Question about Acer Aspire 5500 5570-2609 Laptop
LCD Screen won't work after dropping the laptop
My LCD Screen won't work after dropping the laptop, I tried pluggin another screen in the VGA adapter & the laptop works fine.
Do you have an alternative on how I can solve this issue?
  • 679 Answers
You need a competant tech to see the notebook, it will only be a guess without being able to see what happened inside, it may be as simple as a connector or loose wire, to a new lcd display,take it to a compitent repair place, get the diagnosis, and if you wish to install it yourself we can help you. But no one can tell you from a website that they know what it is.
Posted on Dec 21, 2008
Screen will not load just white lines
Does external display work fine? If you have not checked, connect an external display like desktop monitor or a LED TV which has VGA connector to your laptop's vga port. You may have to use some fn keys combination to switch from laptop display to external. If external display works fine then check the display cable connecting laptop motherboard to laptop display. And also check laptop LCD/LED screen. You may have to try another with another screen in such scenario.
Sep 17, 2012 | Pavilion g7-1219wm Notebook PC
Acer Aspire 5536 only gives black screen when i connect power supply
  • Nothing is more annoying than a monitor that refuses to turn on. Make sure your Acer monitor is plugged in to a functioning outlet. If it's plugged into a power strip, try replacing it with a new one or moving the plug to a different outlet. Ensure that both ends of the power cable are plugged in firmly and securely, and that the connection to the monitor is not loose.
Cable Issues
  • Your Acer LCD monitor will usually accept DVI and VGA inputs. If you have an older computer, a VGA cable should work fine. If it doesn't have a VGA port, you'll need to obtain an inexpensive DVI to VGA adapter at your local computer store. A DVI cable, however, is compatible with most modern computers and offers superior picture quality over VGA. Make sure you're using the cable that's compatible with your system, and that you have the proper conversion adapter, if necessary.
Jun 19, 2012 | Computers & Internet
Dell 1545 laptop with white LED screen on start up. Works fine when connected to external screen via vga connector. Everything else works ok. Broken & remade connections between mobo & screen = no...
If the display works fine when connected to external screen via VGA connector then then the problem is either with the LCD display panel ( which consists of the display panel and inverter ) or the LCD cable that connects the LCD to the motherboard. You could try to re-seat the cable connection on the back of the LCD panel.
Aug 01, 2011 | Dell Inspiron 6000 Notebook
Hi, I accidentally dropped my notebook, it happens when I was getting ready for a play, then BAM! My notebook dropped. Whenever I try to turn it on, lot's of colors appear on the screen. But, there...
If you can here audio coming from the system then this means that windows is running. This is a definite problem with the LCD of the computer. It is not a problem with the video card or the motherboard. To further prove this connect your laptop to an external monitor and it is sure to work. It is likely that the lcd panel or the lcd cable needs to be replaced. Unfortunately this not something that you can fix yourself. Contact Asus or a local computer shop for assistance.
May 20, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Blue screen flickers and goes almost completely dark... when i plug into a different monitor, everything on that monitor is clear, so i know the compputer itself is fine. How do I check for a loose
most likely inverter issue, or somewhere in between inverter and LCD, illumination bets thing to do is to take aprt the LCD frame and disconnect and reconnect all wires leading from the inverter. If that doesn't work, the replace the LCD wires and or inverter.
May 20, 2009 | Acer Aspire 5100 Notebook
Weak or no Signal issue when connected to my TV.
Yes weak signal. Also closing the laptop lid puts the computer in sleep mode.
Jul 07, 2017 | Digital Lifestyle FA1B32Z 32 in. LCD...
Screen gone wild
If your external video is working, most likely your VGA controller is good. Your laptop is using the same controller to control internal and external video. It could be two things that would cause your problem:
1. LCD VGA cable that connect your LCD to the laptop
2. Bad LCD VGA connector on the board(cold soldered joints)
3. BAD LCD panel
Any of the following repairs will require disassembling of your laptop.
Regards
May 27, 2008 | Acer Aspire 4520-5582 Notebook
Blank screen
so there is a picture and the computer works fine other than that this is best taking to a computer shop because its likely to be a screen problem untill then you can plug your laptop into a normal computer by pluggin the computer screen into the vga port on the back of your laptop
Jan 28, 2008 | Compaq M2105USEC214UA Notebook
Toshiba laptop won't work with new optoma projector
-toggle the laptop display using the FN keys and F5 I believe. -lower laptop resolution to 800 x 600 -look in laptop display properties for lcd or external display settings, see if it (external crt) has to be enabled on the laptop first.
Aug 26, 2007 | Optoma Projector Multimedia Projector
Acer Aspire 5500 5570-2609 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
