Sound Problem Audio Device Is Not Installrd On My Desktop Computer no sound
    President:
  • 2,692 Answers
Rerun the instalation disk that came with either your computer or sound card. It has the sound device(which is software) on it.
Posted on Dec 21, 2008
My computer doesn't detect my speakers, I do have windows 8
Do you have the AC adapter plugged into a live outlet and have you turned on the speakers? Make sure that the speaker signal cable is plugged into the correct port on your computer (the lime green port on a desktop). Check that the correct audio driver is installed for your computer. (With Windows 8, use the Device Manager to check. From the Start Screen, type in Device Manager. Click on Settings and then select Device Manager. Alternatively, Windows key+C on the desktop. Select Settings and then Control Panel. You can find the Device Manager under System and Security or Hardware and Sound.) Scroll down to the Audio devices. Expand the section and look for a red triangle with an X or a yellow triangle with an exclamation point. Try updating the driver (check with the manufacturer of your computer for the latest driver). Even if you don't see the error triangle, try reinstalling the latest driver.
Next check if the speakers work on another computer. If they don't work, the audio cable may be damaged. Try a different set of computer speakers on your computer.
If other known good speakers do not work and the correct audio drivers have been installed, check the audio output devices. Go to the Control Panel > Hardware and Sound page (as described above). Choose Manage Audio Devices. Check if the HDMI port is set as the default audio device. Disable it for a bit (right click on the device) . Sometimes when a new video card is installed, the audio device defaults to this port. This messes up the drivers for the regular audio.) Reboot the computer and then try reinstalling the audio driver. Reboot again.
If it still fails, there is probably something wrong with the audio device hardware. If you are using an add-on sound card, try disabling it and using the motherboard audio device. (A number of add-on sound cards didn't work well with Win7 or Win8. The on-board audio drivers worked better.) If you are using the motherboard audio on a desktop, try an add-on sound card. (Check for Windows 8 compatibility (drivers) before selecting any card.)
I hope this helps.
May 29, 2013 | Kinyo PA-1158 2.0 Amplified Speaker System
Our Compaq desktop computer has internal speakers. For some reason there is no playback sound coming from them though. We bought a new, green audio cord to connect to the CPU and monitor. This still...
Hello
Sounds like the drivers for your audio device are missing or corrupt.
Go to control panel/audio or sound devices and make sure your device is listed and checked to enable.
Next go to Hp compaq.com and find which sound device is in your pc.
Download and install drivers for sound.
Or if you have the cd or dvd that came with the pc the drivers should be on there.
Jan 08, 2011 | HP Compaq Computer Speakers
My computer system is having no sound at all after it was formatted. it is using Windows XP
right click my computer in the desktop click properties then hardware device manager expand sound audio & video controller you will see your sound driver if the driver is marked with yellow question mark reload the sound device driver and restart your system if there is no yellow question mark click start settings control panel double click sound and audio device in device volume move the slider to full and leave the mute unmarked and click OK
Dec 08, 2010 | HP (400745-001) Sound Card
No sound or volume in my computer even i had a computer speaker installed in my desktop. when i go to sound, audio device, it says that there is no audio device... how can i install one and what audio...
you need to install sound driver for your computer. or you do have sound card hardware in your computer. check the systems manager if you have
Nov 13, 2010 | Computers & Internet
My sound card on my desktop PC is not working
If it is on board sound then first check in bios that sound audio device is enable. For that when you power up the computer press F1 or F2 or del or ALt+F2 to enter in bios then go to pci configuration and make sure audio is enable then save settings and exit. If it was already enable then make sure audio driver is installed and working fine. You can check it in device manager. Right click on my computer icon then click on property then click on hardware->device manager then you can see all drivers list then make sure audio driver is installed. If still same issue then uninstall audio driver from start menu->control panel->add remove programs then reinstall driver from disk. If you haven't driver disk then download audio driver from desktop menufecturer web sites then install then it will work fine. If you have sound card installed in PCI slot of cpu then open cpu cabinet then reconnect sound card in another pci slot on motherboard then reinstall audio driver then it will work fine. Also make sure there is not any loose connection on sound jack and speaker cable.Make sure in control panel sound property there are not any mute sound. Play song file in window media player and make sure sound is not mute on it. Then check. Let me know if you need further assistance. Thanks for using FixYa.
Aug 04, 2010 | Intel Celeron -D 2.26Ghz Computer System...
How can i find the sound card manufacturer name ?
Please try to check your audio by right click (mouse) My Computer icon (on the desktop screen) > click Properties > select Hardware tab above > click Device Manager tab > click +Sound, Video & Game Controllers > double click your selected Audio Controller device- wherein you can see if the device status is working properly as well as if the Device Usage is Enabled, if not click Troubleshoot tab.
Or you can also check your Sound / Control device thru Start > Contol Panel > Sounds, Speech & Audio Devices > Sound & Audio Devices - wherein you can adjust the volume & test your sound. best regards
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Sound is now unavailable
Or you will have to reinstall the sound driver. best regards
May 21, 2009 | Gateway FPD1775W Monitor
No sound
1)Check the leads connected to speaker
2)un-install and re-install
3) control panel..sound and multimedia and check the properties.
Hope that helps....keep the hope :)
May 20, 2009 | HP Compaq Business Desktop d330 Slim Tower
How can i enable the sound of my computer?
Start>Control Panel>(Sounds, Speech, and Audio Devices>)Sounds and Multimedia (or Audio Devices)
In here go to Audio (tab at the top). On the sound playback device select, "Volume." Move the main audio playback slider up to increase the volume.
If for some reason there are no audio devices listed in the Sound control panel (unlikely), there is a possibility that your audio ports have been disabled (again, unlikely).
Go to your device manager by right-click My Computer (Either located in your start menu or on your desktop) and go to Properties. Now select, "Hardware." In here click the button, "Device Manager."
The device manager should appear. Look at, "Sound, video, and game controllers." If anything in this category is listed as disabled try enabling it, then exit the device manager.
Jan 30, 2009 | Audio Players & Recorders
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
