I have a DBXR453EA dryer which I cannot find on your list. When the dryer is in use it sounds like a bearing might be going bad or t roler is going bad. I tried to open the side up, but I cannot figure...
This dryer uses nylon slides to support the drum in the front. These are very cheap ($5) and not too difficult to replace.
The side panels do not come off on a front-loading GE.
Unplug the dryer.
Remove the screws along the top of the door opening and lift the top upward. Old machines have clips.
Remove the screws on the sides that are about 6" from the floor When these are removed, the panel is loose and may fall, so hold on to it). The front panel (door and all) should be free. You may find it easier to disconnect the wiring to free the panel entirely; be careful not to damage the connectors.
You should now be looking at the drum. Under the drum, in the front, are two little pieces of nylon. These are the slides. If your dryer doesn't have these, it uses a drum support bearing, a large white plastic piece that is about $25.
http://www.repairclinic.com/Drum-Or-Tub-And-Related-Parts?s=t-+DBXR453EA+-%3d%3dc26
Good luck from Detroit, MI.
Jul 11, 2011 | GE DBXR463EDWW Electric Dryer
My GE DBSR453EB1WW electric dryer doesn't turn on. It worked fine yesterday morning for one load and when I put in my second load, it wouldn't start. It is plugged into the outlet and the breaker is fine....
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 15, 2010 | GE DBSR453EBWW Electric Dryer
My dryer squeaks upon starting to dry a load of clothes...everything else works fine except it squeaks the whole entire time. Any advice?
GE dryers have a straight rod in the back center of the drum that goes through the rear bulk head and that is what supports the drum in the rear, it is also what squeaks when it gets warn out , around that short rod that goes into rear bulk head from the drum is a black Teflon plastic sleeve called a barring replace it and that will fix the noise
Apr 05, 2010 | GE DVL223EBWW Electric Dryer
Taking a ge dryer apart to replace worn belt. the dryer works fine with light load but squeeks with medium to heavy load. drying time is fine.
you will need to replace the drum glides near the front of the drum,just behind the door,which will require you to remove the front panel to access the glide unit,there is a gold and a green glide,you will need to get the right one after disassembly
Jan 12, 2010 | GE DWSR483EBWW Electric Dryer
I have a loud squeaking noise from a GE electric dryer drum..
UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
I am not sure what plastic part you have, but there should be no small plastic parts in your dryer drum or at least not the ones I have worked on before.
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine,
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Oct 28, 2009 | GE DBXR463EBWW Electric Dryer
Ge front load dryer model # dsxh436a6ww started to vibrate and make load noise. dryer works and it is not of balance.
Good Luck,
I hope this helps
Oct 24, 2009 | GE Dryers
GE Profile Harmony Dryer Drum will not turn
the inertia switch on the shaft of the drum motor has failed This will require removal of the drum motor
Jun 01, 2009 | GE Profile Harmony DPGT750EC Electric...
Front felt drum seal on ge came off---hard to repair?
Open the dryer door. At the top of the door opening, there should be two screws holding the top of the dryer down. Remove those screws and the top will rotate up, giving you access to the drum.
Nov 19, 2008 | GE DBXR463GB Gas Dryer
GE Profile Harmony DPGT750EC Electric Dryer Logo
118 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
