Question about Dishwashers
GE Mod # GSD22360Z04WW will not drain water. I manually pushed the solenoid down and the pump and motor seemed to run. No water pumped out of the hose that was disconnected from the garbage disposer. I have discovered that the plug for the disposer was not taken out where the dishwasher hose attached. The dish washer stopped working after a new disposer was installed. I rotated the control knob and at no time did the solenoid for the pump operate. It went back to normal position after control knob was turned to the off position. Where should I go from here to fix the problem.
5 Suggested Answers
  • 11 Answers
SOURCE: Bosch SHU4300 Water Fill Issue.
Similar problem for us turned out to be water accumulating in the tray which set off the float switch.  I vacuumed the water out and function returned to normal.  However, we are now facing a repairman's assertion the clay in our well clogged the water inlet systems necessitating $285 in repair parts and labor.
Posted on Oct 13, 2007
jsrock516
  • 5911 Answers
SOURCE: How to knock out garbage disposal plug
Turn off the power source to the garbage disposal. Take the drain hose from the dishwasher off the connector going to the disposal (if connected). Insert a flat blade screwdriver in the drain hose fitting and tap a few times with a hammer. The plastic plug will pop off inside the garbage disposal. Reach inside from the top of the disposal to retrieve the plastic plug. Sometimes you have to use a little force to tap the plug out. Hope this helps you.
Posted on Apr 08, 2008
Loringh
  • 185 Answers
SOURCE: garbage disposal (water won't drain out of sink standing water)
There should be an overload button somewhere on the bottom of the disposal motor. This is to prevent the motor from trying to run if the chopping blades are jammed, otherwise the motor would burn up.
First, try to move the blades with something like a broom handle. Using a flashlight you should be able to see the blades. there's probably three of them. try to make sure each one can move even a little bit.
Next, with the disposal switch in the off position, find the overload button and push it in, Then turn on the disposal switch and see if it runs. If the overload button trips off again, repeat the above steps until the blades can turn.
Let me know how this goes. Loringh
Posted on Nov 08, 2008
  • 13 Answers
SOURCE: dish washer does not pump out water after rinse or wash
Check flap valve and solenoid-Check for hose kinks or food clogs-Check pump impeller for damage-Check-timer Check the (check-valve flapper) some models have a check valve located where the drain hose attaches to the dishwasher.If you just installed an garbage disposal check the knock-out plug at the connection.Check that the pump hasnt gotton stuck due to lack of use or gunk in the pump. 3 things 1-You can remove the lower kick panel and turn the fan blade on the motor until it turns freely 2- Boil a big pot of water and pour it into the tub part let it stand for 15 to 20 min then try the dishwasher 3- Or my (FAV) duct tape your shop-vac to the waste hose and try to blow or **** out the stoppage. Rice is a big problem and pasta for dishwashers and thanks for the advice on my car I will try the method,and sorry about the comment
Posted on Nov 23, 2008
My GE Evolution Max dishwasher is not draining. Water stays in after a normal cycle. Can I empty it manually?
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them. Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water. Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing. Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it. Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced. Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced. Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Jan 29, 2010 | Dishwashers
Ge quietpower 3 wont turn on
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer or Control Board
Replace if defective (note: uncommon problem).
Aug 05, 2009 | General Electric Adora GHDA670N Built-in...
Ge gsd5620 dishwasher
Hi. There are several possible causes, let me explain:
Drain line/air gap
Pump
Belt
Motor
Timer
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Jul 28, 2009 | GE GSD5620DBB Dishwasher
Ge Profile stopped draining
The water doesn't drain from the machine
Drain line/air gap
Pump
Belt
Motor
Timer
Drain line/air gap
Pump
Belt
Motor
Timer
sorry to say but there is no images now... i'll try to find some for you.
good luck
thanks
Jul 07, 2009 | GE 24 in. Profile PDW7800 Built-in...
Ge dishwasher will not drain fully anymore i have cleaned all traps and motor/pump could it be something in the pump? what else could it be?
Hi
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 18, 2009 | Dishwashers
Dishwasher runs for very long time, doesn't clean well and won't drain completely
Drain line/air gap
Pump
Belt
Motor
Timer
Drain line/air gap
Pump
Belt
Motor
Timer
Good Luck!!!
May 06, 2009 | Dishwashers
Water doesn't drain. Lines not plugged, solenoid: OK ge dishwasher/ model no. gsd4920z02bb
Hi
If the water doesn't drain from your dishwasher, check these: Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Thanks
Rylee
Apr 26, 2009 | GE Dishwashers
My ge Profile dishwasher will not drain
HI. check the following areas for fualts.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Replace if defective (note: uncommon problem).....
Feb 08, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE Profile Dishwasher not draining
HI,
Jul 29, 2008 | GE Profile PDW8400J Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
Mike
Marvin
Marvin
