Rinse cycles are usually with cold water. If it cant fill with cold water, it wont go through the rinse cycle. Make sure it fills with cold on a normal wash. You may find its filling with hot only. Alternatively, the machine may not be pumping out properly, this will cause a similar fault. Check to see the machine is draining at the end of the wash. check the pump and the filters for blockages or lint etc clogging the hoses or pump.
there could be 1 of 2 problems with your unit and it`s not the start switch, if the water is not filling the likely problem is ether a defective water level censor unit, it is located at the end of a rubber tube and is disc shaped with the tube at the bottom and a wiring harness at the top, the other possibility is a defective water control solenoid located at the inlet of the water hoses, you can easily check the solenoids with an ohm meter, check for continuity across the 2 contacts located on the solenoid , the easier way to check the solenoids is if you use cold water only in you wash, select hot water, this will enable the hot water solenoid, if it still dos not fill then it is your water level censor that is defective.
OK buzzing sound, hmmm, need to know more than that, dos the water fill ??,,if not disconnect the water hoses at the machine and check the filter elements in the intake water side they might be plugged, if the unit fills with water then the starter capacitor at the motor might be defective. good luck
The pressure switch, also called the water level switch, is what control the amount of water goes in the machine, If your machine is constantly filling to the overflow point, then that is your problem. Now, if water is going in and the level is staying the same then your machine drain line is lower than the pump and your siphoning out the water as it goes in. Pull the drain up a little a that should fix the problem.
the ring where the buttons are should unscrew and the full unit should pull out,if that dos,nt stop the water try to gently pull the plunger up, if that stops it push the plunger back in to flush toilet,see if plunger returns to normal position and water stops, if that dos,nt work have it checked out by aservce engineer.
Did you bleed the cooling system - that's usually why level drops at "Fill tank". It's not an overflow reservoir, coolant actually circulates through the tank. I would pressure test the cooling system, maybe intake is leaking or there's a crack in block. (Note: these motors are sleeved and have been known to have sleeves drop) - here for your ref: download this service manual - "RAVE" (Rover Bible) http://www.landroverresource.com/
you either have a blown head gasket or cracked head both reasons will put compression gas into coolant system since air gets hotter faster than coolant any air in system will cause very fast over heating and push coolant out. the ford 3.0 is has a record of this problem the fix is not cheap and if you do it your self or have a shop do it both heads should be done and the t stat also replacing water pump would be wise
