Question about Nitro BMW-486 Car Audio Amplifier
Blown channel i have a 2050 watt amp i blow a channel and wanted to know how to fix it or should i find a place to fix it
  • Nitro Master
  • 637 Answers
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Might be time to rep .A thumbs up would be greatly appreciated if this answer is helpful to you. blown channel - blown-channel-zb4bomd1rt4qms0dqd12kkt2-3-0.jpg
Posted on Dec 20, 2014
  • 15,935 Answers
Unless you have extensive knowledge about capacitors, and the internal workings of an amplifier... for your own healt, i would reccommend a preofessional amp repairman. usually a power supply shouldnt cost more than $75 including labor. However, an entirely new Nitro Amplifier can probably be had for not much more. If there are on-board fuses, check to see if that is blown first. Even if it looks good, remove it and test continuity with a voltmeter, and/or ust replace it.
Posted on Dec 21, 2008
I'm running 8 gauge wire for battery cable and ground cable....my amp.is a momentum 600 watt...2 channel. ....my fuse is blowing every time I hook up either cable...
First of all, what size fuse? Check the amp and see what max amperage is, and insure your fuse is that size. Secondly, I suspect either a blown speaker or blown outputs. Disconnect the speakers from the amp and see if the fuse still blows. If it does, either you are hooking two wires up improperly, or your outputs are toast.
Aug 06, 2016 | Car Audio & Video
I have a Sony Xplod 800w Amp running a 10' Sony Xplod Amp....i unhooked the amp to do some moving and i tried to put it back in today and it didnt have any sound coming from it! I did notice the power...
it sounds like it could be a blown channel in the amp. if the sub was blown it would still work just sound horrible. i have blown many subs and amps. you can bring it to an audio shop near you and they can fix it. i just got one of my channels fixed for 35$
May 11, 2011 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
My pyle plmra 220 600 watt 4 channel amp blew out, pyler said it would be 50 dollars to send it in to them so i said to heck with that and oppened her up and found a capacitor blown, but when i replaced...
outputs also blown, go to ebay and buy a better amp form the same price you would have paid for pyle to fix that one, just keep playing with that one and you will get better at repairs, thats how i learned to fix amps.
Dec 13, 2010 | Pyle - plmra220 - Marine 600 Watt 2...
Just want to know if i should use my ll203 amp in am or ssb mode when running with a cobra CB radio?
What radio?? Does it have single side band(SSB)? If not, then don't use SSB.
AM - amplitude modulation
SSB - single side band.
If you have SSB, there would be a switch on it to transmit in SSB. If not, it is AM only.
Second, Has this radio been worked on to be able to run on an amp? If not, you will blow the amp.
A CB radio transmits dead keys with 4 watts of power, and transmits with 4 watts of audio.
a 4 watt dead key is too much for a linear amp. You will smoke the transistors. Also, 4 watts of audio is not enough to drive it properly. You won't get full power.
The dead key needs to be around 2 to 2 -1/2 watts,or what ever makes the linear dead key half its peak wattage., and the modulation (audio) turned up all the way.
It doesn't sound like you know too much about CB radio's. Not a big deal, you can learn. For right now you may want to take it to a cb shop and tell them you want a peak and tune, and set up to run a linear.
You can find CB shops usually at truck stops. Some area's they are other places. Check the internet for local shops.
Oct 31, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
I want to know how many watts, the denon dra-375's output is? my brother-in-law gave me this unit and the cover's became diattatched off the back of the all the pot's. i am still in the process of putting...
The unit is rated at 120 watts total output ( 60 watts per channel x2 channels) As far as being worth fixing it depends on the price of the parts and what you want to do after its fixed. I looked around a little and the unit gets good reveiws from owners. They say its great for a "just music" system.
Jul 28, 2009 | Denon DRA-375RD Receiver
Support Question about RMS
you are going to need an amp that can supply the right amount of rms power to make it sound good. these sony subs are rated for 380 watts rms. so in order to find an amp that will supply two, you must multiply that figure by two. so you will need an amp that can supply around 500 to 750 watts continuously (or rms). also you are going to want an amp that is either class d or class ab rated. these amps are built to push subwoofers exclusively and will give you the best efficiency and sound out of your subs. you will also want to get an amplifier is a monoblock amp, and not a stereo amplifier. make sure the amp can put out that rms rating at 2 ohms as two 4 ohm speakers equal 2 ohms wired in parallel. i have a kenwood kac9152d that puts out about 2000 watts max at 2 or 1 ohms (900 watts rms) that i used with my two sony xplod 10's for about 2 years. it was kick ***! now i dont know if you need that much power but they will handle it as long as you dont push them too hard for long periods of time, otherwise you might end up blowing them up! (depending on the box size that is, and the quality of it as well...)
i have years of car audio installation experience and can help with setting up and wiring any mobile entertainment system you can imagine. may i ask what kind of music you listen to and what kind of box do you have for these subwoofers?
if you have any questions email me at thadoggma420@hotmail.com
Jan 22, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Brutus 1600 watt hi fonics amp
i have had the same problem with one of my amps that was given to me by a friend and one of the channels were blown. Blowing a channel can cause the protect light to stay on.
May 08, 2008 | Car Audio & Video
2006 12" Kicker L7 4 ohm
first whats the range in terms of WATTS that your 12" sub can handle in 4 OHMS ? second , lets check the AMP , POWER ACOUSTIK 1800 WATTS , Now thats a lot of power to drive a single 12" sub speaker . your amp is 1800 watts , per channel is around 500 watts , if BRIDGE thats around 1600 watts rms for ONE channel , if your sub can handle that kind of wattage fine , but it will not blow the amp , what it does is shuts down , some kind of protection mode , it will come back on after a minute or so. I suggest to use one channel in stereo mode , or purchase another sub to use the other channel. i hope this helps AJ
May 06, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Sub for lanzar mxa 282
2 X 18" Kicker CVR they will work really clean. 2000 watt max each and 1000 RMS just like your amp.
Nov 16, 2007 | Lanzar MXA282 Car Audio Amplifier
Nitro BMW-486 Car Audio Amplifier Logo
230 people viewed this question
Top Nitro Car Audio & Video Experts
ravie__s
Level 1 Expert
Mark Skinner
Are you a Nitro Car Audio and Video Expert? Answer questions, earn points and help others
