Question about Philips RC282427/01 Remote Control
Phillips remote controle model no rc 2563/01
Phillips remote control model no rc 2563/01
menu button when pressed wont show on screen.
  • 45 Answers
SOURCE: How to open a Phillips remote control???
force it by using a thin-tip flat screwdriver on its side, then to all sides until it will be open.
Posted on May 17, 2007
  • 230 Answers
SOURCE: universal remote magnavox model # CL034
here you go
http://www.universal-remote.net/philipsmagnavox.html
Posted on May 15, 2008
  • 520 Answers
SOURCE: phillips universal remote codes
http://www.urc.philips.com/
Posted on Sep 11, 2008
Happy2Help
  • 59 Answers
SOURCE: I need codes for a phillips tv and a phillips universal remote?
Hi michaeljlent,
There are a number of codes for your remote that correspond to Phillips TV models. They are:
002 009 109 202 209 210 310 402 408 508 510 807 901 914 917
For your reference, here's a web address where all the codes for your remote are listed (along with programming instructions):
I hope this helps - please let me know if I can be of any further assistance.
Posted on Dec 12, 2008
SOURCE: Teknique Jumbo Universal Remote Control Instructions
Pacific TV - Press "SET" and Hold it, press "TV" and release it, then release "SET", then type one of these codes 0676, 0677, 0678 or 0679. After each code try powering off the TV using the remote. One should work. (I think the 2nd one worked for me).
Posted on Dec 26, 2008
I accidentally changed the settings on my remote control using the on screen menu from dvd1 to dvd2
I'm not sure the question - perhaps your TV is set to the DVD2 input and it's not a DVD issue.
If so, using your TV remote, push the "input" button until you reach your desired input.
Apr 07, 2015 | Televison & Video
Olevia tv 237 rc-ltl how to edit in the menu.
Hi, you can get the manual here 237T operating manual. I would simply read through it. you must press the right arrow to select a sub-menu.
Nov 04, 2013 | Olevia OEM RCLTL RC-LTL Remote Control
Is there a Unlock code for bush btvd91216w
This is everything that I have:
Try this general bush unlock:
Press Open tray
Press 2, 8, 1, 2 and Enter to get to the manufacturers settings
Select the required region, by pressing Enter on 9 for multi region
Press Close tray
If that didn't work, try this:
Try this one:
1. Press the Open button on your remote control to open the drive tray
2. Press the 9 button on your remote control
3. Press the 7 button on your remote control
4. Press the 3 button on your remote control
5. Press the 5 button on your remote control
6. Using the on screen menu, highlight the region option
7. Press the Right button on your remote control
8. Using your remote control, select 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
9. Press the Enter button on your remote control
10. Press the Open button on your remote control to close the drive tray
Then there is the following and good luck:
Bush 1000
  1. Open the tray
  2. Insert a disc with desired region code, but do not close the disc tray
  3. Press 0, 1, 2, 3, Play
Bush 1005 / 2004A / DVDAV7
  1. Press the OPEN/CLOSE on the remote
  2. Press 3, 3, 0, 8, 8
  3. Press the button for the desired region or 0 for multi-region
  4. Press OPEN/CLOSE
  5. The on-screen display will now indicate the currently selected region
Bush 2000
  1. Open the disc tray
  2. Insert RC-1 DVD, don't close the disc tray
  3. Press 0, 1, 2, 3
  4. Press PLAY
    To activate RC 2:
  2. Insert RC-2 DVD, don't close the disc tray
  3. Press RETURN and PLAY
Bush 2002 / 2004
  1. Press OPEN
  2. Press 7, ENTER, 7
    A menu should appear (codefree=13)
    Method 2:
  1. Press OPEN
  2. Press 2, 0, 0, 1
Bush 2005 / 2008 / 2009
  1. Turn on the player
  2. Press OPEN/CLOSE
  3. Press ZOOM
  4. Press A/B
  5. Press Up, Left, Down, Right
    A note should be displayed.
