Kenmore 30464 / 30465 / 30469 Gas Single Oven Logo
Posted on Dec 21, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Oven under bake does not kick in
Bake mode
press start
gas will not ignite
Ron Coons
Level 3:
President:
  • Kenmore Master 2,651 Answers
  • Posted on Dec 21, 2008
Ron Coons
Kenmore Master
Level 3:
President:
Answers
2651
Questions
Helped
1547544
Points
7824
Most common issue is a faulty bake ignitor, easy to replace 2 scres and 2 wires. located on the burner bar(white porcelain unit) in metal cage.
I have kenmore gas oven ignitor glows but will not light
Hello there:
It doesn't bake dot_lineone.gif Bake igniter
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve
If you are certain the igniter is ok, it might be a good idea to call a professional appliance technician.
Need a new oven igniter? Click here for most common oven igniters or enter your oven model number in our PART SEARCH. ^ top clear.gif It doesn't broil dot_lineone.gif Broil igniter
When the broil igniter becomes weak or burns out, your oven would not broil. The broil igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the broil igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_range_oven.aspx#ixzz1CgFQ7lBJ
3helpful
Oven will not light. it is a frigidaire model #
When the bake igniter becomes weak or burns out, your oven will not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve will not let the gas out into the oven burner. A weak igniter must be replaced.
  1. Defective thermostat
  2. Defective selector switch
  3. Defective gas safety valve
  4. Defective gas valve coils
3helpful
Gas oven won't ignite
-- defective gas valve coils
Nov 15, 2009 • Bosch Ovens
1helpful
Ignitor lights up and I can smell and hear the gas, but the oven will not light
Nov 13, 2009 • GE Ovens
I HAVE NO IGNITER OPERATION OR GAS COMMING THROUGH THIS OVEN, ITS SUPPOSED TO BE RELATIVELY NEW.
Hotpoint lp gas range Mod# rgb532bea5wh. Oven will not light. Igniter does work but no gas is passing thru the oven control valve. I replaced the oven control valve but oven still does not work. what else...
-- defective pressure regulator(likely issue if the igniter is ok)
5helpful
My kenmore gas oven won't heat. I turn to dial to temp i want can smell gas building up in oven and can see a glow in bottom of oven but will not ignite. Sometimes if I turn on a cooking eye I can then...
2helpful
OVEN WILL NOT IGNITE IT IS GETTING GAS TO THE SILVER PC IN THE BACK
Oven will not relight during cooking cycle
When the bake igniter becomes weak or burns out, your oven would not bake properly. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
The gas oven will not light. gas burners light but oven does not
O-defective thermostat
O-defective selector switch
O-defective gas safety valve
O-defective gas valve coils
Sep 20, 2009 • Ovens
Top Kenmore Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
