Question about Micro Solutions RoadStor Pro (738909003104) DVD±RW Burner
Can't perform the first step...copying from memory card to CD!
I followed the instructions to the letter but could NOT get the thing to work! Charged the battery. Inserted 8 gig CF card with 5 images, turned on unit, inserted CD-R, pressed the backup button twice, waited a few seconds, then received the Message "backup error". Tried different CD-R discs, then tried different CD-RW discs, all of which were empty and formatted. Kept getting the above erroe message...sometimes the meassage would say"insert new disc." Man, I really thought this thing would be easy. I read many reviews before I bought it, most people found it to be easy to use, while some encountered the same problem as me, but never said if they ever solved the problem, or HOW to solve the problem. FRUSTRATING!!! New RoadStor...New CF memory card, and New CD's, and it just keeps spitting out the CD's!!! Any help you can provide would be greatly appreciated. Thanks for taking the time to read this and responding. Please help me get past this first "easy" step.
    Top Expert:
  • Micro Solutions Master
  • 41,875 Answers
There is a possibility that the unit is simply defective.
Posted on Mar 09, 2017
2 Suggested Answers
marked
  • 6487 Answers
SOURCE: Just bought this RoadStor and
Yes you;re correct that alot of user have same problem as you and this problem is can be cause by a software glitch inside this portable burner that causes it not to work properly, fuirst thing that you can try is to contact the manufacturer and ask if there's any software update that you can do if none I suggest you replace this unit with adifferent brand...
Posted on Dec 21, 2008
How do i fix error 20, i already put off an put the battery again but still its not working
You need to tell us what model camera you have! Error 20 in a Canon camera indicates a mechanical malfunction. You might be able to fix it by the following:
If the issue persists, please try an alternate CF card in the camera. If the alternate CF card works fine, then your first CF card was the cause of the issue. If not, there may be another issue with the camera. If so, please follow these steps:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
If the message does appear, your camera may require service.
If not, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the message still appears, your camera will require service.
Oct 19, 2014 | Cameras
Canon EOS Digital Rebel XTI 400D Displays Err 99. Problem with CF card. Replaced with brand new card-still same err 99 camera is totally charges, acts dead, keep flashing Err CF, I try to format, it...
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
camera body.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
camera should be serviced.
Aug 31, 2008 | Canon EOS-20D Body only Digital Camera
Tip
How to recover photos from CF Card?
CF card is widely used by digital camerafor its larger , from about 512MB to 64GB, lower cost as well as fasterspeed, which allows digital camera shoot under special conditions, such asmoving objects. The most popular and trusted brands for CF Cards includingKingston, Ritek Ridata, SanDisk, Transcend, Apacer, Viking, and Lexar.
Reasonsof lost photos
Lost photos in CF cards can be caused bymany reasons: card damage, failure, corrupt, etc. and the following are some typicalphenomena.
1.
Accidently selected "Format" onyour digital camera and erased all the pictures on the CF card.
2.
Keeping take photographs whenthe camera battery is at the end of its life.
3.
When upload images to computer,mistakenly judge the finish of uploading and eject the CF card ahead of time.
4.
Turning off the camera beforethe image is completely written to the CF Card
5.
Receiving an error message like"card not formatted", "card not found" or "no images found"......
How to recover lost photos from CF card?
Before recovery, you should know that yourphotos are not erased actually. It stored on CF card as a file. When you formatthe card or deleted photos from the card, the data on which the images werestored is not deleted. It only allows new pictures to take its place.Therefore, make sure not taking new photographs any more in case that theprevious photos would be overwritten.
Data Recovery program like Card DataRecovery can help you get backpictures from CF Card easily. Download Card Data Recovery and Install it onyour PC. Take out the CF card from digital camera and connect it to your laptopor connect digital camera to PC directly. (If your desktop or laptop has abuilt-in card reader, things will be much easier, if not, you need a cardreader to help you.) Then your CF card appears as a drive letter when you go to"My computer" If you see this, it means Card Data Recovery can access andrecover your pictures. Select "photo" and scan your CF card. The process isquick and all recoverable images will be listed with the same signature. Previewthe photos before recovery and restore what you wanted.
Besides retrieve photos, Card Data Recoveryalso can recover video, music, files, etc. Popular video and audio formats likeMOV, FLV, AVI, WAV, MP3, MP4, MPEG, etc. are available with it.
on Apr 21, 2011 | Computers & Internet
.HAVEN'T USED 10D FOR A LONG LONG TIME AND
Here are a few things to try:
1. Remove the main battery and the small backup battery (CR2025) from the battery compartment. Charge your main battery and put both batteries back in once your main battery has been charged. Sitting without batteries will give the camera a chance to reset itself.
