Question about Speed Queen AWS75NW Top Load Washer
Replace Water Pump on Speed Queen Washer
I don't know how to take the back off my machine to get to the water pump on my Speed Queen Washer. Model #HA6001
  • Anonymous Mar 19, 2014
    Pump not pumping water out
Did you look at the front panel if you tip the machine to the back and look at the bottom of the panel you will see 2 hex head screws remove them and lift the panel out and slide it down some machines others you have to remove the top
Posted on Jan 13, 2010
Speed Queen HA4291WA Doesn't pump water out after cycle?
Pump is clogged or no good. Either way you have to take it off to find out. You can be amazed at what gets into washer pumps so don't be surprised to find lint, a sock, or a pair of skivvies you thought were long lost after a river bank party...
Feb 04, 2015 | Speed Queen Washing Machines
Speed queen top loader. Machine does not drain out water, it washes, but when it comes for the water to darin out , nothing happens. it will spin, but water still does not drain out, have to dish it out...
You need to clear out the drain pump. You do this by tilting the machine back as far as you can so you can access the underneath. You will see the small drain pump. Have a basin ready to catch any water that comes out when remove the pump which is only held in by 1 or 2 screws and twisted out or pulled out. Hope this helps
Mar 02, 2011 | Speed Queen AWS45NW Top Load Washer
Coin-operated Speed Queen washer: Model swtt21wn
speed queen double front load washer spinning without stop,please give some idea,thanks alot
Feb 21, 2011 | Speed Queen SWT921 Top Load Washer
My machine will not drain after a cycle
Hi, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Take care
Jun 20, 2010 | Speed Queen AWS75NW Top Load Washer
I NEED TO REPLACE THE BELT ON A SPEED QUEEN TOP LOADER,HOW DO YOU TAKE OFF THE PLASTIC WHITE WATER PUMP HOUSING TO BET TO THE BELT?
You have to remove the entire motor/pump assembly. Two screws in the front, and two on the rear of the metal mount bracket. There are 3 screws holding the pump on you can get to once it is removed.
Feb 24, 2010 | Speed Queen AWS75NW Top Load Washer
My speed queen top loader is leaking water during the washing period. Water is coming out of the bottom of the washing machine while it is washing
It is probably the pump. Run the washer with the front off of it. The pump is on the bottom of the motor.
Easy repair.
Nov 08, 2009 | Speed Queen AWS52NW Top Load Washer
Older model speed queen
check the water pump and the center tub seal to see if it coming from one of the two if the pump is restricted the water can come over the sides of the tub
Apr 25, 2008 | Speed Queen AWS52NW Top Load Washer
Speed Queen AWS75NW Top Load Washer Logo
1,074 people viewed this question
Top Speed Queen Washing Machines Experts
Charles T Nevin
Charles T Nevin
fta777
Mike
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
