Question about NEC Mitsubishi LVP X400BU Multimedia Projector
Red mirror picture on mitsubishi lcd projector model lvp-x400u
I have very blurred pictur on projector an i think it was a dirty optics in it. so i open it at all till basic color lcd panels and i recognize that mirrror which is inegrated of few single glass take with glue betvenother is apart on some places. i take it all together and still that i have this problem. is the unregular fixing glass cause problem that i have doble red picture near the original image.thanks
  • Ricky brashear
    Ricky brashear Jan 26, 2009
    The blurry picture is dirty lens, I took my xl550 apart and cleaned all mirrors and lens, but when I put it back together I had a dominate green color. I noticed that I had put one of the lens in backwards. Did you take any of the lens that are flat on one side and curved on the other. that is probably your problem.
jackboy
  • 2985 Answers
SOURCE: HP-070
Works for a few months?
Is this a new device -?
Check with seller and or makers help site.
Lamps guaranteed for 90 days and Machine for 2 years usually
Posted on Jan 15, 2008
SOURCE: LCD PRojector has pinkish color for entire image
How many hours are on your bulb? If it is near 2000 it is time to change it.
Posted on Apr 04, 2008
Tualiapz
  • 80 Answers
SOURCE: Projector produces very low light.
My recommendation is that since you have 2 of these machines and the other is working fine,
Pull out the lamp from the good one and place it in the faulty one.
Turn it on and check the projection quality if it is still blurry. If it is working good, then replace the lamp. If it is still blurry, a good cleaning to the lens on the projector may be a good idea.
You can also check the auto focus function of the projector and the cable that provides the video signal to the projector
You can get the manual from below link if you need to find out how to check the auto focus setting
http://www.necvisualsystems.com/Documents/UserManuals/MT860_1060_1060R_MAN2.pdf
Posted on Jun 03, 2009
  • 5 Answers
SOURCE: pink tint on projected picture
Replace LCD
Posted on Mar 06, 2010
SOURCE: Strange shadows on NEC MT1030+ projector image
I dont know if this helps but I have of few of these at my company and when I had the repair people out they said it was a bad prism. If anyone can repair these and whats to buy them cheap let me know. Midwestmusicmoguls@yahoo.com
Posted on Mar 30, 2010
Mitsubishi lvp-s290u turns on and works for about an hour then turns off
Give it a good cleaning while off with canned air. Be sure to clean filter if it has one. Do not spin the fans too fast or they will lock up.
Oct 16, 2012 | Mitsubishi Lvp-s290u Lcd Projector
Mitsubishi dlp tv picture is getting darker
One of two possible issues:
1. Lamp is nearing end of life and may dim just before total failure.
2. A few of these models have 2 mirrors(check with Mitsubishi to see if yours is one) A large mirror in back (never gives a problem and do not try to clean it. Some idiot in these sets used a small mirror inside that the optical unit shines the picture into (wedge shaped mirror and small) and it is facing up----the fans intake air from the front of the set around this mirror--it gets coated with lots of dust---Picture can loose up to 70% of its brightness and clarity if that mirror is dirty--looks like 20 year old set .
If you do not wish to check with Mitsubishi GOOGLE THE MODEL NUMBER with "mirrors" to see.
If it has 2 mirrors I can tell you exactly how to get at it.
SD TECH
Mar 31, 2012 | Mitsubishi WD-65736 Television
Red light labled LAMP stays on and I have no display of picture from projector
there is a problem with the lamp, hence why it will not switch on. Replace the lamp
Mar 31, 2011 | Mitsubishi LVP-X300 Multimedia Projector
I was wondering if u know y my mitsubishi tv wasnt showing a clear picture i replaced the lamp with new one but it still shows a dark picture
This may be a model that has two mirrors. Mitsubishi could tell you if this is the case.
Some idiot had the bright idea to have optical unit shine picture into tiny mirror which puts it into large mirror in back; problem is tiny mirror if there is at bottom and facing up, dust or dirt get on it and picture brightness will diminish up to 70% or more.
If model you own does have two mirrors, the front of the set with the screens will have to be removed to clean it, not real hard and takes 15 minutes.
If you can confirm it has two mirrors I can tell you step by step how to remove screen unit and resolve problem. Usually if tiny mirror dirty it will happen over time, picture will gradually get darker and dull looking.
Let me know if want instructions, the set either has two mirrors or it does not.
SD TECH
Nov 03, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Blurry picture
You need to clean the projector lens on the optical engine using a soft cotton or, better yet, a chamois cloth. Also clean the mirror mounted inside the rear cabinet and also the front and rear of the screen itself.
If picture is still blurred then your the optical engine is most probably defective.
Dec 10, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Projector will not project light (Mitsubishi LVP-X80U) LCD Proje.
Hello toma_leonard,
First check your lamp to make sure it is seated properly in the socket.
Then check all of your interlocks (see your manual for locations), these are usually located on any hatches or doors that allow access to the lamp and or fan area. Once you check your interlocks make sure the filter and fan area is clear of dust, (some projectors have air flow sensors), and the recheck the interlocks. Once this is done , If the interlocks are not broken, or the lamp fuse blown, the projector should be working. If not it is the lamp that needs changing.
I know this may be expensive, however these lamps do go bad, as much as we wish they would not.
If you still feel it is not the lamp, have a technician check the voltage levels to the lamp and the levels of the control board circuitry.
I hope this helps,
Thank you,
Shuttle83
Nov 20, 2008 | Mitsubishi LVP-X80U Multimedia Projector
Red shadows to picture and letters on Sony TV
its most likely a warped lcd plate in the optic block if thats the correct model number which would require a optic block change out
Jul 05, 2008 | Sony KDF42E2000 42" HDTV
Blurred image from sony home theatre projector
Unfortunately an expensive repair or total replacement are probably your only real options. Electronically the projector is fine but your problem lies in the physical optics part of it. Either part of the lense assembly or the refraction array is likely damaged or at least very dirty. I wouldn't suggest trying to clean it yourself as this is a 3 LCD projector and all 3 must align perfectly after cleaning or you'll end up with seperated colors. It could also be one of the LCD's is damaged but from your description I don't think so.
I have a client that had the exact same issue with a different VPL model and it was cheaper to go out and buy a new projector than to fix it.
Jan 18, 2008 | Sony VPL HS10 Multimedia Projector
Mitsubishi LVP-X30 Multimedia - No picture
yes its because of your bulb and filter in the projector clean the filter and see if that works if not your going to have to purchase a new bulb from the manfatures web site
Jan 04, 2008 | Mitsubishi LVP-X30 Multimedia Projector
NEC Mitsubishi LVP X400BU Multimedia Projector Logo
51 people viewed this question
Top NEC Office Equipment & Supplies Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
