Question about Kenwood 104AR Receiver
The pioneer avh-500dvd doesn´t turn on, once connected
Hi Sr., i´m trying to install the unit but there´s a problem with the power on. This just doesn´t turn on. In the manual says that the reset button can solve this, but it dind´t work. This is my first installation of this unit. I already have the pioneer avh-5900dvd, and it´s works fine. Can you tell me how did you install the unit?. Thanks
3 Suggested Answers
SOURCE: Kenwood KDV-412 In-Dash AM-FM-CD-DVD Player.. Will not turn on
I found a switch in the trailer which my wife had switched to the off position that controlled the unit. Turned it back on, and power was supplied to the player. Dumb me... I'll not forget this 'fix' Thanks for your service and reply.
Frank
Posted on Mar 28, 2008
  • 6 Answers
SOURCE: no front speaker sound
Microprocessor reset.
For US and Canada:
  1. Unplug the power cord from the wall outlet, then plug it back in while holding down the POWER key.
For other countries:
  1. With the power cord plugged in, turn the POWER key OFF. Then, while holding down th ON/STANBY key press POWER.
Posted on Jan 18, 2009
My Pioneer AVH-P1400dvd wont cut on after installing it
Did you make sure you connected the Blue wire to the pioneer its the remote to the car when the car is on the device will be on if you don't connect this wire the device will stay on
Dec 28, 2013 | Pioneer AVH-P1400DVD
ON A PIONEER CAR UNIT MODEL AVHP49000DVD , I BOUGHT IT USED , THEN HAD TO BUY A POWER PLUG FROM PIONEER WITH A WIRING DIAGRAM , PUT IT IN MY 2006 GMC TRUCK WITH A FACTORY WIRING ADAPTER IT WILL NOT COME...
You will need to connect the pioneer unit to a switched ignition wire from the ignition switch. The 2006 GM factory radio only has a constant B+ (orange wire) and ground (black wire). The factory radio turns on when the Body Control Module (BCM) sends the radio a turn-on signal (on a data communication line) when the key is turned on. Your pioneer unit won't talk to the truck's BCM, and will need you to wire a switched B+ feed to it that turns on in the ignition accessory and run positions.
Aug 23, 2013 | Pioneer Avh-p4900dvd, Avhp4900dvd,...
I have an Avh-p4100 and the IU200V cable. My DVD was playing the videos, but now it simply doesn´t play videos anymore. The cable´s plug is right conected back the DVD, and in the initial menu,...
Try resetting the unit using a pen. While powered on, click the reset button and this should resolve your problem. If it doesn't the problem maybe related to parking brake cable not being connected properly.
Mar 04, 2010 | Pioneer AVH-P4100DVD Car DVD Player
My Pioneer AVH-P4100 DVD just beeps...
could it be a ground or is the ant. plugged in
Aug 20, 2009 | Pioneer AVH-P4100DVD Car DVD Player
I HAVE A PIONEER AVH-P5100DVD AFTER CONNECTING ALL WIRES THE UNIT WILL NOT POWER ON. IM INSTALLING IT IN A JEEP CHEROKEE.
make sure u have connected the fm tunner silver box if not thats your problem if u do not connect it it wont power thats really important.
Jul 01, 2009 | Pioneer AVH-P5000D Car DVD Player
How do i bypass the brake safety switch on a pionner avh-p4000
CONNECT A SWITHC TO THE PARKING BRAKE WIRE ONE OF THE PINS FROM THE SWITCH TO GROUND AND THE OTHER SIDE TO THE PARKING BRAKE WIRE.
Mar 14, 2009 | Pioneer AVH-P4000DVD Monitor
AVH-P5000DVD
I have the same problem. I conect the red and yellow wire at positive battery and the black wire to ground, but it doesn`t work. I press the reset button and nothing. I am try to turn it on with a power supply. could you tell me or show with a picture how to conect All?
It`s AVH - P5000DVD
regards
From Venezuela.
Aug 19, 2008 | Pioneer AVH-P6500DVD Car DVD Player
Ipod will not play video to my head unit AVH P5900DVD
ok for the first post with the ipod not showing video .. make sure that you have the correct cable running from behind the deck to the ipod .. (iPod Direct Control (CD-I200 Required) once you have that connected you need to go to the video settings of your ipod and turn on the video out .. by default its offf... also remember with movies on your ipod .. that has to be manually selected from the ipod itself .. you cant control the videos from the pioneer unit.. only the audio/music on your ipod can be selected from the pioneer unit..
May 24, 2008 | Car Audio & Video
Unit won't turn on....
There are several surface mount fuses and the flexible pcb is also a suspect, don't attempt to repair this unit yourself unless you have experience if not you will end up doing more harm than good.
Apr 10, 2007 | Pioneer AVH-P6500DVD Car DVD Player
Kenwood 104AR Receiver Logo
98 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
