Rear Projection RCA Snapping & Shutting down
1995 46'' RCA Trimline Rear Projection TV ... For what it is this TV has always worked fine. However, recently we have experienced the following issues:
1: Colors started to blink & occassionally turn to Black & White.
2: We can hear a snapping sound when this occurs.
3: Snapping sound has been occuring much more frequently.
4: Colors flicker, snapping sound occurs, TV shuts off for a few seconds ... & then turns back on.
Thanks ... Kha
    Guru:
  • 449 Answers
I am guessing it to be an intermittent condition of somekind.
Just tap the set with your hand; on the back, sides, top, etc. to see if you can restore the picture. If so, then I am right. Unfortunately, these kinds of problems are very hard to find. If you can find a reliable place to tap or strike the unit, do that and than don;t touch it!
Sometimes if you can put some torque or twist on the chassis it will keep the loose connection inside working. You can do this by placing a small object under one of the corners or something creative like that.
If this technique does not help, you will have to repair it. The cost may be more than the price of a new set.
Posted on Jan 07, 2009
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
RGB as Ginko put it is your Red/Green/Blue or color generating board going into failsafe (black and white mode. As this has to do with picture quality, you are best to take it to a shop as they would have the equip to service but be ready, they could give a repair as expensive as a new set.
  • 837 Answers
I would give it a good "pressure air" cleaning .. like from am air compressor .. Its gotta be dirty inside .. take the back off
    Genius:
  • 2,920 Answers
Yu have a bad circuit board that needs replaced.if the tv is more than 19 years old id look for another tv
    Scholar:
  • 145 Answers
Dear sir,
Let me make you clear that it doesn't sounds like its a do-it-yourself job.I guess there is a multiple component failure in the circuitry of your TV. Some capacitors have surely worn out. I would strongly recommend that you take help of a qualified technician as handling television circuitry without good knowledge is very dangerous and can be fatal. Till the technician advices you do not switch it On to avoid more damage.
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Posted on Dec 21, 2008
  • 10,594 Answers
Let me know model number of TV please.
As its bit old TV so more chances are that it has few capacitors weak in deflection and power supply section.
Few dry solder joints in power supply and deflection boards are also possible cause of above symptoms.
  • 19,396 Answers
Color turns to blackj and white because there is an internal fault, probably a faulty IC or a los contact on the rgb board.
When this happens the tv goes on protection because it detects the fault, that is the click that you hear.
Our RCA high-def 52 inch TV is shutting off on
It has you Posted as a projection TV and Not DLP, if Fan to Lamp stops running set will shut off to protect Lamp,I had a DLP that would play sometimes 30 mins then shut off drove me crazy trying to firgure it out and it turn out to be Fan would stop running I replaced Fan TV working fine . When you remove back engage toggler switch to up position put a piece of tape on it to hold it is a safty switch ,then turn tv on watch to see if all fans are running also if when tv trys to come on is there a spark coming from Ballast Board if so your new Lamp is defective it does happen if not your ballast board maybe Bad it is what turns on Lamp.If all fans are running Ballast Board.
Sep 22, 2009 | RCA HD52W56 52" Rear Projection HDTV
My 52 in rear projectiontv would not turn on
UNPLUG UR TV FIRST go to the back of ur tv on the right there should be a panal that has three screws or more this is were the power switch board is . remove it and check that there's no black marking's on it if there is that the problem
email - bfd.pete@hotmail.co.uk
Jan 14, 2009 | RCA D52W19 52" Rear Projection Television
RCA P46920 TV will not turn on, it makes a beeping noise.
Shorted horizontial output transistor q14401 -I think- and bad flyback transformer(high voltage transformer).The noise is the power supply starting and shutting down very quickly because of the shorted transistor.Very common problem,but some of the flybacks are no longer available from RCA.Sometimes you can use generic but questionable life on some of these.
Jan 11, 2009 | RCA P46921 46" Rear Projection Television
RCA D61W130YX1 chasis AYCZZ1 Serial# C425C101C
hi there do you have sound ?? if so open the back and check for a bulb youself as i dont trust shops much anymore becaues they always want you to replace old models.
richard
Oct 15, 2008 | RCA D61W20 61" Rear Projection Television
Rca 52 in rear projection... start up menu always on
The setup menu will repeat until it is completed and/or something is hooked up.
On my TV it kept reoccurring until I connected up the wire from the roof antenna, even though I had cable already installed.
Check your manual for setup instructions or if you do not have one, Google the make, model number and "owners manual" to see one online.
Hope this helps. :)
Mar 31, 2008 | Televison & Video
Is Repair worth trying?
its smart to try to DIY if its only the sound that was lost.
but be very careful as such appliance have very intricate design. always be careful.
you can start by troiubleshooting the speaker itself then work down going to the wires of the speakers then the audio chip.
if you still have some questions, just post them here.
Mar 28, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv wont work
This set's processor sees a problem and shutting the unit down for safety. There can be one of about 30 different problems that would cause this to happen. A technician has special computer interface that allows him to read errors in the processor. So this unit will have to be trouble shot further to narrow the problem down.
Jan 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
finich seting up ...go through the setup menu. and pushing ok instead of clear. if it continue this indicate the main ac is being interupted.. do you unplug it at night? or just power it down.
Dec 15, 2007 | RCA HD52W58 52" TV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