  6. Turn it off
  7. Turn it on
Bush 2023 / 2024 / 2523
  1. Press OPEN
  2. Press 2, 8, 1, 2, Enter
  3. Set the country code to 13 and press Close
Bush 2028
    already region free
Bush 2039
  1. Press OPEN
  2. Press PROG
  3. Press ENTER three times
  4. Use UP/DOWN to select region
  5. Press STOP several times to set the region
Bush 2047
  1. Press OPEN, SETUP
  2. Go to "Preferences"
  3. Enter 2, 8, 1, 2
  4. Use UP/DOWN keys to select the region
  5. Press SETUP, OPEN
Bush DVD-102
  1. Press OPEN/CLOSE
  2. Press 2, 0, 0, 1
  3. Press ENTER
  4. Select RC (codefree=13). You can disable MacroVision, too.
  5. Press OPEN/CLOSE
Bush DVD-142TV
  1. Press DVD function on your TV set
  2. Press DVD Setup on the remote
  3. Press 1, 3, 6, 9
  4. Press Left three times
  5. Press RIGHT once
  6. Select VERSION
  7. Change the region code
Bush DVD-143TV
  1. Press DVD/TV, DVD
  2. Open the tray
  3. Press SETUP, Right, Left, Down, Up, Display
  4. Enter 0 (or 1-6 for other RC)
  5. Press Enter
    VCD/SVCD playback
  1. Press SETUP on remote
  2. Press Next, Prev, Next, Prev
    Ver should appear in the top right
  3. Change 3001 to 3000
  4. Change 5001 to 5000
Bush DVDAV11K
  1. Open the tray (be sure to be in stop mode)
  2. Press SETUP, Next, Prev, Next, Prev
  3. Select 255 for region free (use LEFT/RIGHT)
  4. Press SETUP
Bush DVDR3000
  1. The disc tray has to be empty
  2. Press TV/DVDR
  3. Press RETURN, DISPLAY
  4. Enter 8, 8, 8, 0
Bush DVHS1
  1. Press the DVD button on the remote
  2. Press OPEN
  3. Press 0, 5, 2, 0
  4. Press UP, DOWN, LEFT, RIGHT
  5. Change the region (0 = multi-region)
Bush DVRHS02
  1. Push SETUP button on the remote
  2. Select SYSTEM INFO on the menu
  3. Enter 1, 1, 0, 1
  4. It shows the current region code
  5. Push 0 on the remote for region free
Bush 2001 / 2020 / 2026 / 2029 / 2035XI / 2038 / 2042 / 5020 / BTV213DVD / DVR3000 / DVRS01 / PDVD0707 no known hacks
Jun 12, 2012 | Bush Televison & Video
Sharp Aquos RC Control Lock and Operation Lock Out
When all else fails read the owners manual page 35:
"• To unlock the buttons on the remote control by using the
touch sensor panel of the main unit (see page 25):
1 Press MENU to display the MENU screen, and then
press VOLl/k to select "System Options".
2 Press CHs/r to select "Operation Lock Out", and
then press INPUT.
3 Press CHs/r to select "Off", and then press INPUT.
4 Press MENU to exit.
• To unlock the buttons on the TV, press MENU on the
remote control, and then select "Off" in "Operation Lock
Out".
Apr 05, 2012 | Televison & Video
My tv wont come back on fpa lock on
Press Menu Button from any Remote control ( RC) by which could turn on your TV, press menu , menu drop down list will be visible on ur screen then wait 4 a minute or more till ur RC stop blinking , then go to Preference menu , go to FPA lock, turn it off. enjoy.
Deva
Apr 21, 2011 | RCA 20F420T 20" TV
HI THERE I GOT THE PHILLIPS MICRO DVD HOME THEATER MCD388 unfortunatelyTHE LAST SUMMER WENT TO THE UK AND THE USA AND I CANT PLAY ANY OF THE DVDs can anyone help me with a region code????
1. Ensure there is No Disc in the player
2.Press Remote Control (RC) "SYSTEM" key to enter DVD system setup menu;
3.Press RC "direction "key to hightlight the forth item "PREFERENCE PAGE" (not
entering the sub-item );
4.Press RC numeric key sequentially 811502(entery code,no display on TV);
5.Press RC "down direction" or "up direction" key to change REGION CODE,"0" is
all code.
