Question about Holmes Products HM4600-U 11 Gallon Humidifier
Need Manual for Holmes Humidifier HM4600
Can not figure out how to use
    Problem Solver:
  • 7 Answers
Because no one else posted the site, heres the pdf
http://www.appliancefactoryparts.com/content/pdfs/116674.pdf
Posted on May 17, 2010
I just found booklet in my file
Posted on Jan 17, 2009
Found booklet on internet
Posted on Dec 22, 2008
What happens if the humidifier runs out of water? Humidifier is new and working fine. I Does the humidifier shut off automatically when it runs out of water?
The humidifier has a float valve in it much like a toilet tank does. If the water gets to low, the float valve should allow more water to enter the tank automatically. When it reaches the proper level, the float valve stops the water. The water line (either copper or plastic) coming into the humidifier should have a shutoff valve on it. Make sure that it is turned on.
Feb 02, 2011 | Holmes Products HM4600-U 11 Gallon...
Need new rubber tank gasket for Holmes humidifier Model HM4600
after scouring the INTERNET AND FINDING PLENTY OF SITES THAT WOULD SELL ME THE WHOLE CAP FOR 24.00. I MAD MINE USING SOMETHING FROM ace hardware THAT COST 2.50 Small suction cups with the hook [CDBL-7500S11] PART NUMBER 7500 .CAN BE MODIFIED INTO MAKING YOUR OWN GASKET. IT WORKED FOR ME ..REMOVE HOOK FROM SMALL SUCTION CUP. cut off nib with sharp pair of scissors. THEN DRILL HOLE THROUGH CENTER OF CUP WITH 7/64 DRILL BIT. re insert plunger part of cap through cap with spring and re- attach suction cup instead of gasket. MINE WORKS FINE ON A HOLMES 3700
woodinvirginia
Jan 23, 2011 | Holmes Products HM4600-U 11 Gallon...
Have been looking for just one of the tanks as the rubber stopper rotted away. Do you know where I could just buy one tank?
you check at local hardware stores. or if your in canada check with canadian tire. if nobody has it locally. you might have to call the manufacturer to order it directly from them.
Aug 17, 2009 | Holmes Products HM4600-U 11 Gallon...
Holmes HM4600 Humidifier LEAKING - - HELP
well since you just purchased this item, you should be able to return it for exchange, and it should still be under warranty, but if thats not doable, then it sounds to me like its a O-ring that is bad if the tanks are removable, best bet though is to exchange it, look at your home owners paperwork, to see about the warranty, more than likely your covered, hope that helped,
mr.grzz
Jan 20, 2009 | Holmes Products HM4600-U 11 Gallon...
Need a manual for Holmes Model HM5601.
I have a manual for the Holmes Model HM5601. If you contact me I can make a copy & mail
it to you.
My email is jadamson7@cogeco.ca
Dave
Dec 10, 2008 | Holmes Products HM5601-UC 1.8 Gallon...
Holmes HM4600HD humidifier tank
Mine dried out too. I could not find where to get the rubber valve seal for the tanks. Holmes does not list the part and when I called the rep told me they didid not stock the part. I solved my problem by purchasing thin rubber washers from Lowe's. They are 3/16 X 1 1/4 X 1/16 thick. The 3/16 hole in the center "snaps" on over the end of the plastic plunger just like the original. I had to trim the outside diameter with scissors to about 1" or using the old ones as a guide. Cost me $0.67
Nov 09, 2008 | Holmes Products HM4600-U 11 Gallon...
Waters tanks never empty
Either you have no wick/filters or they are installed incorrectly. Tanks should empty within hours.
Mar 01, 2008 | Holmes Products HM4600-U 11 Gallon...
Holmes Products HM4600-U 11 Gallon Humidifier Logo
1,809 people viewed this question
Top Holmes Products Humidifiers Experts
cwradio73
ray gallant
Ben Eng
Level 1 Expert
Are you a Holmes Products Humidifier Expert? Answer questions, earn points and help others
