Microphone Problem I got a microphone with my Technika webcam and when i plug in i tell my computer what i've plugged in and it is alright for about 2 minutes and then it keeps asking me and keeps saying the microphone/headset is connected, disconnected etc etc.
  • 30 Answers
Are you sure that it is making a good connection?
Posted on Jan 05, 2010
I have video and no audio.
Three typical things to look at (as you didn't post brand of webcam).
1. Webcam doesn't support audio - fix this by plugging in a microphone to the sound card (if desktop).
2. Input volume (from microphone) is turned all the way down or muted.
3. If webcam has built in microphone - microphone may be damaged.
Nov 25, 2014 | Computers & Internet
No sound
Webcam Audio Getting sound to broadcast with streaming video using a webcam requires a few components to work in unison. Because most webcams do not have a microphone built in, you will need to buy a microphone for your computer or locate your microphone input if you have one built in (some laptops have these). The audio and video are two separate functions and must be diagnosed as such. b> Webcam Software b> If you have a webcam set up correctly and you are streaming video, then you are already halfway there. This details only how to make the sound work, so please refer to an article related to webcam video if you do not have that working already. The webcam audio and video both communicate with your computer via your webcam's software application. Due to this, you will find that there are settings specific to your webcam software for sound. Because there are various software applications that can act as an interface for your webcam, you will want to do a product-specific search on the Internet for your application's settings. Most often you will find the settings for sounds under Tools or Settings, then choosing Options or Preferences. Regardless of the application that you are using to broadcast your webcam video, you will need to ensure that your microphone is plugged into the "Microphone In" jack on your computer or laptop. The microphone input jack is commonly colored pink. b> Microphone Connection b> With your microphone plugged into the "Microphone In" audio jack, test the audio inside your webcam's software application. Most webcam applications allow you test your microphone by reading a sentence and watching a graph move as you speak. If you see this happening, then you have correctly hooked up your microphone. If you have a Windows PC you should also see if your computer recognizes your microphone by clicking on "Start" > "Settings" > "Control Panel" > "Sounds and Audio Devices." Under the "Audio" tab you will find a section for "Sound Recording." From there you can select or change your "Default Device." b> Hardware Troubleshooting b> In the event that your microphone is not recognized by your computer, continue hardware troubleshooting by contacting your computer's support staff. With a properly connected microphone and some minor adjustments in your webcam's software application, you should be broadcasting audio with your video in no time. Hope this helps.
Jan 22, 2013 | Gear Head Gearhead quick webcampro...
ATR3350 Microphone: Battery in. Plugged into laptop. Recorded video. ATR3350 Mic is ignored. Audio is still recorded from my Logitech Webcam software. How does this thing work?
You need to tell your computer which microphone / sound source to use.
In he absence of other instructions it is defaulting to the built in microphone.
Normally your sound-card software should detect a new device plugged in and ask you to confirm it. However if it is not doing so you may need to change the audio settings.
How to correct this will vary slightly depending on which operating system you are using.
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
Now click the VOLUME button in the SOUND RECORDING BOX. Here you need to SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls). If your webcam/ microphone is built in to the laptop there should also be a volume control called 'Internal MIC' - disable it by placing a check-mark in the mute box.
NOTE if microphone (or internal MIC) is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK.
That should be it but it is possible you may also need to turn off the microphone in the software for your web-cam.
Feb 09, 2011 | Audio Technica ATR3350 Microphone
Can you tell me the plug wiring mike end
It should be standard balanced XLR. The wiring is 1= ground/shield, 2=hot(+ve), 3=cold (-ve). Do not bridge any of the pins especially not 1 and 3 if you are using phantom power with this microphone. Let me know if this helps please.
Nov 19, 2009 | SE Electronics SE2200A Professional...
Want a wiring diagram for 1x3pin xlr plug to 2x3pin xlr female plugs.microphone splitter.
Pin 1= ground/shield, Pin 2= hot(+ve), Pin 3= cold(-ve). Just remember if you make a cord like this you can expect some signal loss.
Oct 12, 2009 | Audio Players & Recorders
Webcam same prob
if the webcam has builtin microphone you must plug in at rear in the red connector
To verify if your webcam has microphone do this:
When you plugged in usb the webcam, also it shoul be a red cable (this is the microphone)
If not, you must buy a microphone
Jul 31, 2009 | Logitech Webcam
Wires in the microphone at the point where you connect to the lead have come appart and i need to solder them back on, Black, red and white wires. Which in which order do i solder them onto the connecter...
There are many standards of microphone connectivity with 3 pin XLR (cannon) style plugs. It depends on where in the world you are as to the favoured standard,
Your microphone usesthe following::
Pin
1 ground (white) 2 +ve or hot (red) 3 -ve or return (black)
Another way to work out what wires connect to what, is to remove the cover of one of your XLR-XLR microphone cables exposing the connections it favours, plug the connector into the mics scoket , and use the connections to the cable guide you in resoldering the connections back on.
The same connections can be veiwed in the user manual here
Please rate this solution. Cheers
regards robotek
Jul 15, 2009 | Behringer XM1800S Professional Microphone
Webcam no sound
Alright, so we know you have sound on your computer because you can hear them when they talk to you. We also know that there is an issue with the microphone side of things because when you record something you hear nothing.
Please go to Control Panel/Sounds & Audio Devices/Audio Tab.
Tell me if what you have under Default Device and Sound Recording Device are the same or if they're different. They should be the same. Let me know the results.
Dec 30, 2008 | Logitech QuickCam Communicate STX Personal...
Audio problem with my webcam
what make, model, motherboard, and sound card are you using on your computer. I understand your desire to know why the system would not be working otherwise.. What kind of microphone other then the headset are you using and do you have every reason to believe said microphone is a good mic?
Jan 28, 2008 | Philips SPC 900NC Webcam
Computers & Internet Logo
154 people viewed this question
David Payne
David Payne