6.Press RC "OK" key to confirm.
7.Press RC "SYSTEM" key to exit DVD system setup menu
Jan 15, 2011 | Philips MCD288/37 DVD Micro Theater System...
How to unlock the MENU button on my TEAC RC-1058 remote control
Yes I know press timer and it will take u into the menu........
Jul 31, 2010 | Teac USB2 TV TUNER (USB2TVTUNER) Video...
Phillips Portable DVD Player DCP750/37 says "Wrong Region"
To change the region on the Philips dcp750
2. Press the Setup button on your remote control
3. Press the Right button on your remote control
4. Press the Right button on your remote control
5. Press the Right button on your remote control
6. Press the 9 button on your remote control
7. Press the 6 button on your remote control
8. Press the 5 button on your remote control
9. Press the 3 button on your remote control
10. Using the Up and Down buttons on your remote control, change the region to 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
11. Press the Setup button on your remote control
Mar 13, 2010 | Philips Televison & Video
IR remote-Bizare Problem
Okay I am a bit confused as to the exact problem you are having but I will give you multiple avenues to resolve thios issue.
Assuming that the issue exists with TV1's remote:
Some IR remotes experience interference with other peripherals at times. The easiest way to resolve this is to get an 8.0 remote that is IR/UHF capable.Using the front panel buttons or the old remote place the receiver into UHF Pro mode by pressing menu-6-1-6 . You should be on UHF Pro setup: move the highlight to the left and go to the enable selection, press select and move the highlight back to the right to done.exit out of all screens. Then press the menu button twice to get to the system info screen.Here we will be canging the remote address of the new 8.o remote to the number for the primary remote address. This number is near the bottom of the screen. On the 8.0 press the small SAT button in the upper left hand of the remote and hold until all light on the top light up, enter the number on the screen for the primary remote using the keypad on the 8.0, press the pound sign, the SATbutton should flashh three times, then press the record button. Now you should be able to use the new remote normally. You will need to program the remote to the TV if you were able to control volume and turn TV on and off before. Since this is a different model remote it may or may not be compatible with the TV. If you need assistance with programming the remote to the TV itself just post another request for assistance and one of Fix Ya's Expert will hook you up. You can also find the solution in the archives of previous solutions as that issue is commonly addressed in this forum.
If the issue lies with the TV2 remote I would suggest moving the antenna off the back of the receiver into the room TV 2 is located. This can be accomplished by following the following diagram. If you still need assistance please let me know. I hope this solves your issue.
Oct 03, 2008 | DISH Network IR Remote Control
Multizone code
icon_minipost.gifRegion code hack posted by Tiger1, May 24 2007:
Hi I live in Australia and added this model.
acknowledging: Region code hack posted by ZoidsGodzilla, November 22 2006: for the Samsung DVD-V5600
1. Press the DVD button on your remote (the Samsung logo appears)
2. Press the SUBTITLE button on your remote
3. With your remote enter the code: 76884
4. The current region is displayed on the top left corner of the screen. (e.g. 4)
5. Press 9 on your remote (Region free)
6. Again press the SUBTITLE button on your remote
7. Enjoy the Region free player
If your player is NOT Region 4 by default then you will need to Substitute the Numbers in Step 3 with the ones Below.
Region codes:
RC 1: 2, 9, 3, 3, 4
RC 2: 3, 8, 7, 6, 7 (or 5, 7, 5, 3, 8 )
RC 3: 5, 6, 7, 3, 2
RC 4: 7, 6, 8, 8, 4
RC 5: 5, 3, 8, 1, 4
RC 6: 2, 4, 4, 6, 2
For Example if your Player was Purchased in the usa ( Which is Region 1) then Step 3 would read :-
3. With your remote enter the code: 129334
Have Fun :0)
Mar 25, 2008 | Samsung DVD-V6700 DVD Player/VCR
Televison & Video Logo
338 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
