Question about Whirlpool Calypso GVW9959K Top Load Washer
Waaaayyyyy too many suds collecting in drain box after 2 back to back loads!
I've had the Calypso for 6 years. Always used HE detergent. Never had this problem til recently. In the last year, I can't run more than 2 loads back to back - The suds at the drain hose get to be too much & run down the wall! Mr Plumber came & cleared the line - NOTHING was found. I thought for sure a clog was forming. Thus, I think the problem is with the washer. I'm still using the same amount of HE - even trying diff. brands. Doesn't seem to matter. Suds too much. Do you think it's the pump not pumping enough water? WHY would I suddenly need to use LESS HE detergent after all these years? I'm afraid my clothes won't get clean without the proper amount. HELP!
    President:
  • 1,462 Answers
Very much doubt problem is with washer - after all it just takes water in and turns. points the finger at the detergent or over-dosing
Posted on Apr 05, 2007
My Smsung dishwasher always has suds in the bottom after cycle has completed
Couple of questions?
1. do you have a water softener?
2. what type of detergent are you using and how much?
3. is the detergent HE rated?
To clear out the suds run a cup of white vinegar with 4 liters of cold water and run a rinse cycle. or just put a cup of white vinegar into the dishwasher and run a normal load with NO SOAP... you need to clear the suds from the system to work properly again. the proper detergent to use in most new dishwashers is powder style that is HE rated. and don't use a lot either.
Sep 17, 2012 | Samsung DMT300RFS Builtin Dishwasher
My washer stops and suds flash on the display
Sud: Suds lock (overdose of detergent detected during wash cycle)
The motor control unit senses a suds lock condition by analyzing the
current draw on the drive motor. If "Sud" is displayed a potential Suds
Lock is detected. This may signify a bad pump, an extra heavy load,
excessive detergent, or excessive suds.
Possible causes/procedure:
If too much detergent was used:
-Run the unit through a Rinse/Spin cycle.
-Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
Use your tech sheet for diagnostics it is behind that panel the Handy Hippy showed you how to take loose (see above link) Use this MANUAL for Duet sport as a guide for repairs
Thanks for using fixYa
Jan 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer (whirlpool duet) seems to cancel in the middle of load cycle. Most often the word "suds" is displayed. It is not the amount of detergent or the type because I use very little High Efficiency...
SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
The motor control unit senses a suds lock condition by analyzing the current draw on
the drive motor. If "Sud" is displayed a potential suds lock is detected. This may
signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
ERROR CODES
DISPLAY EXPLANATION AND RECOMMENDED PROCEDURE
Suds
6 - 7
Potential Causes
• If too much detergent was used, run the unit through a Rinse/ Spin cycle then a
Normal cycle without adding any detergent. This should clear the unit of the
excess detergent.
• Check the drain hose and make sure it is not plugged or kinked
• Check Wire Harness connections to the Drain Pump, Pressure Switch, and
• Check/ Clean Drain Pump Filter of foreign objects
• Check Drain Pump
• Check the Pressure Switch
• Check CCU
Oct 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Kenmore HE has the "SUD" error message. Why and what do I need to do
HI;The Motor Control Unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential Suds Lock is detected. This may signify a bad pump, extra heavy load, excessive detergent, or excessive suds, due to using a non- HE detergent.
Possible Causes and necessary procedures are as follows:
A.Run the unit through a Rinse/Spin cycle.
B.Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent. Once the unit is clear; Follow the procedures below:
1. Check the drain hose and make sure it is not plugged or kinked.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check and clean the drain pump filter of foreign objects.
8. Verify CCU operation by running a Diagnostic test or any cycle.
Aug 13, 2010 | Kenmore HE2 Plus Front Load Washer
Tried to wash a load of clothes and keep getting an error code "sub". The machine will not complete a cycle, won't rinse, etc. What does the error code mean and how can I fix it?
SUDS LOCK (OVERDOSE OF DETERGENT
DETECTED DURING THE WASH CYCLE)
current draw on the drive motor. If “Sud” is displayed a potential Suds
Possible Causes / Procedure
■ If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
or kinked.
cycle.
Mar 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Sears kenmore washer 110.42822200 error code sud
SUD- Suds lock (Overdose of detergent detected during the wash cycle, or the actual brand is a non HE type)
The Motor Control Unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential Suds Lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
• If too much detergent was used:
A. Run the unit through a Rinse/Spin cycle.
B. Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent. If the problem persist, follow this check list below.
Press PAUSE/CANCEL twice to clear the display.
Dec 07, 2009 | Kenmore Washing Machines
Washer stops and give an SL error code
SL is a suds lock code it can be caused by the drain pump not draining the water, too much detergent, non HE detergent, or extra heavy loads, try running it empty, if code persits it is a computer failure and will need to be replaced.
Please rate my help++++Thanks for using FIXYA
Nov 28, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
It says " suds " in the window but we are using HE detergent
- Run the unit through a Rinse/Spin cycle.
- Run a Normal cycle without adding any detergent.
(If the suds error code continues to illuminate after the above inspections are preformed, replace the pump.)
Oct 17, 2009 | Maytag Neptune Washer
Get error SUD and will not finish cycle
Sep 30, 2009 | Kenmore HE2 Plus Front Load Washer
Whirlpool Calypso Washing Machine
Have you changed detergent? Have you installed a water softener or has your water source changed? Either of these could cause increased sudsing. Suds could be splashing. I have has suds on the lid when I used regular detergent, not HE.
May 11, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
46 people viewed this question
Dan Webster
Dan Webster
Sal De
