Question about Amana PTH123B25AJ Heat Pump Air Conditioner
Amana PTAC stopped working
We have had this unit for almost 8 years and have had no problems. My wife turned on the unit and heard a pop and now it wil not come on. I have checked the breaker and the fuse and they are ok. What do I need to check next? Any help would be gratly appreciated. Thanks
  • 142 Answers
The relays in these units blow, hence the popping noise you heard, disconnect power and remove the electronic control board. Flip it over and look under the relays, you will see burn marks under the one that blew. You can order a new board from Amana for around $130.
Posted on Feb 10, 2009
    President:
  • Amana Master
  • 2,651 Answers
Its apretty straight foward thing(usually).. there is a power board that controls the uint, so long as you have power in to the unit this is where the problem lies, replacing the circuit board will problably due the trick
Posted on Dec 21, 2008
What does it mean when it indicates stop?
Wow, a talking AC?
How to Reset an Amana PTAC - YouTube
? 0:55
www.youtube.com/watch?v=D4SQfFChiKY
Mar 28, 2014 - Uploaded by Total Home Supply If you ever need to reset your Amana PTAC this simple guide will ... HVAC AC Blower not working, troubleshooting Fan Control board, Fan not ...
Aug 21, 2015 | Amana Heating & Cooling
I have an Amana PTAC ac 15000 BTU that has stopped, the power cord keeps tripping. I removed the power cord and plugged it in to the socket and the breaker did not trip, any clues. I'm thinking of jus
I think you've gotton your moneys worth with ten trouble free years. The power cords safety device is a bit more sensitive to a high resistive short to ground than your breaker is. I would suggest that there is exactly that: a high resistive short to ground within the cabinet of the PTAC. It has been years since I have been on a PTAC call and am unable to suggest specifics. But if you are competent and capable of using a DVOM, open up the unit and begin a systematic approach of determining the problem.
The FIRST thing I'd do is check the motor and the compressor with a digital megohmeter. Sometimes their problem will only show up with this sensitive device.
Dec 28, 2014 | Amana PTC153B35AJ Air Conditioner
Do you have an amana ptac wiring diagrams?
Sounds like you need a new control board.
Sep 03, 2014 | Amana PTC124E50AXXX
My Amana PTAC allows outside air to come through the entire unit (everywhere). I think that maybe the outside air vent, which is closed) is not secure. Would there be a problem with screwing it shut w
If you can get to the fresh air vent, and it is open, plug it by any means necessary, as long as it's safe. It will not affect the overall operation of the unit.
Oct 22, 2017 | Heating & Cooling
My amana ptac is not heating....the code "np" is displayed....how do I correct this...we just installed the unit and know little about operation. Thanks
I don't see this error code in the manual. I do see nP as an error code for Window Switch lockout. I just had this happen to me and they had me reset the control board.
Remove case, flick master switch to OFF for 10 seconds. Press Heat/Cool same time turn switch back on HOLD until off light comes on.
You should be fixed. Just had to do this for my unit. I was playing around with the settings and turned on the window switch option by accident.
Feb 02, 2013 | Amana In Wall Install Kit For Digismart...
I have an Amana ptac hotel type thru the wall unit. The unit won't turn on - it's plugged in. The gfi button is popped out. There is power to the wall plug. Any ideas?
If you reset the GFCI button and then when you go to turn it on the button pops again, then you have a short inside the units probably in the fan motor or the compressor..
heatman101
May 14, 2011 | Amana PTH123B25AJ Heat Pump Air...
I have thru-wall PTAC Amana PTH093B35AM unit. I
see if you can find a new board the power failure fried it
Jun 19, 2010 | Amana PTH093B35AM Thru-Wall/Window Air...
Amana PTAC cannot be turned on.
sound like a thermister problem, however this may also be a circuit board problem, the system is controled by the outdoor board, check to see if you have a blown inline fuse in the outdoor unit, it will be under a red case in one of the wires.
Jan 28, 2010 | Heating & Cooling
Finding a less expensive cover for my ptac unit
These units are changed out quite often. You should be able to find you a cover on line. Try any ac parts web site. Russ You will need model number of unit.
Jul 23, 2009 | Amana PTH123B25AM Air Conditioner
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
757 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
