Question about Intel Motherboard
Can't get past ''entering setup'' 915g
Changed the hard drive because of input-output errors, (formatted it on another pc), now I cannot get past the ''entering setup'' pre-bios splash page. I changed the motherboard battery, not sure if it is fully-charged, but I can chk it with a multimeter later; I cannot see where or how I might try clearing the cmos. (There be no dip switch or obvious jumper bracket) I do see some print on the m-board saying ''clear cmos'' but it's just 3 solder points.
I am wondering if the PS 350 watt is failing. The vid card is an x850xt, i read it may need a ps with a 18amp feed wire? A PS with more watts, eh watt?
Should i chk the ps with my multimeter? Please provide step-by-step idiot-proof instructions.
Hope this ****** gets working before xmas, my kids will be appreciative, and so will I!
Regards and thanks in advance.
Wendy Bradley
williamfelixbradley@gmail.com
  • 1 more comment
  • williamf Dec 22, 2008
    Tried removing the battery again, overnite. No change. Still awaiting your kind advice.
    Wendy
  • George Bill
    George Bill May 11, 2010
    power supply may be too small they ask for 450 minimum for vista, with a video card, see what you have lying around or disconnevt all but the HD
  • George Bill
    did you format NTFS, you sound like you know what you are doing,also did you try running the hard drive alone, without the dvd attched, it may be a slave master setting on the drive.the 3 solder points don't have pins on the other side?, I hate to think they want anyone to short the out by jumping the pins, but that is what it sounds like, try holding the meter accross two of the 3 pins with the batt in and out lets see it the voltmeter drops, let me know, i'll be in and out
    President:
  • 2,692 Answers
To clear the CMOS remove battery. MAybe short the three solder terminals you were refering too,or just short out the two battery terminals, that will work. Reinstall the battery.
Posted on Dec 22, 2008
My satellite Toshiba L875D-s7230 says bootmgr is missing press ctrl alt and delete to restart and does nothing
Which operating you are using?
Method 1: Run Startup Repair from Windows Recovery Environment (WinRE) To run Startup Repair from the Windows Recovery Environment (WinRE), follow these steps:
  1. Insert the Windows installation disc into the disc drive, and then start the computer.
  2. Press a key when the messagePress any key to boot from CD or DVDappears.
    If your PC does not detect the media automatically
    1. During the restart process, read the screen for any instructions that explain how to interrupt normal startup and enter the basic input/output system (BIOS) setup utility. Most PCs use the F2, F10, ESC, or DEL key to begin the BIOS Setup.
    2. Look for a tab in the BIOS Setup Utility that is labeledBoot Order,Boot Options, orBoot. Following the directions on the screen, use the arrow keys to go to theBoot Order, then press Enter.
    3. Locate the CD, DVD, or USB flash drive (this might be called Removable Device) in the Boot list. Following the directions on the screen, use the arrow keys to move the drive up so that it appears first in the Boot list. Press Enter. The boot order sequence is now changed to boot from the CD, DVD, or USB flash drive.
    4. Press F10 to save your changes and to exit the BIOS Setup Utility. SelectYes in the confirmation window. The PC will restart.
  3. Select a language, a time and a currency, a keyboard or input method, and then clickNext.
  4. ClickRepair your computer.
  5. In theSystem Recovery Optionsdialog box, select the drive of your Windows installation, and then clickNext.
  6. At theSystem Recovery Optionsdialog box, clickRepair your computer.
  7. Click the operating system that you want to repair, and then clickNext.
  8. In theSystem Recovery Optionsdialog box, clickStartup Repair.
Method 2: Rebuild the boot configuration data (BCD) from Windows Recovery Environment (WinRE)
  1. Put the Windows installation disc in the disc drive, and then start the computer.
    4. Press F10 to save your changes and to exit the BIOS Setup Utility. SelectYesin the confirmation window. The PC will restart. Allow the PC to restart normally. The scan will take a few minutes and remove any malware that may be infecting your computer.
  3. Select a language, a time, a currency, a keyboard or another input method, and then clickNext.
  5. Click the operating system that you want to repair, and then clickNext.
  6. In theSystem Recovery Optionsdialog box, clickCommand Prompt.
  7. TypeBootrec /RebuildBcd, and then pressENTER.
Jan 20, 2017 | Toshiba Computers & Internet
How do I change the boot order ? It some how changed after I formatted the hard drive it turns on but it wont read install cd or flash drive so can any one help me ?
Enter BOS setup
F1 or F10 Enter Setup at the red Compaq logo or blue HP logo
Boot menu Below is a summary of what is contained on the Boot tab of the BIOS Setup:
  • The order for the bottom process; for example: Removable devices, CD ROM, and hard drive.
  • Boot-time Diagnostic screen
strongly urge to update bios too when possible.
Apr 01, 2016 | HP Compaq Cq60-211dx Intel Celeron...
