Question about Acer TravelMate 290 Notebook
Acer TravelMate 290
Thank you very much for your reply Honestly your suggestion about the COMS battery is very wise , Yes I thought about this solution but the COMS Battery looks fine. I have even measured the voltage and it was about 3 VDC , and its soldered to the motherboard , so there is no way of losing connection. Regarding the recovery CDs yes I have tried it one time before, There is a fresh copy of windows on the hard disk , but even with this fresh copy of windows the problem still exists , ( I am sure its not an operating system problem ) As I said before, sometimes it loads the window with no problem for few seconds or minutes but whenever you move or touch the pc it will turn off again. I don't know if this is logical, but I have noticed that if I put the pc on an angle or just put something under the pc in the front it will work , then as soon as I remove it or touch the pc it will go off and keeps on rebooting in a loop. to make it easier I am including two Pictures; One is the final step before it reboots, and the second for the screen when it goes blank. Many thanks for your help
I have the exact same problem with my acer 290. At first you could give it a good whack and it would work just fine (HD wouldn't spin up until you hit/pressed on it in just the right spot). Now it does as Fakhri described (sometimes tilting/pressing on it etc works for a bit, most of the time however, no dice. I've taken it apart cleaned everything thoroughly, but it does not look like there is a blown cap anywhere. Perhaps a leaky capacitor (I've noticed that now if I hit it it has power for 10-15 seconds, then dies...)??? If anyone comes up with a solution, besides a new motherboard... please let me know.
Posted on Apr 10, 2007
  • Peter Cebo Apr 10, 2007
    One more thing - I have seen that some people believe that it is a Power Supply problem - although clearly a power problem, I have a good battery and the problem is exactly the same whether the battery is used, the PS is used, or both.
    Could this be a CMOS battery problem?? I will try replacing the battery and will post my results here.
  • 60 Answers
Is this pc a new build? if so have you screwed the motherboard directly to the case or used the raising clips? sounds like a possible short somewhere along the line.
Posted on Apr 05, 2007
SOURCE:
Flash bios update
here is a link to the BIOS upgrade just download it and run it it will up date your BIOS for you.
To the web site
http://www.driverstock.com/Acer-TravelMate-290-driver-download/4-21-12922/index.html
A direct link to the download.
http://www.driverstock.com/Acer-TravelMate-290-driver-download/4-21-12922-94790/index.html
I hope this helped
Thank you,
Norse
May 18, 2010 | Acer TravelMate 290 Notebook
Need a recovery disk for acer travelmate 290
do u have another laptop or pc.
if u have open google then open isohunt then.
1st download nero iso maker
2nd download recovery disk for ur laptop
then u nid a 4.7 gig blank disk then burn the recovery disk
Dec 12, 2009 | Acer TravelMate 290 Notebook
Acer Travelmate 290 laptop beeps all the time
try to turn off the alert sound on connectivity and time event from windows.
hope this works.
Jul 11, 2009 | Acer TravelMate 290 Notebook
Laptop acer travelmate 290 hanging
Is your battery 0k? it may be faulty. pull it out and see if you have the same problem with NO battery installed.
Jun 18, 2009 | Acer TravelMate 290 Notebook
Sound drive for ACER travelmate 290
Try Here:
http://www.acerpanam.com/flex/acerdrivers/bin/drivers.html?CFID=235946&CFTOKEN=23918337
Pick Notebook from the list, then your model, then Audio driver.
Mar 25, 2008 | Acer TravelMate 290 Notebook
Beeping
If the system beeped and is a long one, but you did not get it to boot i would suspect that the processor has failed, but if its a short beep and you can get into the bios, check the date and time as if it is incorrect, if so, it may simply be that the cmos battery needs replacing on the motherboard. Beep codes can define allsorts of differnt things, so without knowing the motherboard make, it is hard to pin down to a specific fault so applogies if incorrect.
Jun 06, 2007 | Acer TravelMate 290 Notebook
Acer TravelMate 290 Notebook Logo
136 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
