Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Freezer not cold enough.
I can hear the compressor humm but the freezer fan seems to not be working.  Freezer not cold enough to make ice.  Help!
-ricardo
  • Anonymous Dec 27, 2008
    fan runs don't hear compressor kick in
  • 306 Answers
If you don't hear a fan in the freezer compartment when you open the door then that is the problem. Just take off the inside panel that covers the fan and remove the fan. Save the fan blades it just press's on so gently remove the fan blades and go to parts house and get new fan. Take the old fan with you to make sure you get the right one. let me know how it goes okay. ken
Posted on Dec 21, 2008
Freezer is not staying cold. The freezer is on but its not staying cold enough to keep the food frozen. The Ice maker switch is turned on but ice is still melting. Turned the control to coldest but still...
Sounds like the evap. fan motor is not turning. What is the freezer temp. have you measured it ? What about the fresh food section, (fridge compartment).
Anyway, try this. Hold the door switch in the closed position with the freezer door ajar and see/listen for the fan coming on. If you can't be sure, the best way to do this is to first turn the thermostat all the way to the "off" postion, and with the freezer door ajar and holding the door sw. closed (pushed in). turn the thermostat back on. (you may need to turn off then back on first if your arms aren't long enough) You should hear the fan motor start.
NOTE; you may hear the compressor overload "click" off if trying to start it right after shutting down, this is normal (under short cycles or manual restarts). You may also hear the condensor fan motor run (under the fridge by compressor) this too is normal. try to indentify the freezer fan (evaporater fan motor) running or not.
good luck.
Sep 24, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Problems with Whirlpool 21.0 cu. ft.
checklist: freezer fan running, compressor fan running, compressor running, any frost buildup on back wall of freezer. you may have to take a rag and touch the compressor to feel if its vibrating to see if its running unless you can hear it. please reply
Jun 12, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer isn't staying cold
What is the solution? What can we do to engage the refrig. again?
Mar 31, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Freezer Working Intermittently; Fridge not as cold as should be
the model number you sent didn't come up,i sounds like you could have an inefficient compressor or a freon leak.when you checked the compressor was the condenser fan motor running?this is what keeps the compressor cool also clean the condenser coil too.another thing is that if you have a timer on your machine it could be sticking,if you send the model number i can tell you where it is,also if you remove the back inside wall of the freezer,look at the evaporator coil,the frost on the coil should be the same over the whole coil,if it isn't you have a sealed system problem and will need to replace the machine.if things are cold in freezer but not cold enough this is what it sounds like,do this,open the freezer door,you should hear the fan blowing,if not the evap fan motor is bad or it could be in defrost,if you don't hear the fan blowing wait around a half hour and check it again, it could be in defrost mode so the fan won't turn on until it comes out of defrost,also like i said make sure the condenser fan motor is blowing and the condenser coil is clean,if everything checks good and the freezer is cold but not cold enough and the best thing to check is the ice cream get a new machine,you have a sealed system problem.let me know what you find and good luck
Jan 05, 2009 | Kenmore 65812
Bottom of freezer/fridge only getting cold.
Thre is a fan inside the freezer which circulates the cold air around both the fridge and the freezer compartments.
You should be able to feel cold air blowing around the inside, particularly at the top of the freezer.
If the defrost thermostat fails open, the internal fan (depending on freezer) will stop and this can be the cause of the freezer being warm at the top and no ice.
You say the bottom of the freezer is blowing cold, but are you sure its blowing, as it can feel like a cold blow. Of course the fan could have failed or may be the defrost heater itself.
Have a look at this site for some useful trouble shooting
And a good site for troubleshooting and general info
Refrigeration Help Section, Fridges, refrigerators, not cold enough, frost free problems and how to test, noisy fan motors, clicking on and off compressors, door gaskets
Nige
Sep 26, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Hotpoint FFA70 Freezer High Temp
sum fans only kick on if cold enough
if the whole evap is frosted up u have a defrost problem
if frost is only partial u need to throw it out cause it either has a bad compressor or freon leak
check your fan by compressor and make sure coil isnt filthy too
Jul 08, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Freezer not freezing on m,aytag mfd2560hes
hi andy, based on your story, i think the humming sound is coming from the compressor trying to start and the clicking sound is when the overload trips and make that clicking sound to turn off the compressor but it does resets itself so it would humm again after a few minutes and tripps off again..try to unplug the unit for a day to cool off the compressr and then plug it back. if it will happen again, you need to replace the compressor. i hope i was able to help..
Jul 07, 2008 | Maytag MFD2560HES Bottom Freezer French...
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 29, 2008 | Amana ARB2205C Bottom Freezer Refrigerator
Freezer fine /After power went out twice fridge not cold enough
In back of the refrigerator is a removable panel behind which is the compressor. Listen for a hum and a click. If you hear those sounds the compressor may have failed. Behind that same panel is a condenser where heat is removed from the refrigerating system. Make sure it is clean and check that the fan operates when the compressor runs.
Jun 07, 2008 | GE Â 17.9 Cu. Ft. Top-Freezer...
Refrigerator doesnt sem to be working right
Ice maker will not work if temp in freezer is not cold enough to keep activated
Things to check
Check freezer...
for Frost build up and if Fan is blowing,
Check condenser...
To make sure clean, and the fan is blowing by compressor & IF it is running
Check Recirclating Vents in refrigerator... to make sure theres no blockage,
CONTROLS ...should be in the middle setting
Oct 08, 2007 | GE Profile PSI23NCR Side by Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
69 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
