Ovens Logo
Posted on Dec 21, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
FAN ON OVEN HAS STARTED TO MAKE VERY LOUD RATTLE
OVEN IS BUILT IN DOUBLE OVEN, 8 YEARS OLD. WHAT DO YOU ADVISE I DO ?
Anonymous
Level 3:
  • Master 700 Answers
  • Posted on Dec 22, 2008
Anonymous
Master
Level 3:
Answers
700
Questions
Helped
306846
Points
1781
I wpould suggest tto look at the fan blades and see ig there's any thing on them, if there isn't then your blower bearing is going oiut on youe motor.
Beko double oven the fan has started to make a loud noise and sometimes cuts out had oven 18 months
by loud noise do you mean squeeling squaking .
then its the fan bearing just order another fan motor.
Jul 25, 2014 • Ovens
My AEG competence oven is making a loud buzzing noise coming from the top fan? The food tonight was either burnt or under cooked? The buzzing is also loud when switched off/cooling down? Any ideas please.
I would suspect that the problem is caused by the external cooling fan located under the outside cooker cabinet housing, which continues to operate as the oven is cooling down if it is built in, you will have to remove it from the oven housing to access the fan
1helpful
Smell has started in our 8 month old Neff oven. No obvious reason for it - pretty clean and no unusual food cooked. Any ideas ?
There may be a problem with the cooling or extraction fan on the oven. All Neff appliances come with a two year manufacturers warranty, so I would advise you call them out on 0844 892 8999. If you attempt a repair yourself, you could invalidate the warranty.
All the best.
3helpful
Whirlpool built-in double oven model# RBD305PDB12
the humming sound is coming from the "squirrel cage" fan in the back of the unit, there may be some resonance vibration from the fan this issue should be addressed by a qualified service tech, the whole wall oven needs to be pulled out, i would have him check the fan.
4helpful
NOISY OVEN
Yes, it can be fixed quite simply.
First check that the fan is not catching the cover or grill, if it is not remove panel covering fan and see if the fan blade is loose,on the shaft, they are usually held on by a left handed nut., so to tighten go the oppisite way to what you normally do, if that does not cure it, then your only solution is to replace the fan motor complete.
Plz rate my solution.
Thanks, and a merry xmas.
Dec 21, 2008 • Ovens
Noise exhaust fan on my Amana AOCS3040
The exhaust fan on my oven (Aosc3040) is loud also and has always been. Just hope nothing significant brakes because this model has been discontinued and it is difficult to get parts for it. I have been told by Amana that the life expentency of this oven is 10-13 years, so don't invest in anything that is not necessary. The glass door broke on mine and I cannot get a replacement piece. My kitchen looks terrible. It is a shame because the oven works great. Linda
Main oven tripping the fuse
probable fault to earth of circular element - gets worse when element hot. you will need a megga to confirm this.
Top Zanussi Ovens Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
