HOW DO I CONNECT WIRELESS HEADPHONES TO MY HOME HDTV/Sony DAV X1 SYSTEM? I am trying to hook up wireless headphones and need assistance. Components are as follows: - Sony DAV-X1 DVD Home Theater System (which lacks a headphone jack or set up instructions to accommodate headphones) - Brookstone Wireless Tv Headphones - Samsung HP-S4253 Plasma TV Can anyone offer advice? Much obliged!
  • Ted Simon Aug 28, 2012
    I've been asked by FixYa to add more information. Let's try this. Does anyone know if you can connect a wireless headset to the Sony DAV-X1 home theater system? I've searched all over the Internet, and I've yet to find a solution. See above for details on system. Thanks!
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Audio Player... Master
  • 1,001 Answers
Bluetooth Headphones V3.0 Handsfree Stereo Wireless Headset with Microphone earbuds for Apple and Samsung LG Amazon com Charm sonic Bluetooth Headphones V3 0 Handsfree Stereo Wireless...
Posted on Dec 14, 2016
    New Friend:
  • 3 Answers
Did you get a small USB receiver that you can insert into the USB port of your television system? This usualyy works here, but 'here' is Belgium.
Posted on Aug 28, 2012
  • Ted Simon Aug 30, 2012
    Thanks, Lut. Yes, I do have a USB receiver. I believe the issue lies in the fact that the Sony DAV-X1 does not have any headphone ports or connection capabilities. Appreciate your trying to help!
  • Lut de Potter Aug 30, 2012
    Hi Ted, OK, I see where you're coming from. I didn't know that the DAV-x1 doesn't have any ports. Hope you'll find a solution anyway. Good luck!
4 Suggested Answers
SOURCE:
SOURCE: just bought the brookstone wireless tv headphones.
just received Brookstone Wireless TV headphones as a gift, trying to connect to Samsung Hi-Def mode HLR5067WAX/XAA. There is not 'headphone' jack so I connected the 3.5 mm to a pigtale for a RED-White cable.... any one have information on where the R-W cable is plugged into for sound???
Posted on Nov 25, 2010
  • 11 Answers
SOURCE: Is it possible to connect this model of wireless
So long as there's a regular 3.5mm headphone jack on the Samsung home theatre system, then yes they should work. If not, I would try hooking them up to your HDTV directly.
Posted on Mar 02, 2011
  • 11800 Answers
SOURCE: New Sony MDR-DS6500 wireless headphones.
Simple test to see if the unit is functional: get a cable like
http://www.amazon.com/3-5mm-Stereo-Male-Cable-ft/dp/B002T4OMG8
plug it in the headphones output from your pc or whatever device which you know it works since you are using it with other regular headphones (even a phone will do) and see if you hear something. If you don't then it's defective, if you hear then the problem is with your HT.
The biggest one is the fact that the only way in which this HT is capable of delivering sound to another unit is thru the wireless S-Air connection which the wireless module from the headphones doesn't support - it can connect strictly only to the module from its base which accepts only cabled connections, which your HT doesn't have..
To put it simply there is no way to connect this headphones to this HT. If you want to use those headphones you will need to get a real receiver and use this HT strictly as an BR player.
Posted on Sep 11, 2011
How to hook up wireless headphones
Haley, I have never done it, but it does not sound too hard. Read through the following links below to find out how to hook up wireless head phones.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.jabra.ca/q/how-wireless-headphones-work-how-to-connect
How to set up Wireless Headphones with the TV How Tos
How To Connect Wireless Headphones
Logitech Support
Apr 21, 2016 | Audio Players & Recorders
Sony DAV-IS10 doesn't get video and sound from Samsung 3D Blu-ray Player.
change the input settings on the SONY. sometimes there are are HDMI INPUTS AND OUTPUTS on high end systems. Make sure you are in INPUT
Mar 10, 2014 | Sony DAV-IS10 System
I bought wireless headphones, how do i connect them to the TV wirelessly
Normally the wireless headphones have a transmitter that send audio via wireless to the wireless headphones.
The transmitter needs to be plugged into the headphone outlet on the TV. This will switch off the speakers on the TV and sends the audio to the wireless headphones.
Sep 23, 2012 | LG 32LG30 32 in. LCD HDTV
Is it possible to connect this model of wireless headphones to a Samsung HT-C5900 Home theatre system?
Mar 02, 2011 | Philips SHD8900 Wireless Headphones
Where do I plug my headphones into a Sony DAV-FX900KW home theatre system? I'm playing X-Box 360 (on TV/VCR1) but can't get any sound off my Philips wireless headphones. Appreciate any help
There is a headphone jack on the Sony's front panel, on the right near the bottom edge. Connect the sender part of your wireless headphones to that jack. You may need some form of adapter depending on the sender's input connectors. If the wireless headphone system is working properly, this will give you sound.
Dec 03, 2010 | Sony Audio Players & Recorders
How do i get rid of the Muting On?
Press the Muting Button or Volume +, remove headphones.
Mar 27, 2010 | Sony BRAVIA® DAV-HDX576WF Theater System...
Wireless headphone hook up
Hello depends on how you hook it up as thee are several ways.
many receivers will output sound through the headphone jacks even when the speakers are left on.(my receivers require that you manually turn speaker A off when using headphones)
it may be possible for you to connect the headphones to a tape output but this will require headphones that have a volume control on them or an external.volume control knob.. You may encounter a problem as I am not sure if a tape output will provide enough signal to drive a pair of headphones. this would not be a problem if you use a pair of WIRELESS headphones as they have their own power source onboard..
A set of wireless headphones could also easily be connected to the output on the back of the TV but assuming you have your receiver plugged in to the TV audio out you may need a couple of Y adapter cables.
Also if your receiver has a pair of PRE OUT jacks those would work to power a set of wireless headphones may also power a wired set but once again not sure on power as I have never needed to try it.
Hope that helps a bit
Jan 09, 2010 | Audio Players & Recorders
Getting sound to TV from DVD Home Theatre System
lght304su home cinema,how to connect to tv to get sound through
Dec 29, 2009 | Sony DAV-SR2 System
Sony dav-x1
The simplest solution would be connect the headphone jack on the iPod to the stereo audio inputs (RCA) to your home theater. So you need a cable that is "stereo phono mini jack" on one end (into iPod headphone jack), and then Y-splits into two RCA connectors on the other end (into L and R audio in on the receiver).
The expensive Apple-endorsed Monster-branded version can be found at http://store.apple.com/us/product/TN983LL/A#overview for $30, but you can get the same thing at Radio Shack for $7.
http://www.radioshack.com/product/index.jsp?productId=2102974&cp=&sr=1&origkw=phono+jack+rca&kw=phono+jack+rca&parentPage=search
Set the iPod volume to less than ~80% and then control the volume using your receiver. You have to use the iPod menu to select music.
May 12, 2008 | Sony DAV-X1 System
1,001 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
