Question about Roper RAS8445KQ Top Load Washer
Roper Washer spinning cycle problem
Hi, I am new to this site. Can anyone let me know what could be the problem and how to fix it. My Roper Washer makes lot of noice during the spinning cycle. I believe the wash cabin is rotating irregularly. Any help is appreciated - syamala
This happened on mine as well. I determined that the clutch was bad. These are not belt driven but rather direct drive with a clutch/brake that controls the spins and agitate functions. Try washing an empty or very small load (like tshirts and underclothes) and see if that helps. ALso look underneath to see if there is any oil on the ground if so you most likley will need to replacet he cltuch mechanism... not an easy task for do it yourselfer!
Posted on Jun 26, 2007
Roper washer new will not fill with warm water on rinse cycle it fills and spins
if its only a new machine make sure transport bolts have been removed
Apr 09, 2014 | Roper Washing Machines
Washing machine does not spin in any cycle
Hello, It can be one of two things, the contacts in the dial can have worn or broke causing the relay not to open or close to activate spin cycle.
Most likely it is your transmission or main gear for your spin cycle.
I hope its the dial which is an easy fix, but the trans is a big project IF the washer is worth it. You may consider looking for new/used washer if trans is bad. Good Luck.
Dec 11, 2012 | Roper Washing Machines
My Roper top load washer stops in mid cycle and will not drain or do anything else
Most of the time that is lid switch failure. The lid switch must be engaged before the tub can spin. You can bypass the lidswitch to see if that is the problem. The lidswitch has 3 wires. 2 live wires and one ground wire which is green and bolted to the frame. Tie the 2 live wires together and see if the washer will work. You can use it that way but is could cause harm if anyone was to try and grab clothes out the tub while it is spinning full blast.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 23, 2012 | Roper RAS6233KQ Top Load Washer
Why doesn't my washer spin out more water. After spinning cycle clothes is quite wet. Could it be a loose belt?
Their is no belt. The washer uses a double shafted motor which drives the pump on one end and the tranny on the other end. You must have a small item of clothing in the tub to pump hose. This washer is easy as pie to repair by anyone. Just a few inexpensive tools and you can fix this washer. Here is a link to 4 videos and a training manual. How it works: Direct drive washer
Nov 16, 2010 | Roper RAS8445KQ Top Load Washer
Washing machine works up to the spin cycle, it does not spin it does however empty the water. this is a roper brand top load machine about 5 yrs old.
Lid switch. A safety mechanism used to make sure lid is closed in spin cycle. You can bypass this switch by placing the wires that go to switch together. DO NOT do this if you have children or do not want to remove that safety feature some require because they dont know better than to open a washer in spin cycle. :)
Jul 07, 2010 | Roper RAS8445KQ Top Load Washer
Leaking at drum where drive shaft enters
hi thanks for the question .your problem is major save yourself a lot of aggravations purchase new a nice washer is called roper built by whirlpool but cheaper same quality thanks the appliance doc
Sep 28, 2008 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Roper(whirlpool) washer will not spin
check the tub casting under the agitator or it the gearcase
Mar 17, 2008 | Roper RAX4233PQ Top Load Washer
Roper washer
We haven't heard back on this in about a week. I'm presuming this has been fixed?
Jan 01, 2008 | Roper RAS6233KQ Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
96 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Sal De
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
