Question about Philips DVP-3005 DVD Player
Philips DVP-3020K not eject my CD
my Philips DVP-3020K isn't ejecting the disc inside. i have faced such a problem before and sometimes it eject it after many many many tries. but now the CD isn't ejecting anymore and there is a stocked CD inside.
i have noticed that once it respond for ejection then it will respond all the time after this... but in case i left it unused for two or three weeks then the problem come again... please help me.!
Hello my friend! my dvd player did the same problem. and i solved this just with a screw driver:) if your dvd player s guaranty finished!! switch off the player and open the screws which r 2 on sides and 3 behind the dvd. open the cover and take off the two group of cables on the chipset which are on the mechanical part side! (mechanical side: dvd driver) than plug the cables again to their socket. its done! close all and go on ! i hope this will solve your problem as mine...
Posted on Feb 18, 2009
  • kaktuscicek Feb 18, 2009
    i wrote the solution in my first post but first of all try this!
    unplug the dvd player from electricity all and touch the player to a metal which has a ground connection than try. if this isnot okey do the first.
When I turn on my Sony DVP-SR200P DVD player and press the eject button it's turns the DVD player off.
turn on first the dvd player and wait to read a disc inside if no disc inside the tray it will say disc error. if the unit doesn't turn off, eject now the the cd tray. if get turn off, remove the cover then check for an stuck up gear or obstruction in the cd tray assembly. you can check also the power supply board which may have unusual parts like bulged or burnt component parts.
Oct 06, 2012 | Televison & Video
My sony dvp sr200p cannot eject the disk inside. i tried all the 4-digit code but i failed.
From www.sony.com
Unable to eject a disc.Solution
Follow the steps below to troubleshoot this issue.
IMPORTANT: If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online through the Manuals/Specs/Warranty link on this page.
  1. Ensure the child lock feature is disabled.
  2. Attempt to open the disc tray.
  3. If the issue is not resolved, turn off the DVD player.
  4. Unplug the power cord from the electrical outlet for 30 seconds.
  5. Plug the power cord back into the electrical outlet.
  6. Attempt to open the disc tray.
  7. If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
  8. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
    NOTE: This step may not apply to all models.DISC1 is not available on all DVD players.
Feb 29, 2012 | Sony DVP-SR200P DVD Player
How to eject a cd in a dell XPS m1330 when the hardis has crashed and the disk inside isn't a operatindg system disc
Straighten a paper clip and insert it into a tiny hole below the CD drive tray. Push the paper clip gently into this hole and the CD tray will pop out slightly. Pull the tray out to the fully opened position so you can remove the disc.
Dec 28, 2011 | Dell Computers & Internet
I've recently bought a Sony DVD/ CD player DVP-SR650P. Its accessoies includes a remote RMT-D187P. The remote does not have an open/close/eject button. How to eject the disc tray with the above DVD player...
There is no eject etc button on the remote control because what use would it be? To insert or change a disc, the operator would have to be in reach of the drawer with a disc to hand.
Mar 06, 2011 | Televison & Video
My Cd Player in my car wont take in any discs
Hello you probably have one stuck inside use a flash light press eject and see with your flash light if a disc is surfacing sometimes they get stuck and need a little bit of pres-wading.if this is not the situation perhaps your cd carriage is stuck in eject position if so you will need to have a service technician repair it.
Jan 08, 2011 | 2000 Ford Focus
JVC won't eject my CD!
Turn radio off Push and hold the eject button Turn radio on while holding the eject button.
This is the force eject sequence
Apr 05, 2010 | JVC AM FM CD DET FACE CAR STEREO
My disc drive won't eject.
If there is CD/DVD stuck inside:look for a small hole on the face of the drive and insert a paper clip, and press a bit, the drive will open.
If that does not do the trick, look for an icon on the systray (where the clock is shown) . It represents a square inside which there is disk.The tooltip (bubble) should read Optical Drive Power (on or off). If you click on it it shows a two item menu Power On Power Off with a tick mark near one of them. Click Power ON.
Hope it helps.
Sep 07, 2009 | Gateway Computers & Internet
Philips DVP 5992 DVD player disk tray opens without a disk
it think you should open the unit up.get the cd.then try to play it again.
May 18, 2009 | Philips DVP5990 DVD Player
Wii console will not eject disk
I managed to eject a WII disc out manually very easily:
- Disconnect the drive
- You see the white plastic mechanism on your right side and the wheel connected to the motor
- turn the wheel towards the back side of the drive while pushing the half inch square plastic piece towards the left.
You will see the disc coming out while you are turning the wheel.
Nov 25, 2007 | Nintendo Wii Console
Philips DVP-3005 DVD Player Logo
588 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
