Question about Dryers
Maytag electric dryer, put new motor,new push start switch, but the dryer will not start. I can however tape the door switch shut and hold down the start switch and turn drum by hand to start. But I can only put half the load in dryer or it will shut off. I have taken dryer apart and took the drum off and pushed the start switch and it has started the motor. But I can hold the end of the shaft by hand and it wont start.
  • jdbertrand Dec 21, 2008
    where is the motor control unit, is this the control selector for drying time?
    President:
  • Dryers Master
  • 2,651 Answers
""Check the motor control unit, and the motor coupling, depending on the model, if the machine does not spin on full load, the cause is usually one of this two parts."""
this would be a good diagnosis , if indeed a dryer (let alone your dryer had amotor coupling and/or motor control unit).but i guess when computer guys try to "FIX" appliances this would happen.
Posted on Dec 21, 2008
  • 700 Answers
Did you replace the capacitor fo the motor as well when you did the motor? It sound like it may be weak.
  • Dryers Master
  • 19,396 Answers
Ensure also that you did belt routing properly after replacing the motor.
Wont' come on at all, replaced start button with new unit, nothing still. was wondering how to bypass the timer control just to start the dryer.
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
Apr 28, 2015 | Maytag Dryers
Dryer quit won't start wife ran both washer/dryer same time put new breaker in still nothing?
Apr 18, 2015 | Maytag Centennial 7.0 Cu. Ft. Super...
All lights are on. Dryer will not start when start button is pushed. Why will the dryer not start?
Sep 10, 2014 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Maytag Performa dryer blows fuse after clothes get hot. I cleaned a large buildup of lint from inside the dryer all the way to my roof. I then replaced the hi limit thermostat, thermal fuse and dryer...
their are two possiblities causing that
1) while cleaning the lint from the motor a wire accidently got pulled of of the motor switch
2) to me the buzzing when start button is pushed and may or may not start,the motor is bad
When trying the trick to start the motor by hand the door switch also must be pressed in
Gene
Aug 05, 2011 | Maytag PYE2200 Dryer
When pushing the start button dryer hums but does not spin. when u release start button dryer shuts off
Sounds like a bad motor. Check to make sure the drum isn't stuck, if you can spin the drum put some tape on the door switch and press the start button while you spin the drum. If the drum continues to rotate, you have a bad motor.
Mar 10, 2011 | Maytag Washing Machines
Dryer will not turn on. makes slight buzzing sound when button is pushed. Light goes on, power is on.
Sounds like the motor is gone. Try opening the door and pushing the door swithch inside the dryer door cavity.This may take two people but while holding the door switch, push the start switch and turn the dryer drum at the same time.(in a clock direction) If the dryer starts it means the moter is shot.
Dec 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My neptune dryer sounds like it is going to start but then fails
sounds like a bad motor. when it hums when you push start, open the door. put a piece of tape on the door switch to hold it in. at the same time, push the start button and turn the tub with your other hand. if it starts, this only confirms it is a bad motor. the motor will need replaced. good luck. shane
Jul 01, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool electric dryer LEB6300 door
you have to lift the top cover. then from there you can access the door switch of the dryer.
look closely between the front wall and the top cover. pry the top cover slowly and push the plastic lock that is holding the top cover.
then you can see the switch now and replace.
tnx 4 using fixya,
drcool
Sep 08, 2008 | Whirlpool LEB6300 Electric Dryer
Dryer hums when start switch is turned
you don't have to "pop" the top off the dryer. the only thing you can do to possibly solve this problem without a professional is to:
  • tape down the door switch with strong tape, or have someone else hold it down.
  • physically turn the tub inside the dryer while pushing the start switch.
  • this will hopefully loosen whatever has the motor stuck.
if this does not work then the motor in the dryer might be bad or going bad, especially if a burning smell is present when you hear the humming sound.
Aug 01, 2008 | Hotpoint NVL333EY Electric Dryer
Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
Mar 30, 2008 | Dryers
Dryers Logo
Top Dryers Experts
Marvin
Marvin
