Question about Hotpoint RGB745 Gas Kitchen Range
Hotpoint Range NOISE problem
Some sixty-plus hours ago we were baking pizza at our usual 550 degree temp in our gas oven when the F2 signal flashed on in our clock display. Simultaneously, the stove began to emit a very high-pitched sound that resembles the ringing in your ears. Well, we have done everything from removing the oven sensor to turning off the power to the ENTIRE house, but the sound will not stop. AAArrrrgggghhhh! No pun intended, but has anyone ever heard of such a thing? While some have suggested that this is powered by a battery somewhere, why would Hotpoint power an oven alarm but not the clock? We have ordered a new oven sensor, but it has yet to arrive.
  • Peterrr May 19, 2008
    We have the same problem.
I found the solution. The mercury light (according to my land lord) has crude and build up on it. This was located beneath the oven in the broiler. When it was cleaned the ringing stopped.
Posted on May 21, 2008
The oven will pre heat to set temp, then when it reaches temp the oven beeps and both oven elements turn off. At this point the control panel (clock LED) shows an F2 error.
Good afternoon.
F2 for hotpoint means oven temp sensor thinks oven exceeded 650 degrees .Did that happen?
Probably not so have your sensor checked or replaced. It should be a probe device in oven back wall.
Was this helpful?
Aug 16, 2011 | Hotpoint RB787 Electric Kitchen Range
My GE profile gas range jgbp79wewiww the clock blinks f-2 and i have to light the burners with a match tks for any help
Hi There
I have found the code for and hope this helps you.let me know how it goes.
F2 During Bake Control senses oven temp above 590 degrees F High resistance connection in oven temperature sensor circuit. Check Electronic Range Control (ERC) - Welded bake relay contactsThank you for writing to fix ya.
Best Regards Richard
Mar 20, 2010 | GE Profile JGBP79 Gas Kitchen Range
Need to adjust oven temperature on a Croley gas range
you shouldnt need to adjust the burners for a temp problem.
the control has a built in calibration setting and it should be described in your owners manual.
if you dont have the manual, then try to set the oven temp to max, 550, and then hold the bake button in for 10 to 30 seconds. after that it should beep and show you a 2 digit number like 00. that is the calibration mode, then you can adjust it up or down +/- 35 degrees. try to make a small adjustment first like 10 degrees and see how it bakes.
if it takes too long to bake, then use + degrees, if it is burning things then lower -10 degrees.
hope that helps you.
Jan 03, 2010 | Crosley CE35100AA Electric Kitchen Range
I tried to cook a frozen pizza in my Tappan electric range last night (which required it to be preheated to 400 degrees) and it would not preheat at all, even after about a 3 hour wait. I just turned up...
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5153992&diagram_id=1251523#d1251523
your looking for part number 67 on that part breakdown
it is the bake element and if you inspect it im sure you will find it cooked or broken
befor you actually order the part take the unit out
unplug it
and inspect your wire connections to both sides of the element
Oct 17, 2009 | Tappan 30IN ELEC IGNa Oven
Hi. I have a ge convection oven(JCTP17) that has been working great until recently. I bought a Taylor oven thermometer model number (503) To check othe oven temps to see how accurate the oven is. I do a...
The Taylor oven thermometer you bought is decent at best. It is most likely the sensor inside the oven. Has your clock displayed any fault codes? F, followed by a number? Changing the sensor will probably correct the problem.
Aug 19, 2009 | Ovens
Oven cooks 10 degrees cooler. How can I fix it?
select bake
set the oven to 550 degres
hold the bake button until you see the temp go to zero
push the temp select up until it changes in five degree increments to the desired bump up in temp you can raise it or lower it up or down by 35 degrees in five degree increments, once you have the desired adjustment it will revert back to normal on the controls screen readout
check the oven temp and adjust as necessary, this info is available in your users manual as well.
Jul 14, 2009 | Maytag MER5775Q Electric Kitchen Range
Hotpoint oven
Press the function you want - say bake - the set the temperature by pressing the plus sign (+) to increase the temp to that which you desire then press start
Regards
Aug 25, 2008 | Hotpoint RGB745 Gas Kitchen Range
Flashing F2 while the oven is on
f2 is a faulty oven temp sensor. need to replace the sensor. located in the oven cavity 2 screws hoding in protrudes 3-5 inches out thin metal cylinder
Mar 16, 2008 | Hotpoint RGB745 Gas Kitchen Range
Ge gas oven/ranger xl44
The F2 is the code for the board seeing a temp higher than 600 degrees. It could be one of two things. The temp sensor is out of range, extreme high resistance. If you ohm it out it should read approx 1100 ohms at room temp. The other would be a welded bake relay on the board itself. Check the temp sensor first. If you are getting the F2 in the cleaning cycle, check the temp sensor, welded clean cycle contacts on the board or both contacts on the lock switch are closed at the same time. This is for the model posted JGBP90.
Nov 24, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven not working
Something wrong with knob , the adjustment i s still in close position , and cover with warranty period let them fix the adjusment by company where you bought it.
May 29, 2007 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
498 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
