Question about Kenmore 62602 Electric Dryer
Well I turned my dryer off and then when i went to turn it back on it wouldnt do anything, no humming no nothing now when i hit the start button it did seem like it made a click noise? but then it would do nothing. Do you kow what my problem could be?
  • kstorm Dec 21, 2008
    I have the same issue. I have checked the door, checked the breaker, emptied the lint trap, checked the dryer vent, unplugged and plugged it back in, etc... but still no luck! Any other ideas? I am not sure if mine is the same model (I couldn't find the model number) but it is the Kenmore Elite electric.
    Thanks,
    Kathy
    Sergeant:
  • 359 Answers
Check the door switch and make sure you have power to the dryer , make sure nothing is fouling door or door switch
Posted on Dec 21, 2008
Dryer hit start button and it hums
sounds like a motor is going bad or you have a sock in the blower fan but if it was a sock, it wouldn't work at all
Feb 12, 2013 | LG Dryers
I have a whirlpool dryer model # LEP6848AW0 and when you hit the start button it just hums like something is binding. Open the door and hold switch in and hit start button it hums and you spin the the drum...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 16, 2010 | Whirlpool Dryers
Press the start button on dryer, it hums but wont turn. With 2 people pressed the start button again, held the door switch, reached in turned the drum, it hummed stopped humming then no more nothing....
Sounds like a weak motor. You'll have to get a new motor installed. They are fairly inexpensive and easy to install yourself on that type of machine if you are handy. Motor is located in the bottom right of the machine, attached to the drum belt through a small pulley underneath the drum next to the motor.
Dec 27, 2009 | Dryers
I have a Kenmore dryer model no. 1109282610. When
the motor is humming,could be something stuck in blower wheel,might of had lint filter out and ran dryer and something went down into blower wheel,the belt could be locked up or the motor is bad,take the belt off of motor and see if motor spins
Nov 02, 2009 | Kenmore Dryers
Push the start button but nothing happens
check thermal fuse inside back of dryer usually little white fuse unplug and ohm out should ge a reading if good
Aug 09, 2009 | Whirlpool Dryers
When start button is pushed, hums but does not run. Drum does not turn. Belt is okay
It sounds like it is the motor or a stuck/obstructed blower wheel. You can start by opening the door, push the door switch in, hit the start button & see if you can turn the drum clockwise by hand. This might get it going. if the drum does not move by hand then the problem is probably within the blower. post your findings for a follow up
May 01, 2009 | Dryers
Drum wont turn
yes the start whinding shot,,,replace motor..
Jan 25, 2009 | Whirlpool LER5636P Electric Dryer
Dryer want start
You need to provide model details to get step by step instruction to remove the back cover off.
Jan 08, 2009 | Dryers
Kenmore 62602 Electric Dryer Logo
53 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
