Question about Sony FD Trinitron WEGA KV-27FS200 27" TV
TV comes on and goes off by itself
The TV will go off for no apparent reason. Sometimes it has to be turned back on with the remote and sometimes it immediately comes back on. The set will also turn itself on in the middle of the night. I have eliminated remote malfunction.
    Scholar:
  • 135 Answers
In order to determine whether it is the TV itself or something in the room that is causing the problem, place an object in front of the infrared eye on the TV. This is usually a transparent red plastic window on the front of the TV somewhere. Verify that it is covered by trying (and hopefully failing) to use the remote. If the TV continues to turn itself on and off, then it is the TVs internal circuitry. If the behavior stops, then it is something in the room. One of the more surprising causes for behavior like this is sunlight hitting rotating ceiling fans -- the light reflects off the fan at just the right frequency to fool the TV. I mention this so you don't limit yourself to only thinking that it must be either the TV or the remote.
Posted on Apr 05, 2007
SOURCE:
Volume pegs to max. Turns itself on. Goes to menu. Intermittent
This is becoz your Internal Remote control response program chip needs to be replaced! You need it to get repaired at nearest service station. Or it may be due to Your keys pressed continously from remote control. Check both the causes! then decide. It will help you!
Dec 23, 2007 | RCA F38310 38" TV
Magnavox 42 LCD 42mf438b/f7 turns on/off by itself sometimes screen goes blank tv unresponsive to remote
I have exactly the same problem with a Magnavox LCD 42", very similar model 42MF437B/37. I don't have a solution. If you unplug the TV and plug it back it starts working, sometimes for hours, sometimes for less than 5 minutes, before it turns off again. Does anyone have any real solution?
Jul 08, 2009 | SNK Magnavox 42MF438B/27 42 in. LCD TV
Remote quit working.....tv comes on and goes off by itself at various times
Sometimes Buttons on remote control "stick" underneath the faceplate. It's possible the on/off button is jammed. A lot of times when a button is jammed the other buttons fail to work.
Could also be the reason you needed to replace the batteries with a button being continously pushed will drain the battery life.
Push every button on the remote and kinda wiggle each button while pushing to possibly see if its stuck.
Hope this helps.
May 26, 2009 | Norcent Technologies PT-4291HD 42 in....
Large black square appears on screen of my Insignia NS-15LCD TV.
Look for the closed captioning (CC) menu in the set up and turn CC off.
Feb 25, 2009 | Televison & Video
My Grundig tv turns itself off
Its Probably overheated.
happened to me before then i took to fixers and they changed some part and now its fine or if u have a warrenty call the manafactuarer
Dec 13, 2008 | Proton MM2701VT 27" TV
** sound
Hide the remote from the set for awhile and see if some sanity returns. If that's the case, service or replace the remote. (Check the batteries first...accordianman
Mar 09, 2008 | Sony DAV-SB100 System
Sony TV keeps flipping to Memory Stick screen by itself
My sony HD TV started automatically flipping to the memory stick screen by itself. I thought maybe the remote was malfunctioning so I took the batteries out of the tv's remote as well as the cable boxes remote. Still does it. If I hit the memory stick button on the remote to switch off the screen sometimes it goes back to TV screen and sometimes it doesn't. Eventually, it flips back to the memory stick screen. Is this a known problem for this TV? your problem in system control section check aft &tuning ckt &its voltages check for loose contact in above ckt check tuner thanks
Sep 09, 2007 | Sony FD Trinitron KD-34XS955 34" TV
Sony FD Trinitron WEGA KV-27FS200 27" TV Logo
74 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
