Question about Craftsman 4 Cycle Blower/Vac
My snow thrower once engaged, will not move
It starts, but like a car that starts, but you put it on drive, or reverse, it would not move, what can I do?
Depending on how old it is it is either belt or chain driven check those. but first check your shear pins in the axles to make sure the axle isn't turning inside the wheel those are the basic 2 prob i worked on them for 10 yrs for sears
Posted on Jan 09, 2009
The drive cable came off as i was engaging it & i can't figure how to replace it
TRACTION DRIVE CLUTCH CONTROL
CABLE
6.1. The drive control is on the right side of the handle bars
6.2. Stop engine and allow it to cool disconnect disconnect
the spark plug and ground it to the engine.
6.3. Confirm that the fuel level is low enough to prevent spillage through the gas cap vent with a plastic bag between the cap and the filler neck.
6.4. Carefully tip the snow thrower forward so it rests on the auger housing.
6.5. Mark the bracket to the frame as demonstrated in figure 5.2
6.6. Detach the z-fitting end of the cable from the engagement handle.
NOTE: The cable routes down to the cable guide pulley that is mounted on the drive cable adjustment bracket.
6.7. Remove the bottom access panel.
6.8. Detach the spring end from the friction wheel support bracket.
6.9. Examine the removed cable: If the cable failed because of something other than normal wear, identify and correct the cause before returning the snow thrower to service.
6.10. Install new cable by reversing the removal proceedure.
6.11. Run/test/adjust the tension on the traction drive
clutch control cable.
Feb 15, 2016 | Craftsman Snow Blower / Snowblower Bottom...
How do I get the left wheel of a Murray snow thrower to engaged when the traction lever is engaged?
You will find there is a shear pin that has broken in the wheel that will not engage. Not sure if its a pin or bolt. I had to replace one several years ago.
Jan 24, 2016 | Murray Feiss Murray 27" Dual Stage Snow...
1998 Stiga Snow Thrower
possibly it needs some TLC and oil to free things up .
Nov 18, 2015 | Garden
Auger will not engage
blocked or frozen blower inside of housing, move to warm area or chip out the ice
youre going to need a new belt after burning that one up
Feb 06, 2014 | Mtd 2 Satge Snow Thrower 26"
I can go in reverse but not in drive
Takes two people. Block the wheels, climb under the car and check the linkage.
Jan 13, 2014 | Ford Mustang Cars & Trucks
Snow Thrower Won't Start. I have a Sears 26" Snow Thrower Model No 247.889702. It will not start. Changed fuel, new spark plug, propoerly primed the engine, tried both pull start and electric star
does it have spark? if you can start it with starting fluid chances are the carb needs a good cleaning or replacement. fuel these days goes bad in about 2 months without stabilisers in it. gums up the tiny passages in the carbs. i suggest seafoam as a treatment but anything is better than nothing...good luck
Nov 18, 2017 | Garden
Snow blower shift linkage hard to shift
use wd-40 penetrant to get the rusty bits to move
oil liberally when storing
Jun 10, 2017 | Craftsman Garden
I have Troy-Bilt storm 7524 snow blower which normally works fine, however, it has started to have problems shifting back into forward gear after being reversed. I'll put the snow-blower into reverse gear...
Try lubing the linkage where it shifts from forward and to reverse the linkage is most likely freezing up or has snow or ice build up causing it not to shift, My thought is your shoving it hard enough that it finally engages when you get the snow or ice to break off.
Jan 05, 2010 | Garden
Snow Thrower does not self-propel
Did you check under the handle area, near the blower itself for a transmission lever? This will engage & disengage the transmission.
Jan 25, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Craftsman 4 Cycle Blower/Vac Logo
89 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
