Bosch washing machine
Even when off the washing machine very slowly fills up and leaks from front door if left open
  • xj900f Dec 23, 2008
    thankyou that's done the trick (it only has a cold feed) and new valve fxed it much appreciation Merry xmas
  • Washing Mach... Master
  • 3,463 Answers
You have a sticking water inlet valve, which is slowly letting water enter m/c.
If it is a hot and cold fill m/c, what you need to do is turn either the hot or cold tap off to the m/c, and see if the problem continues, if say you turn the hot off and it still comes into the washer, then you have sticking cold valve, replace with new one. if after turning cold off, and it still fills, then you need new hot valve fitting.
If it is a cold fill m/c only, then simply replace the cold inlet valve.
Problem solved.
Plz rate my solution.
Thanks.
Posted on Dec 23, 2008
PCB isnt locking the door, what relay or other part is in charge of sending the signal to the door ?
Washing Machine Fault Diagnosis - How to repair
www.how-to-repair.com > Home > Washing machines
Nov 11, 2014 - Washing machine leaks from the front (see video tutorial on this) ... I have a Bosch washing machine which is leaking from underneath and the water ... It did work with no load in the drum on a 30 wash. ... Hi cecilia this is not enouth info on this fault but i would start with door lock and checking wiring to pcb.
Bosch Washing Machine Parts - RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Bosch-Washing-Machine-Parts
Huge selection of Bosch Washing Machine parts in stock. Same day ... Door Boot Seal - Part # 1388885 Mfg Part # 00667489 · Skill Level: .... Front door sleeve.
Bosch Logixx WAS28440AU - ProductReview.com.au
www.productreview.com.au > ... > Front Loaders > Bosch
Rating: 3.4 - ‎74 votes
3.4 out of 5 stars for Bosch Logixx WAS28440AU in Front Loading Washing Machines. ... I've been quoted $895 to replace the PCB board plus technicians time plus have .... We're sorry to hear that you're having issues with the door locking on yourBosch WAS28440AU Washing Machine and .... This isn't limited to Bosch.
Jan 12, 2016 | Bosch Logixx WAS2446 Front Load Washer
Bosch avantixx front loader leaking underneath machine? machine only 2 years old
  • You will find a small door on the front bottom of the washing machine.
  • Open it.
  • Unscrew the filter and rinse it with running water.
  • Put it back in place and repeat the above steps in reverse order.
This should solve your leakage problem.
Aug 03, 2014 | Bosch Washing Machines
Bosch 500 series wfmc3301 bosch washer does not stop running the water during a cycle . even will do it with the spin and drain cycle. Even attempting to turn the washer off it will still run and then once...
You have a bad water supply valve which is struck in the on position-this valve is mounted inside the machine right where you attach the supply hoses-cheers Denny
Oct 24, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
My washer is not draining and has slowly filled with water
im not an expert but it might be a leak or somethings backing up or there could be a blockedge in the drain.
Apr 27, 2009 | Kenmore Washing Machines
Bosch Axxis WFL 2060 washer leaks
Hi. Check the doorseal by lifting the folded lip which faces toward the drum opening. Use a torch and carefully examine the doorseal. It may have a small hole which is hard to see at first.
If door seal is ok remove top of machine and check inlet valve. Turn power off and with your hand examine the inlet water valve. If it feels damp on the solenoid then it leaks from there and finds its way around to the front of the machine though the frame work. This leak happens due to to much water pressure at your laundry taps. If so install a pressure reducing valve before the water inlet hose and replace the water inlet valve in the machine as it is now faulty.
0417362396 Melbourne metro area
Regards Sam
Mar 08, 2009 | Bosch Axxis WFL 2060 Front Load Washer
500 WFMC3301 Bosch Front Loader
The door for this model of washing machine cannot be changed to open from the left.
Jul 07, 2008 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Water filling while door is open
if water is constanty dribbling into the machine then there is a leaking water valve on the machine, if not leaking in all the time then exessive water pressure at some time, dont thing it is the control
Apr 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bosch dishwasher is permanently draining even when the door is open. The draining usually does not stop, but on the occasions it does the wash cycle only last a few minutes before it draining again.
THERE IS A FLOAT WITH A RED SHAFT /LEFT SIDE AS YOU LOOK INTO THE BOTTOM OF MACHINE. AFTER TAKING OFF KICK PLATE. IT IS GOING TO DRAIN IF THERE IS A LEAK FROM PUMP OR HOSES FILLING UP THE PLASTIC BOTTOM OG MACHINE . KEEPS A LEAK FROM GOING ONTO YOUR FLOOR.. . MY GUESS IS YOU HAVE A LEAK DOWNTHERE AND NEED SERVICE.
Feb 27, 2008 | Dishwashers
Bosch nexxt washer is leaking from underneath
I found out why mine leaks. In the Bosh design there is a trap molded into the soap dispenser plastic tray. This tray or trap has a wide open path to the inside of the washing machine. We are using the tide pods as a detergent. Two things are going on here. This trap fills up with water immediately when water is cycled into the machine. The second thing is the pods partially dissolve and leave a gunk that blocks the water pathway to the drum. This blockage eventually allows water to pass however when the pressure is high and this blockage is restricting the water level rises and the trap dumps out into the washer panels. This water immediately leaks down and out the bottom. Observation when I disassembled the machine the trap was moldy and stinky. Water stains were running down the inside. Maybe the engineers at Bosch should look into this.
Feb 05, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines slowly fills with water over a few days
could be leaking inlet valve or if drain is plkumbed in unbder sink, could be filling thro drain pipe when you emptyt sink
Mar 17, 2007 | AEG Lavamat 16810 Front Load Washer/Dryer
Washing Machines Logo
Top Washing Machines Experts
