Question about Toshiba SD-2805 Multi-disc DVD Player
Disc will not play
I accidentally pushed the tray when it was open and I heard the it click several times when I pushed it. the tray does not seem to open all the way because of this.
  • Vivian Gosselin Apr 10, 2007
    Fortunately, our 3 sons came to our rescue Easter Sunday. One son is a computer/audio/communications tech, another repairs ultrasound & cameras for hospitals & the third, electronics are his hobby. They are wonderful. Thank you for replying. Vivian
    Genius:
  • 1,074 Answers
Have your set check by a tech according to your explanation it seems that you had broken a gear on inside your set.good luck to you
Posted on Apr 05, 2007
Panasonic SA-PT460 disc tray keeps opening. When system switched on disc tray opens, then closes and then opens and stays open. can't play a disc.
SA-PT460
Original fault tray would not stay closed,opened up 460 case and then removed 2 screws on rear of drive. unplug 2 ribbon cables.
unscrew 1 screw in micro switch pcb rotate and spay cleaner into switch and rock switch several times until the reading across switch is 0 ohms before you start you will find the switch has about 2.5 k of resistance across it witch is too high.
as long as you have about 4ohms it will work.
Aug 14, 2011 | Audio Players & Recorders
Put disc in xbox 360, said reading then open tray. wont play no discs
@paulhull58 when the disc tray closes push down firmly on the top of your xbox where the tray is. if not clean your disc.
Apr 04, 2010 | Microsoft Xbox 360 Console
Disc changer won't open, won't play DVDs. RCA RTD
Check the belt inside underneed the tray if this is still in place.
if not put belt back on
Feb 15, 2010 | Bose Lifestyle 12 System
Disc will not read..
its mostlikey the disc that is the issue if it isnt i rcommend calling the number in the manual that came with the xbox
Jan 11, 2010 | Microsoft Xbox 360 Console
We have the RCA RS2767i Home Stereo with 5-disc changer and ipod dock. The CD Tray won't eject or shuffle...everything else works fine. It seems the disc tray isn't responding to anything. We read in the...
Let me respond with a possible solution although I'd bet that both of you already tried these.
The reason I checked into this is because I'm looking for a new mini system. I happen to be at Target and they only had 2 models - this one and a SONY. I certainly didn't want to buy the RCA given these problems, so I asked the salesperson, who seemed to have some knowlege.
As far as opening the tray on top, there is a button to push right under the tray. The button has an icon of a triangle on it. This seems to be somewhat of a standard icon for opening the tray or ejecting a CD (my car's CD has the same icon for ejecting a CD).
As far as only being able to get 3 CD's out, there is another button under the tray marked "disc skip". This rotates the tray. When you open the tray, you can only get to 3 of the CD's. When you push disk skip, it rotates the tray one position, so you can get the 4th one out. Another push and now you can get the 5th one.
Sometimes my CD changer doesn't shuffle the disks. If I only have 1 CD or DVD in it and push the tray open button, the disk stays in the unit and the tray revolves to an intermediate position. I push the button to put the tray back and try disc skip; that usually works.
If your problems are not solved per above, then I definitely do NOT want to get this.
Fred
Dec 05, 2008 | Audio Players & Recorders
Dvd do not loads
Our started doing the same thing about a week after the warranty ran out. It has to do with the alignment of the discs being loaded. here's a work-around that works for us:
Open the tray
Choose which disc you are going to watch and use the Change Disc button to push the selected disc to the back (ie, if you want to view Disc 1, discs 3 and 4 will be visible in the tray).
Look down the center holes of discs 3 and 4... manually move your tray left-or-right to align the holes with the tray.
Push the Direct Play button on the top right of the unit for your disc of choice (Disc 1 using the example above).
hope that helps... I've searched for a while and played around with the unit (with and without the cover on) trying to figure out a way to re-align the tray, but no luck.
--JeD
Aug 20, 2008 | Samsung HT-WP38 System
Disc tray locked on JVC XV-N322
there is a small hole in the front of the tray that will accept a straightened paper-clip. gently insert the clip and the tray should release. if the cd/dvd disc is dislodged from being flat in the tray, it may not come out. you might need to open the cover and manipulate the disc to get it back flat in the tray. a good first test is to see if the disc plays. if it does, it is in the tray correctly and should be easily released with the paper clip. the try might work after you release it.
another possible first try would be to gently push inward on the tray after telling it to release. if there is extra tension on the tray it could cause the mechanism to not release. freeing the tension on the tray could be all that you need to get the 'unlock' to release. (kinda like trying to open a door when someone is pushing it very hard against the lock mechanism. it wont be able to move).
good luck
mark
Jan 03, 2008 | Televison & Video
LG LHY-518
I had the same problem. Also, the disc tray had issues opening if there was no disc in there. The problem was two fold... I think.
1) It was kinda dusty inside the machine and needed a good air can dusting. Get around the tray but be careful not to turn the can upside down and freeze components. I also ran a lens cleaner disc several times.
2) The tray top (only visible with the system open) was starting to warp... likely because the build up of dust was creating too much heat, also causes issues in reading discs... I created a make shift cushion that I taped to the top of the plastic tray that was depressed when the top of the machine was placed back on. This required several tests as if too much pressure was applied, the tray wouldn't open at all and I got read issues in the middle of playing a disc (possibly an alignment issue of the lens caused from the pressure). I finally got a good system where I occasionally have push the top with my finger to open the tray only if it was empty so my padding (made from gauze and gauze tape) was barely getting pressure. Again, this took about 30 minutes of trial and error to get it right. The heat and the displacement due to the warped cover could have caused read issues.
I don't know if either or both of these were the cause of the problem but I can safely say that I have no issues now and yes, prior to this, I slowly went from 100% reading discs to almost 0%.
Sorry for the winded response but this saved me from buying a new system and may save you. Good Luck!
Dec 30, 2007 | LG LHY-518 System
Disk tray stuck.
My CD ROM try needs to be tightened, can you help me?
Jan 10, 2007 | GE 5803P Multi-disc DVD Player
Toshiba SD-2805 Multi-disc DVD Player Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
