My Crate blue voodo amp head
Im not an expert on amps but im guessing that the tubes in the amp are broken. I know its not the fuse because the lights will turn on but no sound will come out. This is an old amp and I saw the advice you gave the guy on the fender amo, so i thought maybe you could help.
    Genius:
  • 1,175 Answers
Hi...
1st off , check the connections from the head output jack to the speaker cab. If you can get hold of a meter , check the continuity on the cable (center wire to center wire , ground wire to ground wire) both should be about 0 ohms.
Do you have another speaker cab you can try>?
You might have a speaker fuse internal on the amp too OR a secondary fuse on one of the power supply lines
Posted on Dec 29, 2008
  • Scott Frye
    Scott Frye Dec 29, 2008
    also...
    see if the tubes are "lit" . There should be some glow action in the tubes when it's fully on.
Crate power head replace fuse how to /
did it blow a fuse or is it just dead?
Aug 02, 2014 | Crate Music
Hello im sorry but not speak english a litle, im need picture of power amplifier crate model spa-1200 made in u.s.a.fabricated for slm electronics,1400 ferguson ave. st louis mo. 63133 and not found...
Hi,here is the one upper version of it as "Crate SPA1400 model " 1400 watt Stereo Power Amp.they are identical ..
Hope this helps! Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :) Thanks
Crate SPA1400 Stereo Power Amphttp://cgi.ebay.com/Crate-SPA1400-Stereo-Power-Amp-/270771488929?pt=LH_DefaultDomain_0&hash=item3f0b3d08a1
Jun 25, 2011 | Audio Players & Recorders
Have a Crate V50-112.Have had it for 1 year. Replaced tubes 2 weeks ago, turned amp on tonight, started to play, amp went dead. Checked fuses, they're good. Any ideas?
Check for bad tube... it HAPPENS that brand new ones fail... USUALLY if they last 50 hours, they will last for the expected life. The bad tube would likely NOT be the main power tubes, as the amp would still run on one cylinder...
Feb 02, 2010 | Crate Music
Im Installing an amp and i have a kenwood head unit im not sure what model as i was givin it by a mate. I no that in most head units the remote turn on wire or remote amp wire is blue but im jst checking...
yes there will be a blue wire and maybe a blue with white wire one will give 12volt the whole time the radio is on, the other wire will give 12 volts for 10sec
Jan 07, 2010 | Car Audio & Video
Crate amp hums when it is turned but can work at times
has th amp got a valve if so the valve may need replacing or might need reseating..
Jul 31, 2009 | Audio Players & Recorders
I have an old crate blue voodoo amp head that wont work
Good day sir, changing the tubes won't solve the problem, sad to say it but you may need to bring it to a veteran technician, that knows tube amps. there are simply lots of things to check for. hope this helps, thanks
Jul 19, 2009 | Audio Players & Recorders
Amps broken need to fix it
Their may be a schematic on the inside of the amp.I don't remember if Crate puts one or not. And I have had several Crate amps. never needed repair except for tube replacement. If there is not one in side , go here and find what you need . http://www.crateamps.com/support/warranty/ Good luck DFD please rate me TK U
Apr 18, 2009 | Crate Music
Crate bv120.no power or sound..no lights..f6 fuse has 160 ohms...
did you change out the fuse? could be a tranny going south. if you change the fuse and you still get no power, then you have a fried power transformer. they are relatively easy to replace. look on ebay . get the numbers off of the existing one and start web searching. something will come up. if not email me on my contacts tab in my website yostamplifier.com we can troubleshoot. you should see the custom blue voodoo i built and gave to my little brother.
Mar 14, 2009 | Crate Blackheart BH15H Handsome Devil...
Crate tube amp will not power up but cooling fan tries to run
Yes.
Are you saying that the only indication that it is running at all is that the fans are running? So the tubes don't light up? No indicators on the front of the amp?
Power supplies that provide multiple voltages, which your amp has, can provide some of the voltages while having a problem that prevents them from providing others, all while not blowing a fuse. If you are not confident in your ability to work on a piece of electronic equipment that has 120VAC coming in and at least 175VDC or more present inside it, bring it to a service center.
The good news is that it is probably not horribly serious. Problems like this can almost always be repaired in a cost effective manner.
Feb 11, 2009 | Crate Blackheart BH15H Handsome Devil...
 Grubhead
Grubhead
Marvin
Marvin
