Question about Canon PIXMA MP960 All-In-One InkJet Printer
Incorrect color matching
Using the MP960, I have been experiencing incorrect color matching from the computer to the printer as well as from an SD card in the printer.  The color in heavy on Magenta.  I have tried the head nozzle check pattern and have good results, but the photo glossy paper (4X6) shows poor color representation.  I have changed out the photo magenta and the yellow cartridges and use either Canon original or Carrot ink ones.  Any suggestions???  Would the print head be bad, and if it is, is it easy for me to change out the print head?  (the machine is 2 years old and has never been worked on)
Chuck Gibbs
  • 92 Answers
Maybe problem with waste ink tank....
When waste ink tank full it gives this kind of problem. Replace the waste ink tank..or visit nearest canon dealers or service provider.. they solve u r problem by replacing waste ink tank.
or
Look slike your printer firmware is damadged...
Contact your local resseler/ tech to update it if possible.
Best Regards.
If it helps, please rate me.
Posted on Jun 25, 2009
  • 92 Answers
Probably its print head, it is you that changes its like the ink cartridge .
Posted on Dec 30, 2008
My Konica-Minolta-Bizhub-C350-Color-Copier-Printer paper keeps jamming, why?
well could be several reason incorrect paper size incorrect paper weight are you running Thick 1 or Thick 2 to paper. Do you know how to read paper weight? on out side of the paper package is words 20lb or 36lb mite also see the something like 75 g/m2 that is the weight of paper in the metric world (Every one else except the GOOD OLD USA.:):):) we use the lb. system . select paper on the control panel and make sure the paper weight matches most paper copy are putting both lb. and metric but if it is only metric then use the control panel to figure it as you select the thick 1 or 2 you will see the g/m2 on the control panel, if you using paper off the shelve and don't know then call the company where you get the paper from and ask them. Are using the bypass tray make sure that you follow the icon on the screen when it says load paper in the by pass tray does the little icon show portrait or landscape. if you using legal size paper did you pull out the extention tray to allow additional sensor to come into play for the longer paper. Does you print properties on the computer screen match what is in the draws? IF the paper come wrapped an only has lb. # then you will not find it on the control panel you need to get your operation manual out in that manual will be a chart that show what lb. # equals what thick 1 or thick 2.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 05, 2012 | Minolta C350 Printer
Right Cartridge Incorrect on Lexmark 5400
Hi
Here are a few possibilities...
1. Try cleaning the contacts on the inkjet cartridge and where they make contact inside the printer. (use cotton wool and Alchol) if that does not work...
2. Pull out power cable from printer wait 1 MINUTE then insert cable and switch back on again. (some printers reset to factory settings)
3. Remove printer cable from computer... Uninstall Printer driver from computer... Switch off both printer and computer. Wait 1 minute... Reconnect cables and switch on printer and computer... Allow computer to find printer reinstall driver.
4. Try installing old cartridge to see if printer rejects that?
5. You may have a faulty inkjet cartridge (return it to store if so)
Good Luck!
Tinteiros Magic Inkjet Flush Kits (Ebay)
Sep 12, 2009 | HP PSC 2210 All-In-One InkJet Printer
Ricoh aficio 2090 gives sc 866 when i put sd card for work as printer and scaner
SC866 B SD Card Error 1: Confirmation
The machine detects an electronic license
error in the application on the SD card
inserted in the controller slot when the
machine is powered on.
The program stored on the SD card contains
electronic confirmation license data. If the
program does not contain this license data,
or if the result of the check reveals the
license data in the program on the SD card is
incorrect, then the checked program cannot
execute and this SC code is displayed.
• Required program missing or
incorrect
• Download the correct
program for this machine
onto the SD card.
SC867 B SD Card Error 2: SD Card Removal
The SD
Jul 03, 2009 | Office Equipment & Supplies
"Incorrect Color Cartridge Installed"
You can just click the print button and the printing will begin, I was having the same problem.
Apr 05, 2009 | HP PSC 750xi All-In-One InkJet Printer
Incorrect cartridge error
The Error is incorrect or Invalid .
The error invalid comes if the printer and cartridge does not belong to the same region.
Mar 27, 2009 | Samsung CLX-3160 All-In-One Laser Printer
Prints incorrect colors
Try another head-cleaning cycle -- it worked, last time, correct????
Dec 09, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
Everything I print comes out pink, including black print is pink.
Run a clean cycle and a test page this is priming the cartridges. If this fails to get the colors going the printer will need to go in for repair. The internal print circuit could be gone. Check costs before doing this a new printer maybe worth less then the repair.
Dec 05, 2008 | HP DeskJet 940c InkJet Printer
Display shows: printer cartridge incorrect
It seems like you are using incorrect printer cartridges.....
Make sure that part number on ink cartridges should be :
MK990 Cartridge, Ink, Standard, Series-9, Black CTRG,INK,STD,SERIES-9,BLK 0 1 0 Yes 1 N MK991 Cartridge, Ink, Standard, Series-9, Color CTRG,INK,STD,SERIES-9,CLR 0 1 0 Yes 1 N MK992 Cartridge, Ink, High-Yield, Series-9, Black CTRG,INK,HIYLD,SERIES-9,BLK 0 1 0 Yes 1 N MK993 Cartridge, Ink, High-Yield, Series-9, Color CTRG,INK,HIYLD,SERIES-9,CLR 0 1 0 Yes 1 N MK995 Cartridge, Ink, Series-9, Photo
Nov 10, 2008 | Dell 962 Photo All-In-One InkJet Printer
Printing incorrect or faded colour.
Your printer have 4 sensors for ink level in ink tank section. Clean this sensors. Incorrect or dust colors - problems with printhead, or with the ink system. If you never replace printhead on this printer - call service. Thats be cheepest.
Oct 17, 2008 | Brother MFC 210C All-In-One InkJet Printer
Canon PIXMA MP960 All-In-One InkJet Printer Logo
125 people viewed this question
old marine
old marine
