Sounds like a poor connection in the control or a faulty control module, I would return it as faulty for a new one. They seal those units up pretty good so we can't fiddle with them. Everyone gets a lemon sometimes.
Try to reset the circuit breaker. also check for an earth fault on the starter motor .If this is not a circuit breaker and is a relay, you should make sure everything is ready for a start, (ie : in neutral, sidestand up and clutch in and that the battery is charged.) the neutral light being "on" doesn't mean it is in neutral. I hope this helps.
check for power to starter solinoid, if power to there. then it has to be a bad starter solinoid or starter. checker solinoid first. if bad you will not hear any clicks or anything.
The AUX output is your best bet as it is independent of the main mix, so the main volume control won't affect the recording. You will need to turn up the AUX control for each channel you wish to record, and also make sure that the AUX master is up. Depending on the software/ hardware you are using to record, you should be able to set the main record level using the AUX master. Start by setting all the AUX controls to 12 o'clock and adjust from there.
if you are referring to a computer with your microphone & headset attached click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enablewindows 7 hope this helps