2. You may have a bad CF card. Try starting your camera without a CF card or use another.
3. Try reloading the firmware (camera's operating system) using this link Canon. http://web.canon.jp/imaging/EOS10D/10D_firmware-e.html
Be careful to follow instructions exactly as restarting the camera in the middle of a firmware update will brick it and you will need to send it back to Canon for repair.
Hope that helps,
Bax
Oct 11, 2011 | Canon EOS 10D 35mm SLR Camera
Cf error - camera now dead
None of this sounds good. I would start by checking the condition of the pins in the CF card slot. A small light and a loupe will help. If any of the pins are damaged, bent, or even missing, then the camera may have had a short circuit and blown the internal fuses. Neither the pins or the fuses are user replaceable.
Feb 06, 2010 | Canon EOS 30D Body Only Digital Camera
Canon Rebel XT wont fully come on
Hi
Error 99 is usually a lense error and gives the only real clue as to what is going on with your camera. You can try this simple fix which comes straight from Canon. Follow the steps to help isolate the issue. Note the fact that you are currently not getting the Error 99 is probably a good sign according to the troubleshoot.
To isolate the cause of the issue, we suggest that you do the following:
Does the “ERR 99′ message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
Does the “ERR 99′ message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
camera body.
Hope this helps. Please do rate my answer. Thanks.
Aug 09, 2009 | Canon Rebel XT / EOS 350D Digital Camera
I am getting an error cf..tried to format card and get error 99
I Googled the error code you're getting, and found a list of things to try and steps to attempt directly from Canon. Try out some of the stuff below, it should help.
camera body.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err CF then Err 99 - Canon Rebel XT / Hitachi 4GB Mircodrive
Not all CF cards are created equally, so yes, it could be your batch of cards. To determine if the error is CF related, and not anything else, try the following steps which are used to diagnose err 99's
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Feb 13, 2009 | Canon EOS 30D Body Only Digital Camera
Nikon D70, displaying error code 'CHA' when memory card inserted. Unable to format or use memory card. Have tried new memory card, still same problem.
CHA errors indicate a communication issue with the CF card. Your card could be going bad, you could have a broken pin, or any number of other problems.
I'm running into this same problem now. If anyone has a good step-by-step to troubleshoot which of the dozen things this error could be, I'd appreciate it.
For myself, I'm planning to start by trying a new CF card.
Sep 02, 2008 | Cameras
Camera
Please check the following things when the camera does not turn on.
Possible causes and how to handle them
1. The camera is not on
Turn on the camera. (Operation procedure varies between camera models. Please refer to the camera user guide supplied with your camera.)
2. The rechargeable battery is not fully charged.
Make sure the rechargeable battery is fully charged. If the battery has not been used for an extended period of time, or if it is being used for the first time, it may not be fully charged. In cases like this, fully charge the battery and then discharge it completely in the camera several times to bring the battery back to its normal performance.
The rechargeable battery's capacity diminishes the longer the battery is used. When the battery consumption becomes quicker, the battery life may be at its end. Replace the battery with a new one.
3. The battery terminals are dirty.
When camera does not operate with a brand-new alkaline battery (for cameras that use AA-size batteries) or with a fully charged rechargeable battery, the terminals may be dirty.
Polish the terminals with a dry cloth and make sure the terminals are clean. If the terminals are covered with oil from your skin or similar matter, this may cause poor contact and power may not be fully supplied to the camera.
Also, polish the battery charger terminals with a dry cloth before charging the battery. If the terminals are covered with oil from your skin or similar matter, this may cause poor contact and the battery may not be fully charged.
4. The batteries are not installed correctly (for cameras that use AA-size batteries)
For cameras that use AA-size batteries, multiple batteries are used in one camera. Make sure the direction of each battery matches the direction indicated on the camera. If any of the batteries are improperly inserted, the camera will not operate.
5. The battery cover or CF card (SD card) slot cover is not securely closed
Most cameras have a lock mechanism on the battery cover. The camera will not turn on if the battery cover is not locked or securely closed, or if the CF card (SD card) slot cover is not securely closed. Make sure these covers are securely closed.
If your camera does not operate after checking each of these things, or if there is any visible damage on your camera that could be the cause, please contact the nearest Service Center.
Courtesy: http://photography-on-the.net/forum/showthread.php?t=151603
Jul 20, 2008 | Olympus FE-210 Digital Camera
Micro Solutions RoadStor Pro (738909003104) DVD±RW Burner Logo
Top Micro Solutions Computers & Internet Experts
Tom Chichester
Bill Boyd
Are you a Micro Solutions Computer and Internet Expert? Answer questions, earn points and help others
