Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Noisy dryer dryer has loud "clunking" sound at start & stop of cycle. any ideas about belts/bearing/pulley probs? dryer also feels like it has resistance when i spin it by hand. thanks
  • Hilltop108 Dec 24, 2007
    I have this same problem, only now it's making the sound pretty much throughout the drying cycle and it takes forever for a load to dry. If it's the wheel, where do I get one and is it easy to change out? Thanks for your help. g
    Problem Solver:
  • 15 Answers
Don't turn the tub to much this may make the belt run off track . If the machine makes a rumble at the beginning and at the end or when u stop the machine and restart it it is probably the blower wheel,it is made of plastic ans wears out on the motor shaft.
Posted on Oct 11, 2007
How to stop dryer from making loud noises and tumbler from hitting inside walls
A dryer kit contains the wheels that the drum turns on, new glides, to keep the drum in place, and a tension pulley for the belt. You may also need a rear bearing. I'd say about $60 in parts and an hour or two & you'd be good to go.
Dec 04, 2015 | Dryers
I simply turned the drum and loud clunk. Now when I push start it clicks and won't start. Everything looks normal. Lights on
Sounds like the belt rolled off the dryer's tension pulley and now the belt switch is open not allowing power to get to the motor. What is your dryer's model number?
  • not all dryers have a belt switch, but many do.
  • I linked a guide below that will show how to reinstall the belt if you can get to it.
  • With the model number I may be able to link you a video of how to get to the belt.
Dryer Belt Pulley Installation
Jun 17, 2015 | Whirlpool Dryers
What is cause of loud vibration noise
In most cases, vibration sounds come from which ever helps the drum to spin with no resistance, In most cases those would be drum support wheels or bearings depending on the model.
In some rare cases, blower or belt pulley could also cause similar symptoms.
Feb 11, 2015 | Dryers
I have wh Holden statesman that recently just started playing up when I'm at a standstill at the lights I feel the car like it's going to die out then when I begin to drive it starts making clanking n
if its loud knocking noise at idle from front area of motor possibly crank pulley has separated from rubber.
when motor is not running can you grab the serpentine belt and move it along rotate it from left to right side of vehicle until it clunks to a stop which is the saftey lugs on the inside of the crank pulley, turning the pulleys?
if so the crank shaft balancer needs replacing
if you cant turn belt over by hand its ok and could be an internal motor issue, big end or camshaft bearing failure were the other common faults
Mar 29, 2014 | 1999 Holden VT
Belt slipping off
did it sound loud on spin if it did
check your bearing as they may be worn and need replacing
or your pulley may be damaged
Jan 11, 2014 | AEG Lavamat 74640 Front Load Washer
The dryer made a clunk sound and the tumbler stop rotating
Sounds like you belt has either broke or came off. If you were rotating the drum by hand in the counter clockwise direction when it clunked, there is a pulley kit to fix that problem. If it was just running when it clunked the belt probably just broke. Hope that helps
Aug 29, 2011 | Samsung DV448AEE Electric Dryer
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Kelly
Mar 04, 2010 | Whirlpool LER5636P Electric Dryer
KENMORE DRYER
Hello ENRIGHT11 Welcome to Fixya
My name is Huum,
You said,
DRYER MAKES VERY LOUD NOISE WHEN RUNNING. ALTHOUGH IT HEATS UP AND BEGINS TO DRY, IT STOPS RUNNING COMPLETELY AFTER ABOUT 5 MINUTES. IF YOU WAIT AN HOUR, YOU CAN START IT AGAIN, BUT IT AGAIN SOUNDS VERY LOUD (ALMOST A RATTLING SOUND) AND THEN SHUTS OFF AFTER 5 MINUTES
Faulty Blower Wheel
If you hear a great deal of noise coming from the blower area of the dryer when it is running, then the blower wheel could be defective.
The are many different designs for blower wheels and just as many unique failure modes. Vanes (fins) can break off the wheel and bounce around in the blower breaking more pieces. The blower can break around the coupler with the shaft. This can cause the blower to spin loosely on the shaft. The blower can form cracks which cause it to vibrate, etc.
You should also not be surprised to find foreign debris in the blower. The occasional bird, rodent or squirrel has been known to bypass the out vent cover. If they crawl into the exhaust tube the first thing they come into contact with is the blower wheel.
If the blower wheel is not spinning, or if it is missing vanes, it is not moving air efficiently. As a result, heat is not removed from the heat source and it can trip the high limit switch or blow the thermal cut-off.
Worn Belt
A worn belt can stretch and/or become brittle with age. The belt can then slip on the drum or motor to cause squeaking. If this is the case, the solution is to replace the worn belt.
The belt is not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, worn drum glides or worn drum rollers depending on brand and style.
When replacing the Belt is is a good idea to also change the Drum Support Rollers, Drum Glides, Idler Pulley and Clips. All of these items are economical easily changeable when replacing the belt. The upside is that your dryer will operate like new.
Recent Customer Symptoms:
Dryer makes loud noise when turned on. Dryer works and heats up OK but makes too much noise.
Worn Drum Glides
Some dryer models are equipped with Drum Glides. The front of the dryer rests on these glides. They provide a low friction surface on which the drum spins. After time however, this glides wear down. Much like an automobile brakes, these glides make a load grinding noise when they wear thin. This griding against the drum usually leaves a bare metal stripe that is visible at the point of contact. If the glides are worn, the solution is to replace them.
The drum glides not the only items that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, a worn belt or worn drum rollers depending on brand and style.
When replacing the Drum Glides it is a good idea to also change the Drum Support Rollers, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new.
Worn Rear Drum Bearing
Some dryer models are equiped with a Rear Drum Bearing. The rear of the drum rests on this bearing. It provides a low friction surface on which the drum spins. After time however, this bearing will wear down. If the bearing is worn, the solution is to replace it.
The rear drum bearing not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum glides, a worn belt or worn drum rollers depending on brand and style.
When replacing the rear drum bearing it is a good idea to also change the drum glides, drum support rollers, drum belt, idler pulley and clips depending on make and model. All of these items are economical and easily changeable when replacing the rear drum bearing. The upside is that your dryer will operate like new.
Worn Drum Support Rollers
Some dryers such as Whirlpool/Kenmore brands are equipped with Rear Drum Support Rollers. The weight of the dryer drum rests on these rollers. They provide a low friction surface on which the drum spins when in operation. After time however, these rollers wear down. When they wear, often times they begin to elongate and form a non-round 'cam' shape. The result is that when the dryer is turned on it creates a rumble that sounds as though you are trying to dry a pair of tennis shoes. This sound is usually the drum being forced up and down on the non-round wheels. If the rollers are worn, the solution is to replace them.
When replacing the Drum Rollers it is a good idea to also change the Front Drum Glides, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new. Whirlpool
Kenmore models have a dryer maintenance kit that contains all of these items in a single kit.
Thank You For trusting us with your question
Please remember to leave a
solved rating before you leave!
Jan 21, 2009 | Kenmore 63942 Dryer
Loud noise when dryer runs
Two items on two different dryers can make this noise. One is the belt tensioner pulley and the other is the bearing on a Frigidaire dryer.
Sep 27, 2008 | Dryers
Makes clunking sounds & throws belt off pulley.
I think you have the answer. I suspect it will be the bearings that have seized up. Or possibly the spyder / drum axle broken
Oct 19, 2007 | Frigidaire GLTF1670A Front Load Washer
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
109 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