Non system disk or disk error
Hi is the bios detecting the hard drive? Are you able to open the laptop and chek if the hard drive is correctly plugged into mother board
Feb 06, 2013 | HEWLETT-PACKARD 625 Notebook PC
IO error
The message "The Request Could Not Be Performed Because of an I/O Device Error" appears when Windows is unable to read the data on a storage device.
If this error message appears when attempting to access the files on an input/output
(I/O or IO) device, such as an external hard drive, the file system on the drive could be damaged, the drive could be infected with a virus or the data connector inside the device enclosure could have come loose.
If troubleshooting the drive fails to fix the IO device error, formatting the drive might repair the device.
Connect the external hard drive to the computer.
Run an antivirus program.
Click the "Scan" tab or button, then click "Custom."
Uncheck all items in the list except for the drive letter assigned to the external drive.
Click "OK." Click "Scan" or "Scan Now" to run a virus scan on the hard drive.
Quarantine or remove any infections the virus scanner detects.
Click "Start." Input "cmd.exe" into the search field.
Press "Enter" to open Command Prompt. Input "chkdsk <drive>: /f /r" into Command Prompt.
Replace "<drive>" with the letter assigned to your external hard drive.
Press "Enter" to run CheckDisk on the drive.
CheckDisk will search for and repair detected errors or bad sectors.
Burn the files on the external hard drive to a set of DVDs or move the files to another drive, if possible.
If the IO device error reappears when attempting to move the files, disconnect the external hard drive from the computer.
Remove the power adapter from the drive.
Check the documentation included with the drive for instructions to take the drive apart.
If no instructions are available, contact the manufacturer for instructions or find out if disassembling the drive will void the drive's warranty.
Remove the screws securing the faceplate to the drive or from the edge of the enclosure. Insert the edge of a small, flathead screwdriver in between either side of the enclosure to wedge both sides apart.
Check the connections to the drive.
Confirm that the IDE or SATA interface is plugged into the back of the drive.
Reassemble the external hard drive, reconnect the power adapter and reconnect the drive to the PC.
Attempt to access the files on the drive.
If the IO device error reappears, return to Command Prompt. Input "format /fs:fat32 <drive>:" into the command-line prompt.
Replace "<drive>" with the letter assigned to the external hard drive.
Press "y" when the message "Proceed with Format (Y/N)?" appears.
The process will format the drive, erasing all data on the disk.
If the drive still fails to function after format, you will need to replace the drive.
Hope this helps
Nov 25, 2012 | Western Digital WD5000AAVS 500 GB SATA II...
My hard disk shows me IOCTL error while trying to format it
Input / Output control error. Hard drive is not configured or attached correctly. Check BIOS and connections.
Nov 23, 2012 | Computers & Internet
I/O error on Buffalo HD-PET500U2 Ext Hard Drive
If this error message appears when attempting to access the files on an input/output (I/O or IO) device, such as an external hard drive, the file system on the drive could be damaged, the drive could be infected with a virus or the data connector inside the device enclosure could have come loose.
Hope this helps
Nov 16, 2012 | Buffalo Technology Computers & Internet
Input/output error while formatting
try to defrag the external HDD,possible bad sector
Jun 13, 2010 | Hitachi Travelstar 60 GB Hard Drive
When i format my hard drive it says disk error how to fix it?
The "format" has failed to complete, due to input/output errors on the disk-drive. It's time to buy a new disk-drive. If the "old" disk-drive is still under warranty, exercise the warranty to get it replaced.
Jun 12, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
I can not install Windows on my Compaq Evo N620c
The quickest solution here would be to put the hard drive into a computer that has Windows already running, and format it through the operating system itself. I've run into this problem a few times, and when another computer wasn't available I would use a Linux boot disk to clear out all my partition tables, then I would load up with Windows XP and tell it to write a new NTFS partition. Do NOT select the 'quick format' option, you'll have to wait through the long one.
May 04, 2009 | Compaq Evo N610C Notebook
About hard disk
I am assuming you got this error while trying to install Windows XP. If so, The solution to this problem will result in the LOSS OF ALL DATA ON YOUR HARD DRIVE. This is a two part process.
1) Check to make sure hard drive is seated in laptop well.
   Enter BIOS and ensure that your hard drive is detected. If not, try the auto detect feature that most BIOS' have and see if this detects your hard drive. If not, try restoring the BIOS defaults and see if that works. If not, hard drive may be bad.
   Continue to part 2.
2) Insert your Windows XP CD and boot computer from the CD and wait for setup to load.
  • At the Setup Notification screen, press Enter to continue.
  • At the "Welcome to Setup" screen, hit Enter to continue.
  • Read the Windows XP Licensing Agreement and press F8 to agree.
  • On the Xp Setup screen, you'll create an installation partition, but first some housekeeping. If you have any existing partitions you must delete all of them before proceeding.  After deleting all partitions, select "Unpartitioned space" and pressing Enter. And then press Enter again to confirm the partition size as is (it should already be set to the maximum size).
  • Next, select "Format the partition using the NTFS file system" and press Enter. Xp will now install.
If the same error appears then the hard drive is probably bad.
Oct 24, 2007 | Compaq Presario 5000 PC Desktop
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
