Question about Protech Systems FasNSeal FSWMKE4 4" Vent Kit for Wall Mounted Boilers & Wat
VOKERA UNICA HE BOILER - ONLY ONE YEAR OLD. DON'T HAVE USER HANDBOOK AND NEED TO RESET THE BOILER. IS THE HANDBOOK AVAILABLE ON-LINE?
    Champion:
  • 248 Answers
Vokera will send in post if requested
Posted on Oct 12, 2009
Vokera boiler problem
If it is a gas unit, I am not familiar with that unit, I would get a qualified tec, it sounds like the gas is lightning late and the explosion you hear is real. Sorry I cannot offer more help.
Apr 28, 2014 | Water Heaters
Vokera aav leaking
Robert, i'm sorry to say but the AAV's are machined parts and the seal should not have been broken by removing the cap. The floats are set perfectly and you would have been easier replacing the whole vent. You could have isolated all the pipes under the boiler and just drained the boiler down by releasing any pressure by the pressure release valve. You may need to buy another AAV and start again.
Apr 06, 2014 | Water Heaters
Vokera boiler problems
need to change thermostat and a thermocouple
Jan 28, 2014 | Water Heaters
Hi. Had a code 10 on my Vokera UNICA HE boiler. This was due to the overflow pipe freezing up. The pipe has been disconnected from the boiler and the boiler pipe is now dripping into a bucket. However, the...
I had the same problem. There's another clear rubber pipe underneath, that runs from the front right to a pump in the middle. I had to pull it off and dry it with a hairdryer before mine would light properly. Blast into the hole the pipe came off too to dry the sensor if there is one.
Dec 20, 2010 | Water Heaters
I have a vokera unica 28 which pulses when firing
your fan may need attension fan runs after boiler shuts down is normal on some Vokera,s too clear fumes out the flue 2mins approx
Oct 04, 2009 | Water Heaters
Vokera mynute 14se lockout reset button on
Has the boiler cool down? Try turn the power off for a few minutes and see if that will work.
Mar 14, 2009 | Water Heaters
Vokera combi boiler
there is a zoneing valve thats suppose to be in the line to keep this from happening, might even have a check valve either way which ever one you have is bad and should be changed with a new one
Feb 20, 2009 | Water Heaters
How to bleed a vokera syntesi combination boiler
I think you mean your boiler needs pressurising firstly connect hose hand tight open the non return valve normally teed into a 22mm pipe then flick the valve lever on the cold supply quick little bursts till you reach your required pressure best of luck
Nov 15, 2008 | Water Heaters
Protech Systems FasNSeal FSWMKE4 4" Vent Kit for Wall Mounted Boilers & Wat Logo
757 people viewed this question
Top Protech Systems Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Protech Systems Water Heater Expert? Answer questions, earn points and help others
