Question about Tally Line Matrix T6050 Printer
Tally t6045 printing problem
My line printer printings wavy, garbage
  • Anonymous Mar 17, 2014
    Printing coming out with wavy lines
    New Friend:
  • 114 Answers
Hi!
there is two reasons behind this problem.
1. The parallel cable is damaged .
2.The parallel port of your computer is damaged.
so at first changed the parallel cable .if not solved connect your printer to another pc.
i hope the solution will work for u.
Regards
Swarnava Palit
U can mail me your problem- swarnavapalit@gmail.com
Posted on Jan 29, 2009
NEED WIN7 DRIVERS & FIRMWARE FOR T6045
Best option is to add printer in Win 7 using Generic manufacture and generic/text only for printer. Obviously you select LPT, serial or your external printserver IP address.
Should be able to print anything you want.
Except barcode...
If you have problems printing a simple windows test page, let me know, we can figure out the problem.
Thank you,
Toby
As you know those printers are very old, so to get you out of the dinosaur days and into the 80's. You might look at TallyGenicom 6312. It can do everything the T6045 plus multiple times more. We have parts still available for T6045, but if the main logic board goes bad... recycle time
Aug 09, 2016 | Tally Line Matrix T6045 Printer
How to change Tally T2240/24 Matrix Printer character and line spacing
This sounds like an Microsoft Excel issue. The Windows printer driver controls how printing is done regardless of your printer settings.
Excel controls the format of your page with column widths and line height. Depending on your version of Excel, after selecting your print range and your margins, you will need to go to Page Setup and select "Fit to" -- select 1 page wide and a larger number of pages tall.
Jul 25, 2014 | Tally T2240/24 Matrix Printer
Pls i need printer driver for Tally T6045 on window xp platform
Here you go:
download driver to the link below http://drivers.downseeker.com/download/22177/tally-t6045-printer-driver/
thanks for using Fixya
Jun 08, 2011 | Tally Line Matrix T6045 Printer
Tally t6215 is printing continuously, one line a page. how do i make it print normally?
I would suspect this is happening because the system printing to the T6215 is sending only Line Feed Commands and not Carriage Returns. Access the menu on the T6215 and enable the AUTO CR function. This will cause the printer to append a Carriage Return each time it sees a Line Feed, this should resolve the issue.
Dec 22, 2010 | Tally T6215 Matrix Printer
How i can download tally 7.2 from google search ?
Download Tally 7.2 Free from different sites like tallysolutions.com. But for such softwares you need a key or serial number but if you download it and run it in educational mode then you can use it as long as you want.
Jul 22, 2010 | Tally Line Matrix T6045 Printer
Pdf printing is not properly impression on the line priter tally t6090 ,plz help harish
Hi, maybe this TechNote will help you:
http://support.dascomeurope.com/index.php?option=com_content&view=article&id=296%3Apoor-print-quality-when-printing-adobe-acrobat-pdf-files-&catid=234%3Afaqs-t2265-t2280&Itemid=57&lang=en
Mar 12, 2010 | Tally Line Matrix T6090 Printer
Printing wavy letters instead of straight
we have similar problem. my printer is canon mp 145. straight lines become wavy and some letters are italics when printed out. it was corrected when i used print head alignment but that was true when printing from my computer and not when using the copier. when using the copier lines still comes out wavy and i cannot correct it until now. please post when you solve your problem. i hope it will help you and i hope you can help me
Jan 21, 2010 | Canon PIXMA MP160 All-In-One InkJet...
ERROR MESSAGE BLK 1CHKSUM FLT on tally t6045 printer
BLK 1 means your black toner cartridge, and I believe the chksum error may have something to do with the memory file. Check out No. 6 under Unrecoverable errors on this sheet.
http://www.tallygenicom.com/support/technotes/3400/error.htm
This is problably something to be sent in for maintenance.
For this error these are the recomendations:
(Try cycling power; initilizing printer. If error persists, maintenance
service is indicated.)
Apr 27, 2009 | Tally Line Matrix T6045 Printer
Tally printer T6180 Printing problem
There are several reson behind the problem.
1. Check the driver settings & match it with the printer imulation.
2.Check the parallel cable.
If not solved connect the printer to a new pc.
some time computer's parallel port may damaged.
Jan 24, 2007 | Tally Line Matrix T6180 Printer
Tally Line Matrix T6050 Printer Logo
263 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Vasil Hristov
Vasil Hristov
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
