Hello
Dear Friend...
You can check your Device Manager under My Computer / Right Click / Properties / Hardware Tab / Device Mgr
You need to check the Control Panel / Sound and Audio Devices / Audio Tab / Sound Playback option.....
if it's greyed out then u dont have a Sound card or the card is corrupt....
if no internal sound card is present or if it's not working then u have this alternative....buy a " USB Sound Adaptor" and connect it to the USB port and connect the speaker sound jack to the sound port in this adaptor....u will get back the sound....also keep in mind that u " may " have to disable onboard sound in BIOS, u may also have to make changes in the Control Panel / Sound and Audio Devices / Audio Tab / Sound Playback option... Click the drop down button and select the "USB Audio Devices/Headset"
You can get this in Ebay for $1 to $4 or google it to locate a place near u......
This is the one i am refering to(I bought it in Ebay for 1$)....u can buy something similar also....there are many available, all of them are made in China, as it's USB enabled plug and play, connect it to your PCs USB port....you will not need any software or driver to install it....Winodws will auto install it and show it under the Device Manager / Sound Audio and Games Ctrlr as told above and will also show it under Control Panel / Sound and Audio Devices
If you find this solution useful please leave a feedback and rating to this solution.
Regards....
All the best, my dear friend..
i have the same problem
need the model to find sound for you
