Question about Ultra Products Guardian Ultra Source 17,500 Watt Emergency Power System - 4583
I have a slight power surge on my 15,000 ultra source
I noticed the lights diming slighly. I went to check out the generator and noticed a slight surge in the engine so I disconected all power had no change. The generator is at my Camp house and is only run about one or two week ends (4-5 hour at a time) in a month.I removed the breather cover and noticed the linkage on the controller moving slighly.I changed spark plugs and still no change.
My Brother in law has practicaly the same unit as a stand by generator on his home. He said he notice his doing the same thing.
I keep my generator serviced more than the book calls for and I keep stabil in my gas to keep it fresh.
  • 132 Answers
That linkage is suppose to move. The more power draw the more the linkage moves
Posted on Feb 02, 2009
When I try to start it it clicks than nothing. Any thoughts?
What you are describing is the symptoms of a dead battery, bad or loose cable or perhaps a seized piston.
Jun 13, 2015 | Generac Guardian Ultra Source 15,000 Watt...
Cant get it to turn over
charge battery,fill oil,turn switch to on,try to jump the solenoid,if it turns over,it is the solenoid
Starts up but will not run but for a few seconds
Check the oil. Some engines will shut down if the oil is low. Otherwise you probably have a dirty fuel filter and the carburetor fills up with gas long enough to start but isn't getting enough gas to keep it full.
Feb 13, 2014 | Generac Guardian Ultra Source 15,000 Watt...
Start switch does nothing
Try the easy thing first, check connections and lube switch with mfg suggested lubricant. Sounds like a corrosion problem to me.
Nov 10, 2013 | Generac Guardian Ultra Source 15,000 Watt...
I need a wiring diagram for a generac gp15000e generator
I have a 15000 ultrasource generator the start and stop switch was taken out i need to put it back The problem is i dont know which wire goes where and when i look at the wire diagram the numbers are different the numbers on my unit are 15, 11, 133, 14, 12, The 15 and 11 are the same wires the start and stop switch has 6 males on the back to plug the wires into Does anyone know which wire goes where???
Nov 05, 2011 | Generac Guardian Ultra Source 15,000 Watt...
Guardian 15000 Watt Portable Generator will not charge the 12volt battery. Help
Suggest you go to Amazon.com and do a search for the Generac Guardian. When you find it, look in the product details and you will see Product Manual (PDF) under the Product Details.
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000031765.pdf
it has a troubleshooting guide located on page 19.
No Battery Charge DC output.
1. Battery posts are corroded. 1. Clean battery posts.
2. Battery cable is bad. 2. Replace cable.
3. Battery is defective. 3. Check battery condition; replace if
defective.
4. Receptacle is bad. 4. Contact Authorized Service Facility.
Hope this helps!
Jun 02, 2011 | Generac Guardian Ultra Source 15,000 Watt...
The current starter battery is not recharging. I would like to know if there is a problem with the alternator or battery charging mechanism. If so, is there a replacement part available ??
Hi Frank,
Have you charged the battery and see if it holds a charge? If it does, then it's probably your alternator.
I hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Apr 27, 2011 | Generac Guardian Ultra Source 15,000 Watt...
Fuse blows repeatedly
The auto speed control is failed. Keep it manual and see how it does...It will run at full throttle even when no load is running. Then fix the throttle control when able.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Aug 09, 2009 | Generac Guardian Ultra Source 15,000 Watt...
Dont have 12 volts to start switch generac guardian ultra source
Have you checked the fuse? Mine keeps blowing the fuse (located on the back of the control panel) with each startup and shutdown or use of idle control.
Jun 20, 2009 | Generac Guardian Ultra Source 15,000 Watt...
Ultra Products Guardian Ultra Source 17,500 Watt Emergency Power System - 4583 Logo
154 people viewed this question
Top Ultra Products Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Ultra Products Electrical Supply Expert? Answer questions, earn points and help others
